Latest post Sat, Jan 27 2018 2:11 PM by mark.burton. 36 replies.
Page 1 of 3 (37 items) 1 2 3 Next >
  • Tue, Jul 4 2017 12:15 PM
    • Nate Orloff
    • Joined on Tue, Aug 21 2012
    • Los Angeles, CA
    • Posts 11
    • Points 135
    Unusual Trim Mode Crashes (5+ a day) with 8.8.3 & 8.8.4
    Long time Media Composer user and I haven't quite seen anything this perplexing. We've swapped systems, Blackmagic devices, upgraded to 8.8.4, even upgraded macOS to 10.11.6 and my editor is crashing constantly in Trim Mode. We have DNxHD 115 files in multicam clips (A/B only) streaming from a Nexus. My identically matched system doesn't crash and I arguably use Avid "harder" than he does, we're not pushing the system to the limit or anything. Random roller trims seem to cause him to crash. It'll crash when he previews things. And like I said, we've swapepd systems and it's still happening.
    Has anyone experianced this before? We're desperate for solutions! Next I'm goin gto start downgrading .1 release by .1 release to see if it solves his issue.
    I have crash logs I can email to someone if that helps.
    Thanks!
    Nate
  • Tue, Jul 4 2017 1:20 PM In reply to
    Re: Unusual Trim Mode Crashes (5+ a day) with 8.8.3 & 8.8.4
    Have you tried a newly created user setting (before the editor copies all their default settings back in?)
  • Tue, Jul 4 2017 1:30 PM In reply to
    • Nate Orloff
    • Los Angeles, CA
    • Posts 11
    • Points 135
    One of the first things we tried – I rebuilt their settings and there wasn't much going on. Every setting I changed I couldn't imagine impacting playback on trim mode.
  • Tue, Jul 4 2017 2:48 PM In reply to
    • jef
    • Joined on Sun, Feb 26 2006
    • Maryland
    • Posts 3,405
    • Points 41,095
    Have you checked to see if Fast Scrub is off?  This has been a problem in the past.  Don't really know if it is in 8.8.3 and on.
    Jef
    Jef Huey
  • Tue, Jul 4 2017 2:51 PM In reply to
    • Nate Orloff
    • Los Angeles, CA
    • Posts 11
    • Points 135
    Just tried that and will report back. Not ideal, timeline use is a little chunky with it off. Fast Scrub is supposed to work!
  • Tue, Jul 4 2017 4:57 PM In reply to
    • Nate Orloff
    • Los Angeles, CA
    • Posts 11
    • Points 135
    Fast Scrub was off, still just crashed. This time in PLAYBACK. Not trim mode. Going to try revertign to 8.8.2 for fun.
  • Wed, Jul 5 2017 8:47 AM In reply to
    • oze
    • New Zealand
    • Posts 574
    • Points 6,790
    I've also have this trimming/scrubbing problem. I also get regular crashes when working inside nested clips.
    2017 27" iMac i7 4.2, 2TB PCI memory, 64GB RAM, OS 10.13.6, MC 2018.10 [view my complete system specs]
  • Thu, Jul 6 2017 12:21 PM In reply to
    • mark.burton
    • London, UK
    • Posts 912
    • Points 11,110
    OK we are now seeing Trim mode crashes too with 8.8.4 on macOS 10.12.5, DNxIO (driver 10.9.3). This is going to be a huge problem.
    Nate - did you go back to 8.8.2 and have any luck?
    I'm also wondering if there is any relationship with Auto Save settings, the crashes seem to be happening right at the limit of the save period, almost as if it tries to force save in the middle of a trim.
    Has anyone tried 8.8.5 yet?
    Mark
  • Thu, Jul 6 2017 12:56 PM In reply to
    • Nate Orloff
    • Los Angeles, CA
    • Posts 11
    • Points 135
    So I’ve reverted to 10.9.1 as it’s the latest Avid-approved and any bug reporting with 10.9.3 would be invalid.
    I’ve reverted the editor to 8.7.2 and no crashes yet!
    I think it’s all about caps lock. Our reseller brought this up and it is a difffernce between my editor and me. He tends to leave it on, I have the setting on that it runs off when changing sequences or something.
    I’ve now tried to keep caps lock on as a way to test crashes and I’ve crashed once, stalled once (quit QuickTime OPserver).
    According to the reseller, caps lock is a feature that has been periodically buggy in various versions since introduced. It can cause memory leaks (which we’ve had).
    I’ve heard weird things about grouping in 8.8.5 from another show so I’ve avoided it.
    Thanks!
  • Thu, Jul 6 2017 3:40 PM In reply to
    • Nate Orloff
    • Los Angeles, CA
    • Posts 11
    • Points 135
    BTW, we absolutely thought originally it had to do with auto save because the crashes were always at the worst distance from the last save. Annoying, to say the least.
  • Thu, Jul 6 2017 3:44 PM In reply to
    • mark.burton
    • London, UK
    • Posts 912
    • Points 11,110
    I've rebuild user settings and haven't had a crash in a few hours, but I'm also not feeling like we've found the issue to be honest.
    Did you ever use 8.8.2? I came from 8.4 so I've no real experience with these later versions. Would like to avoid switching the OS back if at all possible.
  • Sun, Jul 9 2017 10:52 AM In reply to
    • mark.burton
    • London, UK
    • Posts 912
    • Points 11,110
    Since removing all user settings and rebuilding, we have not had any more crashes (yet!).
  • Tue, Jul 11 2017 8:08 AM In reply to
    • mark.burton
    • London, UK
    • Posts 912
    • Points 11,110
    Wishful thinking, crashes came back yesterday. Same story, trim + crash.
  • Thu, Jul 13 2017 11:02 AM In reply to
    • mark.burton
    • London, UK
    • Posts 912
    • Points 11,110
    Moved to 8.7.2 and still getting same thing. Now looking at changing out the Wacom and drivers. Seems to affect all versions of MC, have so far had identical trim crash on 8.7.2, 8.8.4 and 8.8.5.
  • Thu, Jul 13 2017 4:51 PM In reply to
    • Nate Orloff
    • Los Angeles, CA
    • Posts 11
    • Points 135
    The Wacom bit is interesting. We were having an issue just now with our Kensington mouse causing a system hicckup.
    Yeah, 8.7.2 totally fixed the non-repairable crashes. I think he's crashed once a day or every other, but on 8.7.2 they've all been savable when going to Activity Monitor and quitting QT_OPServer or whatever. The 8.8.3+ crashes, there was no going back.
    It's a really frustrating because it's just not repeatble enough yet happen constanly, hard to nail down what's cuaisng this. I think it's memory leak of some kind.
    I knwo you had Trash Cans & we're on Towers... what hardware boxes are you guys on? Avid Artist DNxIO by Blackmagic
