Latest post Wed, Jul 12 2017 7:49 PM by Nathan Grout. 0 replies.
Page 1 of 1 (1 items)
  • Wed, Jul 12 2017 7:49 PM
    • Nathan Grout
    • Joined on Fri, Aug 26 2011
    • Los Angeles Area, CA
    • Posts 9
    • Points 125
    Clip-Based LUTs Break Multi-Groups
    Last year I was unable to add script marks to groups that contained clips with LUTs applied via source settings.  Haven't checked to see if this is still an issue.
    Now I've tried again to use clip-based LUTs.  I'm running Media Composer 8.8.3 on OS X 10.11.6.  This time, when I load a multi-group into the source monitor and that multi-group has clips with LUTs, I can't switch between cameras (except for cameras within the first sub-group, which I can switch normally). If I matchback to the sub-groups, I can switch between cameras.  If I cut the multi-group into the sequence, I can switch cameras, but if I try to matchback from the sequence, it takes me to the group, not the multi-group.
    Clear as mud?
