Latest post Sun, Jul 16 2017 6:19 AM by camoscato. 6 replies.
Page 1 of 1 (7 items)
  • Thu, Jul 13 2017 5:38 AM
    newscutter exports not working in other NLE
    i use newscutter at work, and Premiere Pro at home. i export a sequence using Quicktime > same as source to get the best possible export, and lo and behold my home pc won't read the file. The PCs at work running premiere read the file just fine and dandy. can someone point me to a codec pack i can download so i can read the files at home as well? thanks.
    an example file:
    https://1drv.ms/v/s!Auu8McGAPINMgRQW559A4UTgXha0
    medie info:
    General
    Complete name                            : H:\Temp\Video Mixdown AGAIN 2.mov
    Format                                   : MPEG-4
    Commercial name                          : AVC-Intra
    Format profile                           : QuickTime
    Codec ID                                 : qt   2005.03 (qt  )
    File size                                : 2.54 GiB
    Duration                                 : 6 min 20 s
    Overall bit rate                         : 57.3 Mb/s
    Encoded date                             : UTC 2017-07-07 03:40:16
    Tagged date                              : UTC 2017-07-07 03:41:27
    Writing library                          : Apple QuickTime
    Video
    Format                                   : AVC
    Format/Info                              : Advanced Video Codec
    Format profile                           : High 10 Intra@L4
    Format settings, CABAC                   : Yes
    Format settings, GOP                     : N=1
    Codec ID                                 : AVin
    Codec ID/Info                            : Advanced Video Coding
    Bit rate mode                            : Constant
    Bit rate                                 : 56.1 Mb/s
    Width                                    : 1 920 pixels
    Original width                           : 1 440 pixels
    Height                                   : 1 080 pixels
    Display aspect ratio                     : 16:9
    Original display aspect ratio            : 1.000
    Frame rate mode                          : Constant
    Frame rate                               : 29.970 (29970/1000) FPS
    Original frame rate                      : 29.970 (30000/1001) FPS
    Standard                                 : Component
    Color space                              : YUV
    Chroma subsampling                       : 4:2:0
    Bit depth                                : 10 bits
    Scan type                                : MBAFF
    Bits/(Pixel*Frame)                       : 0.902
    Stream size                              : 2.47 GiB (97%)
    Language                                 : English
    Color range                              : Full
    Color primaries                          : BT.709
    Transfer characteristics                 : BT.709
    Matrix coefficients                      : BT.709
    Audio
    Format                                   : PCM
    Format settings, Endianness              : Little
    Format settings, Sign                    : Signed
    Codec ID                                 : sowt
    Bit rate                                 : 1 536 kb/s
    Channel(s)                               : 2 channels
    Channel positions                        : Front: L R
    Sampling rate                            : 48.0 kHz
    Bit depth                                : 16 bits
    Stream size                              : 69.7 MiB (3%)
    Language                                 : English
    Other
    Type                                     : Time code
    Format                                   : QuickTime TC
    Time code of first frame                 : 01:00:00;00
    Time code, striped                       : Yes
    Language                                 : English
    Encoded date                             : UTC 2017-07-07 03:41:22
  • Thu, Jul 13 2017 6:18 AM In reply to
    Re: newscutter exports not working in other NLE
    It looks like you're exporting files using the AVC-Intra codec. Do you have that codec on your home machine?
    Media Composer 2018.4 w/Symphony option, HP Envy 17t-j100 Quad Edition laptop, Windows 10 Pro, Intel Core i7 2.4GHz, 16 GB RAM, nVidia GeForce GT 740M [view my complete system specs]
  • Thu, Jul 13 2017 8:39 AM In reply to
    could not find anywhere to get the codec. i downloaded the p2 card reader drivers, but it didnt seem to not do anything. but i can tell you i can't play the files on the machine anyhow. like if i double click on it, quick time and windows media player both do nothing. so yeah.
  • Thu, Jul 13 2017 9:17 AM In reply to
    What about exporting from Newscutter using a different codec? If you choose custom instead of same as source you should be able to choose a codec you can also use on your home machine (h264, for example).
  • Thu, Jul 13 2017 10:52 PM In reply to
    I could, but all the other export options look.... well, not good. I compared about 12 different export versions and none of them held up to the avc-intra. I even did an h.264 at 50 Mbps, and it still had artifacts and color degradation. Is there just simply a zip file somewhere that I can download the avc-intra codec to install?
  • Sun, Jul 16 2017 3:44 AM In reply to
    ok i resolved the issue. i had to install the Avid Codecs PE on my home pc, and everything works now. yay.
  • Sun, Jul 16 2017 6:19 AM In reply to
    Glad you figured it out, and thanks for posting the solution.
