I've successfully installed and running 8.9 on my macpro system.
Just one thing begins to happen too often - when i enter effect editor mode, avid - randomly crashes and asks me to send log to avid. It shows me the white outline of the effect editor window - and then crashes.
i work in older (8.8.5) project. In 8.8.x it works absolutely stable.
DJFio[DB]
Hmm can you send me a fw o the crah logs?
AOL IM: avidmarianna
Twitter: avidmarianna
Skype: mariannamontague
e-mailed a couple of generated logs
I've had the exact same thing on my MacBook Pro, but I put this on running it on 10.9.5 (not approved by Avid).
I finally got around by opening the fx editor from a clip that had no fx, resizing and moving its window, and then clicking on the fx'ed clip I wanted to adjust.
Would it be another of those "interface glitches" I noticed?
How about you pierreh?
Crash logs....
[quote user="DJFio[DB]"]
[/quote]
got them - working on it with support.
Happy to send some, which ones? Using Mac OS Console or the logs stored in Shared Users?
It seems that this issue was solved with 8.9.1 update.
I can not reproduce it anymore.
Thanks Marianna :) you are our lifesaver !
