Latest post Mon, Sep 4 2017 7:11 AM by Keith R. 11 replies.
Page 1 of 1 (12 items)
  • Sat, Aug 26 2017 11:38 AM
    • Keith R
    • Joined on Fri, Jun 8 2012
    • Posts 285
    • Points 3,365
    Media Composer First 8.9.1 Exception Can't create a directory
    Finally getting MCF to load the interface...
    Ther's an Yellow Triangle in the grey box
    Media Composer 8.9 1
    Exception Can't create a directory ,as one of the path below has insufficient permissions , path .E \ (username) \
    Looking back I have requested help with this and other isssues..
    to the best of my ability i followed up on all the usual response re-load your operating system re- load the programet etc
    this leads me to the conclusion the problem is in my chair ..  shorly MCF  can not be this bad .
    Shorly someone else has had this issue and knows fow to fix it..???
    Exception; Can't create a directory ,as one of the folders in the path below has insufficient permissions , path E: (username )\
    long time since I studied Windowc\Media Composer \ Path\Folder \ Protocols \Media Composer folder management ..
    So happens a close friend holds among other things a Masters in Computer Science\ Data Migration ..
    Reaction ..Good Luck
    i'm still stalled on Exception etc etc .. Avid Media Composer 8.9.1
    After about three weeks of trying shorly MCF  can not be this bad ...???
    Fred
  • Sat, Aug 26 2017 12:15 PM In reply to
    • Keith R
    • Posts 285
    • Points 3,365
    Re: Media Composer First 8.9.1 Exception Can't create a directory
    Here's another rush of blood to the head possibly the last one...
    Pinnacle Studio
    Liquid Edition
    Media Composer Versions V4 right up to including Current 8.9.xx
    NewBlue 4 XXXX
    Squeeze 10 Pro
    Premier Pro xxxx
    Edius (Trial Only)
    With honesty and sincerity I have never not succeeded , never expected to go back to studying Folder\File Management
    anything else will auto create/load necesssary folders  and find the requred Patrh/Paths...
    Exception Can't create a directory ,as one of the path below has insufficient permissions , path .E \ (username) \ .....
    Fred ...
  • Sat, Sep 2 2017 8:31 AM In reply to
    • Keith R
    • Posts 285
    • Points 3,365
    Is there a fix yet ... ?
  • Sat, Sep 2 2017 11:25 AM In reply to
    • Pilot
    • Tel Aviv
    • Posts 63
    • Points 735
    Hi Keith,
    if you do not connect any external USB devices to the your Toshiba laptop, then maybe your DVD has the letter (path) E:\ ?
    Have you some CD/DVD disk within DVD drive?
    Geeked
    p.s.
    maybe it's your SD Card have a letter "E" and write-protected, and for this reason MC|First can not create directory there.
    For MC|First:Win 7 Ultimate x64 SP1 / ASUS K54C/CPU B960 @ 2.20GHz/DDR3 8GB RAM/ Intel HD Graphics 2GB *For MC 8.4.4/Symphony option/Win 7 Ultimate x64... [view my complete system specs]
  • Sun, Sep 3 2017 12:00 PM In reply to
    • Keith R
    • Posts 285
    • Points 3,365
    Does a re-write help maybe  not understood.
    Does this help
    I recently downloaded a free version of Avid media Composer First .
    The installation stalls at the Interface and the Error Message in the box with the Yellow Triangle is :-
    Exception : Can't create a directory one of the folders in the path below has insufficient permissions  Path E\xxxx\
    The program freezes the computer (Laptop) at the error message .
    (Running Windows 10 home on 17.3" i7 good Laptop..
    i am reading the identical issue in several Professional Video Reviews ...
    There are posts on this issue back to July 2 no doubt this issue has been addressed..?
    Kind Regards
    for Keith R
  • Sun, Sep 3 2017 1:49 PM In reply to
    What is your E: drive? Is it an internal hard drive in the computer? Is it an external hard drive attached via a cable? Is it something else?
    Media Composer 8.9.3 w/Symphony option, HP Envy 17t-j100 Quad Edition laptop, Windows 10 Pro, Intel Core i7 2.4GHz, 16 GB RAM, nVidia GeForce GT 740M [view my complete system specs]
  • Sun, Sep 3 2017 2:33 PM In reply to
    • Keith R
    • Posts 285
    • Points 3,365
    camoscato:
    Hello Carl
    (1) there is no E: drive Toshiba I7 Laptop with internal (C) and (D) only
    Could we pls home in on that error message .
    All I can best offer is Media Composer and just about anything else I would rather not post here will auto find\Create\Install necessary Paths\Folders .
    Media Composer First will not , we have the Interface and then the Exception: ie:- error message I have posted so many times ...
    For
    Keith A
    Regards
  • Sun, Sep 3 2017 3:53 PM In reply to
    • Pilot
    • Tel Aviv
    • Posts 63
    • Points 735
    Keith R:
    Your laptop has a built-in internal SD card Reader, which the Windows assigns the letter E, if you insert there SD Card.
    To solve this "Exception Can't create a directory", insert any SD card with Write Protect Tab up (see picture above) and run MC|First.
    Geeked
    p.s.
    this video can help you :
    https://youtu.be/h4fvySwEPq0
  • Sun, Sep 3 2017 9:51 PM In reply to
    • Keith R
    • Posts 285
    • Points 3,365
    Geeked
    The subject Laptop is Satellite  P70 B there is no SSD
    Regard
    Fred
    For Keith A
  • Sun, Sep 3 2017 10:44 PM In reply to
    • DStone
    • Massachusetts
    • Posts 3,222
    • Points 41,690
    Pilot is not referring to a SSD. He's referring to the multi-card reader which takes SD/SDHC/SDXC cards. There may actually be a card in there that's write locked. In any case, the suggestion is to put in a SD card in write mode and then try again.
    DIY quad core I7-4790K, 16Gb, NVidia GTX 970 4GB, Win 10 Pro, MC 8.7, MC 7.x [view my complete system specs]
    Dave S.
  • Mon, Sep 4 2017 5:01 AM In reply to
    • Pilot
    • Tel Aviv
    • Posts 63
    • Points 735
    Keith R:
    For your model P70-B from User's Manual (page 70)
    https://www.manualslib.com/manual/1080078/Toshiba-C70-B.html?page=70#manual :
    p.s.
    thank you DStone :-)
  • Mon, Sep 4 2017 7:11 AM In reply to
    • Keith R
    • Posts 285
    • Points 3,365
    Quote
    Unquote
    Hello again
    Down the road purchase micro SDHD card 16Gb
    Computer Shop purchase Havic external card reader
    Run Media Composer First try again
    Now the Program has accepted the card as you suggested, one more small step ok ....
    The Interface is up and ready to go
    next problem ..
    The Program stalls and locks up the Computer ...
    Media Composer will install and run on this computer without this external drive ... ??
    in any case we now have the requested Path E: etc etc the Program still will not run
    now jumped all the hurdles up to the interface re-visiting the computer I suspect the next
    hurdle may be graphics maybe
    Just a note on the Toshiba P70 B again the is no internal card reader and no other program requires one
    Windows 10 Home on Toshiba P 70 B Toshiba MB Intel i7 472 HQ 16 GB Ram
    Graphics Intel HD 4600 (Toshiba)
    AMD Radion R9 M2 65 x (Radion)
    Storage 931 GB Avail (Toshiba)
    Two more flags - Is Windows 10 Home (current) and the Toshiba Graphics under spec for this creation maybe we should just quit ..
    Fred
    For Keith A
    Regards
