Latest post Tue, Aug 8 2017 10:56 PM by AndrewAction. 28 replies.
Page 2 of 2 (29 items) < Previous 1 2
  • Thu, Aug 3 2017 9:11 PM In reply to
    • DStone
    • Massachusetts
    • Posts 3,236
    • Points 41,875
    Re: New Fusion 9 and Avid Connect
    OK, I reinstalled both Fusion and Fusion Connect, and it does in fact work!!!!! So you don't need the paid version, nor the I/O box.
    DIY quad core I7-4790K, 16Gb, NVidia GTX 970 4GB, Win 10 Pro, MC 8.7, MC 7.x [view my complete system specs]
    Dave S.
  • Thu, Aug 3 2017 10:40 PM In reply to
    DStone:
    It sure does! Tested with MC 8.9 Windows 10 new install of Fusion 9 and Fusion Connect 9.  Very happy!Thanks BlackMagic Yes
  • Sat, Aug 5 2017 12:28 PM In reply to
    • v-block
    • Posts 522
    • Points 6,605
    The web site seems to indicate that it shouldn't work with the free version. Does that add to the con Fusion, notwithstanding the fact that you have it working.
    https://www.blackmagicdesign.com/ae/products/fusion/compare
    Asus X58 Sabertooth motherboard, Core i7 920 CPU, Win 7 Pro 64bit, NVIDIA GeForce GT610, 12GB Corsair 3x4GB CMX-12GX3M3A1333C9 ram in triple channel config... [view my complete system specs]
  • Sat, Aug 5 2017 12:48 PM In reply to
    • Bruno M
    • Joined on Thu, Feb 11 2010
    • London, UK
    • Posts 373
    • Points 4,590
    Also, why does it say 'NEW'?
    The plugin's been around since Blackmagic aquired Fusion from Eyeon. Does this refer to the fact they think it won't work with the free version?
    As you say, confusion reigns!
    HP Z800,HP8600,HP8760WSonnetFusion RAID, Mediadock U320, Classic Nitris Mojo DXSymphony 5,6 & 8.5 JVC DTV1910 HD tube monitor, HP Dreamcolor, [view my complete system specs]
  • Sun, Aug 6 2017 11:23 AM In reply to
    • Bruno M
    • London, UK
    • Posts 373
    • Points 4,590
    Just tried it now and it behaves just like version 8 did. That is, Avid layers are exported, but clicking the 'Edit Effect' button doesn't start up Fusion. I can start Fusion and then load the comp manually. Exporting back to the Avid timeline works as expected.
    So, I'm not getting the complete success others have reported. Could this be an OS/MC version issue?
    I'm on Windows 7/64 with MC version 8.5.3
  • Sun, Aug 6 2017 11:40 AM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,465
    • Points 58,325
    Just as with Fusion 8 some folks have success with Connect. I could never get it to work but it works fine now that I've upgraded to the Studio version. In my opinion a necessary upgrade for support of OFX plugins anyway and now pretty inexpensive.
    Camera(s) PXW-X70, HDR-FX1, Hero 3+ | MC 8.9.3 | QT 7.7.9 | BCC 10.0.6 | Sapphire 11 | Mocha Pro 5.5.2 | Titler Pro 6 | Windows 10 Pro x64 | System: P6X58D... [view my complete system specs]
    Steve
    ______________________
    www.nelliedogstudios.com
  • Mon, Aug 7 2017 2:58 AM In reply to
    Bruno M:
    I just tried a clean new install of Fusion 9 and Fusion Connect 9 here on a W7 64 Pro SP1 with MC version 8.8.4 open. The AVX starts Fusion, loads the comp and renders back into the MC timeline.
    FWIW I do have BM Hardware (Intensity Pro 4k) installed on both the W10 and W7 machines. Maybe this makes a difference.
  • Mon, Aug 7 2017 7:29 AM In reply to
    • Bruno M
    • London, UK
    • Posts 373
    • Points 4,590
    AndrewAction:
    I have a Decklink 4K SDI card fitted, so I don't think it's a hardware issue.  The only thing that seems different is the version of MC I have installed (8.5.3).
    BTW the Blackmagic hardware seems to work well with Fusion 9, once you enable previews to the card from 'Preferences'.
  • Tue, Aug 8 2017 1:22 AM In reply to
    • DStone
    • Massachusetts
    • Posts 3,236
    • Points 41,875
    Hmmm, I also have a BlackMagic card installed...
    Dave S.
  • Tue, Aug 8 2017 3:50 AM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,465
    • Points 58,325
    Didn't we suspect quite some time ago that having the BM hardware seemed to be a factor in the free version launching from MC?
    Steve
  • Tue, Aug 8 2017 4:52 AM In reply to
    Combo of that and or the BM Desktop version perhaps.  FWIW I am on 10.4.3 with W7 and 10.9.3 with W10.
  • Tue, Aug 8 2017 4:05 PM In reply to
    • DStone
    • Massachusetts
    • Posts 3,236
    • Points 41,875
    BarkinMadd:
    Bruno has a BMD card, and it's still not working for him.
    Dave S.
  • Tue, Aug 8 2017 10:36 PM In reply to
    • Atomike
    • Nebraska
    • Posts 689
    • Points 10,495
    Bruno M:
    DStone:
    I just downloaded Fusion 9 (free). It does not install the Fusion Connect AVX into Avid. I am unable to test the Studio verion.
    The AVX plugin is a separate installer. Scroll down from where the main installer is located and you'll find it.
    Just downloaded Fusion 9, and there is no place on their site that has the AVX plugin.
    Not sure where you see it. If the plugin is available, I'd love an actual link, since there seems to be no such thing on BlackMagic's site.
    Thanks for any help anyone can provide!  Looking forward to trying this.
    EDIT: Finally found it.  It's actually on the support page, and not the normal download area where 99.99% of people will be looking.  Here's the actual link:
    https://www.blackmagicdesign.com/support/
    Media Composer 8.X (usually newest release), Avid matrix-recommended versions of both Nvidia driver and Quicktime, Matrox Mini MX02, Self-built machine... [view my complete system specs]
    I spend most of my time between New York and Los Angeles.  In Nebraska.
  • Tue, Aug 8 2017 10:56 PM In reply to
    Atomike:
    Try this (takes you to Blackmagic support page).  Select Family product  "Da Vinci Resolve/ Fusion Software". Look in "Latest downloads"   Third item down.
