Latest post Wed, Jun 21 2017 8:25 AM by BabyTV. 0 replies.
Page 1 of 1 (1 items)
  • Wed, Jun 21 2017 8:25 AM
    • BabyTV
    • Joined on Wed, Jun 7 2017
    • Posts 0
    • Points 0
    Export audio mono file
    i discovered a strange and ennoying issue that is looking like a bug. when you exporting straight from the bin an audio MONO master clip using MONO Wav preset you are getting a file that is completely identical in its level to the original file in Avid. HOWEVER if you are making a sequence and editing there the same audio master MONO clip and exporting it using the same MONO preset -  at the end you will get a file with reduced volume about 3db. By the way, with stereo master clips that are edited on sequence and with stereo audio presets (export) there is no such problem. i tried also to export MONO from sequence using "same as source quick time" preset - same result, the audio file was reduced. please explain\help.
    this is major issue for us since we are sending these audio files as MONO for broadcast. please reply as soon as possible
    this is happening in all 3 stations we have: versions 8.8.1 ,  8.8.2,  8.8.3
    thank you
