Latest post Wed, Jul 26 2017 9:10 PM by Bill Harris. 3 replies.
  • Mon, Jul 3 2017 4:07 PM
    • Bill Harris
    • Joined on Mon, Mar 17 2014
    • Nevada City, CA
    • Posts 5
    • Points 55
    XDCAM AMA Plugin error
    Hi all,
    I'm hoping an Avid employee monitoring this forum might be able to tell me what the assertion referenced in this error message is checking for?
    "* Exception: FATAL_ERROR, msg:Assertion failed: FALSE, file:..\..\src\msm\MPEG2GOPInfo.cpp, line:69."
    Thank you in anticipation!!
  • Tue, Jul 4 2017 4:10 PM In reply to
    • RalphC
    • Joined on Wed, Sep 2 2015
    • Posts 1,833
    • Points 20,230
    • Avid Customer Advocate
      Avid Customer Service
      Avid Employee
    Re: XDCAM AMA Plugin error
    GrassValleyAMA:
    Hi all,
    Please complete your profile.Thanks!
    RalphC
  • Tue, Jul 25 2017 6:44 PM In reply to
    • mikedeluca
    • Joined on Tue, Feb 28 2017
    • Posts 5
    • Points 55
    Here it is: the calculated GOP size is less than or equal to zero.
    AvBigByteCount_t thisGopOffset = pMapper->GetIndexOffset(firstSample*2);
    AvBigByteCount_t nextGopOffset = pMapper->GetIndexOffset(nextIFrame*2);
    AvBigByteCount_t GopSize =  nextGopOffset - thisGopOffset;
    if (GopSize <= 0)  // something is wrong
           CoreEvent(DECODE_AND_FTC, 6, "CreateMPEG2GOPInfoFromMapper: bad GopSize, firstSample %d, offset %d, nextIFrame %d, offset %d, SampleNumDisplayOrder %d",
                  (int)firstSample, (int)thisGopOffset, (int)nextIFrame, (int)nextGopOffset, SampleNumDisplayOrder);
           FtlAssertNotReached(); // LINE 69
    The MC application uses a combination of GetSampleProperties(), GetNumberOfSamples(), GetSamplePosition() and GetSampleSize() from the AMA plugin to determine the GOP size; you should verify that the values returned by the AMA plug-in for these make sense.
  • Wed, Jul 26 2017 9:10 PM In reply to
    • Bill Harris
    • Nevada City, CA
    • Posts 5
    • Points 55
    Thank you. We'll give this a shot........
    -Bill Harris
