Latest post Sat, Aug 19 2017 2:55 AM by Keith R. 50 replies.
Page 2 of 4 (51 items) < Previous 1 2 3 4 Next >
  • Sun, Jul 30 2017 10:35 AM In reply to
    • Keith R
    • Joined on Fri, Jun 8 2012
    • Posts 244
    • Points 2,875
    Re: Application Manager won't initialize
    I still have this issue have you found a fix yet ...RegardsSad
  • Wed, Aug 2 2017 7:35 PM In reply to
    • RalphC
    • Joined on Wed, Sep 2 2015
    • Posts 1,165
    • Points 12,655
    • Avid Customer Advocate
      Avid Customer Service
      Avid Employee
    Please tell me the result of the following links:
    There are several ports that are used by Application Manager to retrieve information and licensing. You can check accessibility by clicking the following links:
    https://license.avid.com:3443/ping.aspx
    https://license.avid.com:443/ping.aspx
    http://update.avid.com:96/ping.asp
    If you are able to successfully reach these ports, the link will return a page that says "ACK."
    If not successfully, it will return "This webpage is not available."
    Ports 3443 and 443 are used to activate a software license over the internet.
    Port 96 is important in order to see software Updates and Feeds within Application Manager.
    RalphC
    This is a test. Media Composer 8.8 w/Symphony option, HP Envy 17t-j100 Quad Edition laptop, Windows 10 Pro, Intel Core i7 2.4GHz, 16 GB RAM, nVidia GeForce... [view my complete system specs]
  • Wed, Aug 2 2017 9:07 PM In reply to
    Hi There
    I have tried the three links and received the ACK on screen for each.
    The issue with Application Manager is the same, Continues to initialise and am unable to login with the app eventually failing to connect to the Avid server.
    Since the last time I posted I have given up trying to fix this as its gone on too long.
    S
    RalphC:
    Normal 0 false false false EN-US X-NONE X-NONE /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman","serif";}
    RalphC
    iMAC 3.2 GHz Intel i3 12gb 1333 MHz DDR3 MAC OS X Version 10.12.5 Macbook Pro 2.5 GHz Intel Core i5 8 GB 1600 MHz DDR3 Intel HD Graphics 4000 1536... [view my complete system specs]
    Simon McGuire
    Broadcast & Film Editor.
    Avid Certified User.
  • Wed, Aug 2 2017 9:21 PM In reply to
    • RalphC
    • Posts 1,165
    • Points 12,655
      Avid Employee
    I encountered this on my laptop yesterday running Windows 7.
    • 1. Select preferences tab then "Clear Cache files"
    • 2. Let it do it sync.
    • 3. Go back to preferences tab and Restart AppMan Help. It continue to initialize then I open Windows "task manager" end both AppMan helper and AppMan
    •  Launch AppMan and I was able to sign in. I'm not saying it will work for you but it's worth trying.
    RalphC
  • Thu, Aug 3 2017 8:54 AM In reply to
    • Keith R
    • Posts 244
    • Points 2,875
    Hello Ralph
    Did all that :-
    Application Manager won't initailize ...
    Thi issue now is to keep posting or acccept that there is issues with Application Manager in MCF ...
    Regards
    Keith
  • Thu, Aug 3 2017 2:25 PM In reply to
    Hi Keith,
       We're really sorry for the hassle with this. This has not been the normal experience for people and I would love to get this cleared up for you.
    Within the "Preferences" area of App Manager, could you copy and paste information from the "Activity History" please?
    Maybe we can get a clue from there.
    Please let me know.
    ~Keith
    - MacPro, 2.66 GHz, 14G RAM; OS 10.8.4; MC DX Nitris; ISIS 4.5 - MacBook Pro, 2.3 GHz i7, 8G RAM, ISIS 4.5 - z800 Xeon 2.93Ghz, 12G RAM, Win 7, DX Nitris... [view my complete system specs]
  • Fri, Aug 4 2017 8:33 AM In reply to
    • Keith R
    • Posts 244
    • Points 2,875
    Hi Keith,
    Hello Gerard
    I'm sorry I really do not understand, there are numerous posts on this forum directly or indirectly related to this issue ie:-
     "Re Application Manager won't initialize"
    I'm with Media Composer 8.8.5 and no issues and happy with it MC xxx since before 2012  tried downloading and testing MCF on a Core i7 Toshiba Laptop and MCF is on the Laptop but the Application Manager won't initialize
    Thank you, however I have removed MCF from the Laptop and maybe attempt again at some later date ..
    Regards
    Keith
  • Fri, Aug 4 2017 12:41 PM In reply to
    Please let us know when you are able to installed Media Composer | First.
    Thank you,
    ~Keith
  • Fri, Aug 4 2017 2:19 PM In reply to
    • Keith R
    • Posts 244
    • Points 2,875
    Hello Keith
    Not planning on re-installing it again right now -
    ... I have been  a regular forum folllower for many years -
    and will keep an eye on the related  postsi - there is currently about twelve .
    (Application Manager won't initialize) - maybe it is a Windows issue.
    On the bright side MC 8.8.5 is fine on my main machine so happy to leave it
    at that  ... thanks again for now...
    Regards
    Keith R
  • Fri, Aug 11 2017 9:55 AM In reply to
    • Keith R
    • Posts 244
    • Points 2,875
    Hello Simon -
    Has this been resolved .. ?
    I had the same issue on a Toshiba i7 Laptop and W10 .
    I eventually gave up - but still interested if I can find
    a fix - all  I coild get was the same blank Application Manager screen
    you have illustrated ..
    Regards
    Keith R
  • Fri, Aug 11 2017 1:37 PM In reply to
    • RalphC
    • Posts 1,165
    • Points 12,655
      Avid Employee
    Keith R:
    Hello Simon -
    Regards
    Keith R
    Have you tried the newest AppMan released 17.7
    RalphC
  • Fri, Aug 11 2017 9:51 PM In reply to
    • ck123
    • Joined on Wed, Jul 17 2013
    • Posts 109
    • Points 1,370
    RalphC:
    Keith R:
    Hello Simon -
    Regards
    Keith R
    RalphC
    I asked support for AppMan 17.7 and they told me unequivocally it doesn't exist.
    Charles
    HP Z400, z220, and z420 workstations with 8GB of RAM and nVidia Quadro 2000 graphics cards. Windows 7 64-bit SP1. ISIS 5000 4.2. [view my complete system specs]
  • Sun, Aug 13 2017 8:34 AM In reply to
    • Pilot
    • Posts 38
    • Points 510
    ck123:
    Charles
    I again got this error with "Initializing...", and after it even more strange error in AppMan window: "Platform Log-In Denied. Application: Media Composer | First out of date. Please update immediately."
    This time, only clearing Windows Temp Folder helped.
    Simon McGuire:
    Very frustrating... the avid App manager is not something I would be happy with as a long time avid user (since 1995). I realise that the company has to protect itself from pirating and such but this does put you off.
    I still do not understand why so to complicate this free program destined to attract new users to Avid?
    Sony HDR-AX2000E /Media Composer 8.4.4 /Symphony option /Windows 7 Ultimate SP1 /i7-5820K CPU /16GB RAM /X99-UD4-CF MoBo /GTX 750 Ti 2GB***MC|First 8.9... [view my complete system specs]
  • Mon, Aug 14 2017 2:47 PM In reply to
    • Posts 8,429
    • Points 110,065
    Pilot
    Who told you AppMan 17.7 doesn exist????   it certainly does but you need 17.6 installed before upgrading to it.
    Fixed in Application Manager v17.7
    Bug Number: AMPT-5773. In some instances, Application Manager might have installed MS C++ 2013 Redistributable (x64) software even if it was already installed.
    Bug Number: AMPT-5724. In some cases, Application Manager was not properly restored after waking your system from sleeping mode.
    Bug Number: AMPT-5718. (Mac) Application Manager CPU usage was high.
    Bug Number: AMPT-5633. Application Manager might have logged you out when in offline mode. You should now be able to run the application when you are offline instead of receiving a “Problem logging into account” error.
    what do you have spoecifically that you are installing MC | First one?  OS, Computer type, RAM, cards etc...
    AOL IM:  avidmarianna
    Skype: mariannamontague
  • Mon, Aug 14 2017 2:57 PM In reply to
    • ck123
    • Posts 109
    • Points 1,370
    Current Response:
    Entered on: 8/10/2017 11:36 PM  Entered by: Jeni Nacario
    Hi Charles,
    I checked with IT and they told me that the only version that we have at the moment for the Application Manager
    is version 17.5.1. The Application Manager 17.7 is still in the works and has yet to be released, though the release
    date is not definite yet. Regards, Jeni | Avid Video Registration
