Latest post Tue, Sep 5 2017 4:37 PM by gaspar. 13 replies.
Page 1 of 1 (14 items)
  • Thu, Aug 31 2017 1:10 PM
    • gaspar
    • Montreal, Quebec
    • Posts 99
    • Points 1,230
    XAVC-S long clips won't transcode MC8.9.1
    Hi all,
    I've been given a project shot on a Sony. The clips are mp4 XAVC-S. The newest version of Media Composer (8.9.1) lets me link the clips, which is great. However, long clips always fail to transcode. The longest clip I have that transcodes successfully is about 10 minutes. Longer clips always fail.
    Has anyone else run across this? My workaround at the moment is to convert with Squeeze and link that clip but the colours don't match.
    Thanks!
    Gigabyte X58A-UD7, Core i7 920, 24G GSKill Ram, Quadro FX 1800, 2XDell U2410, Win 7 64bit with MC8.9.1 [view my complete system specs]
  • Thu, Aug 31 2017 1:17 PM In reply to
    • Fazz Powell
    • Joined on Sun, Dec 3 2006
    • Annapolis, MD
    • Posts 333
    • Points 4,630
    Re: XAVC-S long clips won't transcode MC8.9.1
    I have seen simular posts on the Avid Editors of Facebook Forum on clips over 20 minutes. I don't recall what their work around was, or if they had one yet. Not much help, but yeah...it's happening to others. 8.9.2 anyone? :)
    MC 8.8.5 w/Symphony option. NitrisDX, HP Z800 Dual 2.67Ghz, 96GB Ram, Nvidia M4000, BCC10, Sapphire10, TitlePro5, ProTools 10.5,Terrablock 24XS Multi-Write... [view my complete system specs]
  • Thu, Aug 31 2017 2:23 PM In reply to
    • DStone
    • Massachusetts
    • Posts 3,194
    • Points 41,350
    Trtanscoding also fails for background transcodes (see this other post http://community.avid.com/forums/p/181552/846587.aspx#846587). It's been entered as a case in the support system 03275602. I'll send an update that it's also happening on foreground transcodes.
    DIY quad core I7-4790K, 16Gb, NVidia GTX 970 4GB, Win 10 Pro, MC 8.7, MC 7.x [view my complete system specs]
    Dave S.
  • Thu, Aug 31 2017 2:36 PM In reply to
    • gaspar
    • Montreal, Quebec
    • Posts 99
    • Points 1,230
    Thanks for that link. My searches didn't come up with that one.
    My error was the same and also during background transcoding. Can't remember if I tried in the foreground.
    Cheers,
    Vito
  • Thu, Aug 31 2017 4:10 PM In reply to
    • Lukas Boeck
    • Joined on Fri, Jul 31 2015
    • Austria
    • Posts 362
    • Points 4,205
    what plugin are you guys using?
    got 8.9.1 on a mac here and: nada (assertation failed)
    tried quicktime and avid generic
    MC 8.4.4 Cusom bulid Supermicro X9SRL-F, 32 Gig Ram, 3ware 9750 6x6TB Seagate EC Drives, LSI 9207 + LTO-6, Mojo DX, Artist Color, Flanders CM240, GTX 1070... [view my complete system specs]
  • Thu, Aug 31 2017 4:25 PM In reply to
    • gaspar
    • Montreal, Quebec
    • Posts 99
    • Points 1,230
    It's the generic MC plugin, new for linking XAVC-S in MC8.9.1
  • Thu, Aug 31 2017 4:35 PM In reply to
    • DStone
    • Massachusetts
    • Posts 3,194
    • Points 41,350
    Just to note, I've only been testing on the PC. I don't have a MAC on which to compare results.
    Dave S.
  • Thu, Aug 31 2017 9:21 PM In reply to
    • AntCaladine
    • Joined on Tue, Sep 11 2007
    • Stourbridge, UK
    • Posts 307
    • Points 3,870
    Out of curiosity, can you ama a clip in, drop that clip on the timeline so it has all its a/v tracks and data track, then remove a track at a time and see if you can transcode that sequence. Start with removing the data track. It might help show where the error is.
    when the fs7 first came out we had issues with the data track on xavc-i clips so used to ama, unlink, deselect tracks then relink, then transcode. I still do that for safety even now.
    3x HP Z820 16GB ram, Win10 Pro 64bit, Nvidia Quadro 4000 AMC 8.9.2, 2x Aja IO, 1x Blackmagic 4k Studio 16TB T-Box Shared Storage with 8gb Fibre connection... [view my complete system specs]
  • Fri, Sep 1 2017 12:54 AM In reply to
    • DStone
    • Massachusetts
    • Posts 3,194
    • Points 41,350
    XAVC-S doesn't have data tracks. For grins I just removed the audio tracks and started a transcode in the foreground. I'll wait to see what happens; if it works, I'll try it in the background.
    Dave S.
  • Fri, Sep 1 2017 9:32 PM In reply to
    • Lukas Boeck
    • Austria
    • Posts 362
    • Points 4,205
    zero, nada, zilch.
  • Sat, Sep 2 2017 3:11 PM In reply to
    • DStone
    • Massachusetts
    • Posts 3,194
    • Points 41,350
    Removing the audio tracks didn't work.
    Dave S.
  • Sat, Sep 2 2017 8:32 PM In reply to
    • Lukas Boeck
    • Austria
    • Posts 362
    • Points 4,205
    nope
  • Tue, Sep 5 2017 4:32 PM In reply to
    • DStone
    • Massachusetts
    • Posts 3,194
    • Points 41,350
    This is now bug number MCCET-2027. Hopefully it will be a quick fix (and include the other XAVC-S problems as well).
    Dave S.
  • Tue, Sep 5 2017 4:37 PM In reply to
    • gaspar
    • Montreal, Quebec
    • Posts 99
    • Points 1,230
    Great. Thanks for the help, David. That will be a real time saver in future.
