Latest post Mon, Jun 19 2017 3:12 PM by Pat Horridge. 3 replies.
  • Fri, Jun 16 2017 6:43 PM
    • bushfilm
    • Baton Rouge, LA
    • Posts 441
    • Points 6,095
    Proble with media offline.
    Hi all, I seem to remember a fairly easy way to point Avid to a new hard drive with my media on it. You went into the "Avid Media Folder" and deleted a single little file, then on re-start, Avid would find the media on the new drive. Anyone able to help me here? I moved media off a hard-drive in order to re-format it, but when I moved it back, it was in a folder (John's Backup), let's say, and now the project timeline shows "media offline". I know there is a simple fix for this, but can't seem to remember it. Have TMB syndrome (Too Many Birthdays). Help?  Thanks in advance.
  • Fri, Jun 16 2017 7:15 PM In reply to
    • RalphC
    • Joined on Wed, Sep 2 2015
    • Posts 1,064
    • Points 11,475
    • Avid Customer Advocate
      Avid Customer Service
      Avid Employee
    Re: Proble with media offline.
    bushfilm:
    I hope this FAQ does the trick.
    RalphC
    This is a test. Media Composer 8.8 w/Symphony option, HP Envy 17t-j100 Quad Edition laptop, Windows 10 Pro, Intel Core i7 2.4GHz, 16 GB RAM, nVidia GeForce... [view my complete system specs]
  • Mon, Jun 19 2017 2:57 PM In reply to
    • Guy Malou
    • Joined on Fri, Sep 26 2008
    • Posts 172
    • Points 2,230
    You can delete the *.pmr and *.mdb files in each folder.
    You most likely did it like this BUT...
    make sure that
    1 - the folders with the avid media in are named numerically (1, 2, 3, 18547 etc.)
    2 - the folders with the avid media in are all in one folder named MXF
    3 - that this MXF folder is an another folder named exactly Avid MediaFiles
    4 - and that this Avid MediaFiles folder is located on the drives root level
    Only then MC is able to "see" and scan the folders.
    After scanning and indexing you can rename the folders with names containing also letters.
    MC 8.8.4 | Symphony Option / HP Z420 / WIN 7 PRO 64-bit SP1 / certified NVidia driver + QT version [view my complete system specs]
      ·´¯`·.¸¸..><((((º>.·´¯`·.¸¸.·´¯`·.¸
      ><((((º>`·.¸¸.·´¯`·.¸><((((º>`·.¸
  • Mon, Jun 19 2017 3:12 PM In reply to
    bushfilm:
    Thats your problem.Avid can only see media in the correctly names flder structure from root level down.
    John's Backup isn't part of that nor can it be.
    ACI Moderator. I'm not employed by Avid or work for them. I just do this in my spare time. Symphony V8.6 / 8.3.1 HP Z400 system [view my complete system specs]
