Latest post Thu, Sep 7 2017 4:04 AM by TMVC. 7 replies.
  • Wed, Aug 23 2017 1:37 AM
    • Evan2001
    • Joined on Mon, Feb 29 2016
    • Posts 10
    • Points 130
    GeForce GTX 1080 Ti & Avid MC
    wanted to see if people having any issues running Avid using the GeForce GTX 1080 Ti GPU cards?
    I do a good amount of 4k qork.
    -Evan
  • Fri, Aug 25 2017 7:02 AM In reply to
    • tommix
    • Joined on Tue, Oct 14 2008
    • Posts 182
    • Points 2,290
    Re: GeForce GTX 1080 Ti & Avid MC
    On PC MC references "GPU" which could mean the CPU GPU or a GPU like the GTX-1080. Anyway to tell if MC is using GTX-1080?
    MC claims "no additional hardware" -- but does it consider GPU boards as "hardware?"
    Curious what Nvidia driver you and others are using for GTX-1080.
  • Mon, Aug 28 2017 2:51 PM In reply to
    • EvanAA
    • Joined on Mon, Mar 7 2016
    • Posts 38
    • Points 495
    Is there anyone using this card?
    Or anyone from Avid?
    Thanks!
    Evan
  • Mon, Aug 28 2017 4:32 PM In reply to
    • ramz434
    • Long Island
    • Posts 173
    • Points 2,160
    I'm running that card and havent had any sort of issues right now. Not doing a ton of 4k, but its working well when I do.
    Occasionally Ill use GPU-Z to see how much of the card is being utlized, and I do see some usage, unfortuntaly I havent paid enough attention to break it down any more than that.
    I've got the 382.33 driver installed, and Im on MC 8.9 right now.
    **EDIT - I just realized you were asking about the TI variant of the card - Im only using the base GTX-1080 version
    - HP Z400/24gb ram/Windows 10/MC8.9.4/256gb Samsung SSD/ NVidia GTX 1080/HP ZR22 Monitors/ - Macbook Pro/16gb ram/OS 10.13/MC8.9.4/NVIDIA GeForce... [view my complete system specs]
  • Mon, Aug 28 2017 11:01 PM In reply to
    • cls105
    • los angeles
    • Posts 251
    • Points 3,400
    There are so many variables to what makes a good setup.
    I have a 1080 ti, running mc  8.9.1 on a diy intel 7820x setup.
    My 1080ti works flawlesly if I use blackmagic intensity (open io) as a video output
    However in the past i tired software only with 3 displays and i couldt get flawless performance on my 3rd  full screen playback monitor.
    2 computers. diy win10 7820x and 8700k that both work flawlessly with intensity cards. [view my complete system specs]
  • Tue, Aug 29 2017 3:10 AM In reply to
    • EvanAA
    • Posts 38
    • Points 495
    Right now I have a HP z840 with 2x K5200 cards. I'm thinking about replacing one with a GTX 1080Ti if it will work with the z840.
    This is not for Avid. I do more DaVinci Resolve. But for my work I need a system where I can use Resolve, Avid Symphony, and Premiere with not issues.
  • Wed, Aug 30 2017 3:00 AM In reply to
    • cls105
    • los angeles
    • Posts 251
    • Points 3,400
    OK.  I use all the software you mentioned (multiple monthly subscriptions) with no issues.
  • Thu, Sep 7 2017 4:04 AM In reply to
    • TMVC
    • Posts 81
    • Points 1,090
    Hi cls105,
    We're also considering this setup.  Just want to check again the playback issue you're having.  Usually we have two LCD monitors for editing and one broadcast monitor for playback and quality check.  Are you still encountering that playback problem on a monitor?
    Thanks in advance :)
    System 1: MC Adrenaline version 3.2 HP xw8200 3.4 dual xeon 3 gb RAM Huge Mediavault U320 3 x 200 gb RAID 3 1 x 2 TB Editshare system System... [view my complete system specs]
