Latest post Sat, Aug 12 2017 1:01 AM by DStone. 10 replies.
Page 1 of 1 (11 items)
  • Sat, Jul 22 2017 1:25 PM
    credi roll problem
    hello i
    i am going mad with credit roll
    first i use title pro 3, make the keyframing seems ok
    but don t work regualrly..
    i play it back and sometimes titles finish at half of their content
    sometiomes seems ok..i export and again they finish at that point
    the always finish let s say after the first screen of text
    i have tried to use title tool..but can t get roll..there is a button on bottom saying roll...but i click on it and nothing happem
    some help to make roll credit??
    thanks a lot
    CPU I7 2600k 3.4ghz Ram 32gb Ssd 256gb GPU Nvidia GTX760 Win 10 Avid Media 8.4 [view my complete system specs]
  • Sat, Jul 22 2017 3:14 PM In reply to
    • Fazz Powell
    • Joined on Sun, Dec 3 2006
    • Annapolis, MD
    • Posts 333
    • Points 4,630
    Re: credi roll problem
    Do you have AVIDFX/Boris Red? I'd use that.
    MC 8.8.5 w/Symphony option. NitrisDX, HP Z800 Dual 2.67Ghz, 96GB Ram, Nvidia M4000, BCC10, Sapphire10, TitlePro5, ProTools 10.5,Terrablock 24XS Multi-Write... [view my complete system specs]
  • Sat, Jul 22 2017 3:24 PM In reply to
    stefanocps:
    After you click that button, you then add text (and/or objects) to the title. By entering more text/lines, the page gets longer and longer and a scroll bar will appear to the side. Save and close the title. It will show up in the source monitor. Splice it into the sequence. Speed is determined by the duration of the rolling title (which you can trim). Seeing it play requires a render, though.
  • Sat, Jul 22 2017 6:05 PM In reply to
    ok..i had the tile with text already in it and i wanted to apply roll after
    now the title roll but don t like...don t understand the relation to speed an dduration....actually i don t see it
    i see a very slow roll that will show only a smal part of all the text
    also having to render all the time it is a real pain, and even after render it doesn t work properly
    not a good tool this...
    don t know what to do
  • Sat, Jul 22 2017 6:11 PM In reply to
    Fazz Powell:
    yes i find i have an old version..don t know how to use that though! :)
  • Sat, Jul 22 2017 6:31 PM In reply to
    • Fazz Powell
    • Annapolis, MD
    • Posts 333
    • Points 4,630
    Take your credits out of Word and paste it into Boris text tool, make it the font and point size you want and then go to Controls and create a linear move on the Y axis. This is a newer version tutorial... https://web.borisfx.com/helpdocs/?page_id=7969
  • Fri, Aug 11 2017 12:29 PM In reply to
    hello i have create a rolling title with red effect but it has a strange behaviour
    at start and at then it slightly slow down the speed
    so ita start..then in few second speed up to the speed he will keep for the whole lenght
    until it arrive at last few seconds where again it slightly slow down
    why that?
    also i tried to export it
    during the scroll some part are not smooth
    thanks
    Fazz Powell:
  • Fri, Aug 11 2017 7:36 PM In reply to
    stefanocps:
    Sounds like your keyframes are set to ease in/out. I haven't used Red, so I'm sorry but I don't know how to change them. My first guess would be right-clicking on them, but hopefully someone who knows for sure will answer.
    Media Composer 2018.7 w/Symphony/SS/PF options, HP Envy 17t-j100 Quad Edition laptop, Windows 10 Pro, Intel Core i7 2.4GHz, 16 GB RAM, nVidia GeForce GT... [view my complete system specs]
  • Fri, Aug 11 2017 9:13 PM In reply to
    • DStone
    • Massachusetts
    • Posts 3,381
    • Points 43,620
    If you're using the title tool, the scrolling is based on the duration of the title (you can stretch or compress it to the right length to control the speed) as well as keyframes (which you can edit to control the ease-in and ease-out, among other things).
    If you're using Red, then in the Title container, set the type to Roll (or Crawl) and click on the Maintain Speed checkbox. Then set your position keyframes from start and end (note: if you set the position keyframes and then select Maintain Speed, the positions will change from where you set them).
    DIY quad core I7-4790K, 16Gb, NVidia GTX 970 4GB, Win 10 Pro, MC(generally the latest or the one just before), MC 7.x [view my complete system specs]
    Dave S.
  • Fri, Aug 11 2017 9:20 PM In reply to
    Hi
    I use red
    Where is the mantain speed checkbox?
  • Sat, Aug 12 2017 1:01 AM In reply to
    • DStone
    • Massachusetts
    • Posts 3,381
    • Points 43,620
    Select the Title Container you added to the timeline. In the upper left you will see the tabs for Controls, Library Browser, etc. Click on Controls. Click on the Animation tab in the Controls box. Select either Roll or Crawl (depending on what you're doing) for the animation type. You will now see the animation controls, including the Maintain Speed checkbox.
    Dave S.
