Latest post Sun, Jun 25 2017 12:37 AM by BarkinMadd. 19 replies.
Page 2 of 2 (20 items) < Previous 1 2
  • Sat, Jun 24 2017 9:49 AM In reply to
    • Lukas Boeck
    • Joined on Fri, Jul 31 2015
    • Austria
    • Posts 434
    • Points 5,075
    Re: ama relink and transcode
    i wouldn't buy used tape drives.
    the magnetic head wars out with time.
    MC 8.4.4 Cusom bulid Supermicro X9SRL-F, 32 Gig Ram, 3ware 9750 6x6TB Seagate EC Drives, LSI 9207 + LTO-6, Mojo DX, Artist Color, Flanders CM240, GTX 1070... [view my complete system specs]
  • Sat, Jun 24 2017 9:55 AM In reply to
    yes for sure
     i have seen cheap tape not used though
    like this
    https://www.amazon.it/Tandberg-Data-8781-RDX-tape-drive/dp/B00QND1CIC/ref=sr_1_18?ie=UTF8&qid=1498298423&sr=8-18&keywords=tape+drives
    CPU I7 2600k 3.4ghz Ram 32gb Ssd 256gb GPU Nvidia GTX760 Win 10 Avid Media 8.4 [view my complete system specs]
  • Sat, Jun 24 2017 10:06 AM In reply to
    • Lukas Boeck
    • Austria
    • Posts 434
    • Points 5,075
    tape is cheap, the necessary drives to read the tapes aren't.
    you'd bee looking at LTO-5, 6 or 7
  • Sat, Jun 24 2017 1:02 PM In reply to
    • DStone
    • Massachusetts
    • Posts 3,364
    • Points 43,425
    Lukas Boeck:
    RDX is the reverse. The drive is cheap. The tape is expensive (about $100 - $150 per terabyte).
    DIY quad core I7-4790K, 16Gb, NVidia GTX 970 4GB, Win 10 Pro, MC(generally the latest or the one just before), MC 7.x [view my complete system specs]
    Dave S.
  • Sun, Jun 25 2017 12:37 AM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,543
    • Points 59,395
    stefanocps:
    i think i find the solution for my version from an old post
    this is the workflow
    Edit your transcoded clips into your timeline and finish up your edit.
    To relink back to your original AMA clips, close the bin with your transcoded clips, open the bin with the AMA clips and select all those clips. Open the bin with your sequence and select your sequence as well (holding the control key as you select to sequence so that it is included in the whole selection).
    At this point, the only files selected should be your original AMA clips and your sequence.
    Right-click on the sequence and select 'Relink...'
    In the Relink dialog, select the option that reads as 'Selected Items in ALL open bins' and then make sure the option to create a new sequence is ticked. The other default options should suffice.
    Click OK and a new sequence should appear. It should look exactly like your original sequence but will have each clip replaced by its AMA counterpart.
    Now you can do a video and audio mixdown at a much higher quality and put these in another sequence (the mixdown will let you then do a SAS or QT Ref export to an encoding package like Squeeze, Adobe Media Encoder or TMPGenc for transcoding to a delivery format).
    It actually took much longer to write this description that it will take you to execute these steps.
    i tried in the test sequence and work..i have to try in the big one
    yhe only problem is that i have all the ama linked files in several differnt bins and i don t know how to select them all together
    This sounds so familiar...
    Not sure how best to select all the linked clips across multiple bins - anyone?
    Camera(s) PXW-X70, HDR-FX1, Hero 6 Black | MC 18.7 | QT 7.7.9 | BCC 11 | Sapphire 11 | Mocha Pro 5.6 | Titler Pro 6 | Windows 10 Pro x64 | System: P6X58D... [view my complete system specs]
    Steve
    ______________________
    www.nelliedogstudios.com
