Latest post Fri, Jun 1 2018 2:51 PM by Marc Cebrian. 38 replies.
Page 2 of 3 (39 items) < Previous 1 2 3 Next >
  • Tue, Aug 29 2017 10:36 PM In reply to
    Re: MC 8.9.1 and Boris RED 5.5 Conflict
    W10 pro 64 here was a clean install on a new computer 4 months ago.  Installing Red 5.6 yesterday added these Microsoft Visual C++ files   1x 2008 and 1x 2012.    I have Quicktime 7.7.9 installed.  Testing on new Project with new timelines.
    Marc Cebrian:
    I am now crashing by importing Quicktime MOVs
    Was this working with 8.9.1 and then stopped?
    What type of QuickTime's?
    I just imported 4 .movs  These .movs are test patterns originally exported SAS from MC 6 as DNxHD 185 at 25P)  No issues.
    I also separately imported 4x 4K  ProRes HQ .movs without issues.
    I did not have any .aif files handy to test  those.
    My IO is BM Intensity Pro 4K
  • Tue, Aug 29 2017 10:43 PM In reply to
    It's not a solid issue, but has happened twice today. I've brought in about 30 files total. It did it to me once yesterday and I thought it was a fluke. These are a blend of DNx145 up-rezing to UHD on import and also DNxSQ UHD imports. The AIF was a straight to 1080p import. This is very unusual for these imports to act this way.
    Thanks for checking.
    We have the DNxIO from Black Magic.
    Windows 10 Enterprise - Dell Precision 7810 - 32GB RAM - DNxIO - Nvidia Quadro M5000 [view my complete system specs]
  • Wed, Aug 30 2017 1:51 AM In reply to
    Marc Cebrian:
    So a significant difference could be that we have different BM desktop versions installed. I have 10.9.3 on the W10 test machine and 10.4.2 on the W7 test machine.  I asume you have the Avid version.
  • Wed, Aug 30 2017 2:59 AM In reply to
    Correct. We are using the Avid certifified 10.9.6 from Avid directly. I doubt this has anything to do with our problem...seems like an effects engine issue to me.
  • Wed, Aug 30 2017 8:01 AM In reply to
    • Gretski
    • Posts 154
    • Points 2,065
    Just a thought - I had a lot of issues with Avid FX ( and BCC title studio) crashing the system a while back.
    It turned out to be a Nvidia graphics card settings.
    tripple buffering - off
    vertical sync - off
    Buffer flipping - block transfer
    multi display - compatability mode
    Might help.....
    Asus X299, i7 7820, Nvidia 2000M 32GB ram, NVME SSD 8.9.1 ( yes its very fast!) [view my complete system specs]
  • Wed, Aug 30 2017 12:19 PM In reply to
    Gretski,
    I have never had to adjust any of the default Nvidia settings. That said, I am willing to try anything. I checked your setting in the Control Panel. The only one I could not find was Multi-Display. I also updated my driver yesterday to the latest Avid approved version for our Quadro M5000.
  • Wed, Sep 6 2017 4:18 PM In reply to
    Marianna,
    Avid has now been able to reproduce the problem "easily" on a Windows 10 system. The bug is now being forwarded to the Avid engineers.
    [Case: 03275411]
    Thank you,
    Marc
  • Wed, Sep 6 2017 7:09 PM In reply to
    • Posts 9,264
    • Points 206,140
    Marc Cebrian:
    Marianna,
    [Case: 03275411]
    Thank you,
    Marc
    Marc
    Excellent - reading the case now and will immerse myself in the dialog between CS and engineering to ensure it gets fixed.
    AOL IM:  avidmarianna
    Skype: mariannamontague
  • Thu, Oct 26 2017 5:43 PM In reply to
    • josh calvi
    • Joined on Mon, Apr 12 2010
    • burlington, MA
    • Posts 49
    • Points 695
    I have not been able to reproduce this on 8.9.1 or 8.9.3 running on Win10.  How many people are running into this?  How often does it occur? Any insight would be very helpful.
    Josh Calvi | Senior Software Test Engineer | P&S Creative Professional [view my complete system specs]
  • Wed, Nov 1 2017 8:45 PM In reply to
    • JohnnyMeck
    • Joined on Mon, Feb 1 2010
    • Knoxville, TN
    • Posts 12
    • Points 140
    I upgraded to 8.9.3 yesterday on a Win 7 machine.  This runtime error is plauging me like wildfire.  I've tried a re-install of Avid (running as admin) and Boris Red 5.5.  The problem still persists.  It is mostly occuring when I working in color correction mode and come a cross a Boris Red transition.  I can turn off my track monitor, delete the FX, commence color correcting, then re-apply the transition and it will render fine.  If I break the render I am back to the runtime error.  I'm leaning toward an incompatibility in C++ versions.  Any suggestions?
    I running C++ version 12.0.4.0660.0.
    Avid 8.8.5 Symphony, Artist DNxIO, HP z840, 2.6Ghz Xeon E5-2640 8 core, 64GB RAM, Windows 7, NVIDIA Quadro M4000 [view my complete system specs]
  • Wed, Nov 1 2017 9:43 PM In reply to
    Have you tried Red 5.6?. It installed two  C++ versions here with a clean install on a W10 computer.  I hope to upgrade a W7 Pro to 8.9.3 over the weekend and test Red 5.6.
    Edit Add
    I updated to 8.9.3.   Red 5.6 was already installed.  Opened a project. On a timeline I added a Red 5.6 RT transition to each edit. Added CC to each clip.  Had no issues with no rendering.  Rendered all CC and Red effects and had no issues.
    On this computer I have I running I have 2 versions of C++ 2013 Redistributal 12.0.4.0660.  showing up as installed ((x86) and (x64))
    I also have 2 versions of C++ 2015 Redistributal 14.0.4.24215 ((x86) and (x64)) both with an install date that corresponds with my Red 5.5 to Red 5.6 upgrade.
  • Tue, Dec 19 2017 3:02 PM In reply to
    This conflict is now far worse with 8.9.4 and RED 5.6 - My crashes are more frequent and I get a clear memory error.
    I used to be able to tell if the application was going to crash before I break a render or apply an effect by Launching User Interface from the Effects Editor. Now when I click the box, I get the same old C++ error.
    My case is still open and I am working with Dennis at Avid.
    This is an update in case others are having the same issue still.
    Marc
    Here is the memory error I get:
    “There is not enough memory available to complete the operation. Please make more memory available by closing windows or quitting other applications, and try again.”
  • Sun, Jan 21 2018 8:55 PM In reply to
    I was able to confirm this problem persists with 2018.1 -- in fact, it might have gotten worse. While working with an unrendered effect, it crashed even though I didn't just break a render. It used to be that once you broke a render, if it did not crash, you could at least keep working. Instead, I jumped in and out of a submaster when the C++ error window popped up. Still working with Avid on our case.
  • Sun, Jan 21 2018 10:53 PM In reply to
    Marc Cebrian:
    Hi Marc, do you know if all the others with this issue have the DNxIO? (It occurred to me that I may have only tested in software mode as I had a totally different IO to the one you were having issues with)
    If operating in software mode does the issue still occur?
    If not then if you render the effect and switch back to hardware mode do you still get the issue.
  • Mon, Jan 22 2018 7:25 AM In reply to
    • carlgmi
    • Western Australia
    • Posts 754
    • Points 9,330
    I am getting a constant and repeatable crash on 8.10 trying to open an existing Boris FX or playing over a realtime unrendered FX. Windows 7.  We haven't bothered following it up, as I understand it Avid FX is eol so we have jumped and rebuilt all FX in AE...
    Too busy (nice problem to have) to really do anything more about this but I'll lend my voice to those noticing the problem.
    edit: no DNxIO
    MC8.10 Win 7 64 with Dongle, Dual 10 core Xeon, Quadro K4000, Adaptec RAID 5-8x3TB, External TB2 4x3TB, 64G RAM, BM Intensity Pro 4K. NewBlue Titler 6... [view my complete system specs]
    Vote 1 - Dongles.
    UME an old engine, now with 4K, mags and furry dice....
