Latest post Fri, Oct 26 2018 12:30 PM by Jeroen van Eekeres. 4 replies.
  • Wed, Jun 14 2017 6:22 PM
    Nexis client, folders in workspaces occasionally locked on windows user level.
    Dear Avid, Bob,
    I see another case being opened for the latest project I'm doing but before doing so I wonder if you ever saw this before Bob?
    About once a week a client of the Nexis storage, it can be a win10 editing client or win 2012r2 server like SGL all of a sudden produces a user rights access warning when you try to access a sub folder or parent folder while browsing either in an apllication or windows itself. Only resolution is to quit nexis client and start it again and that immediatly resolves it.
    In the past 6 weeks I have become aware of it happening 4,5 times. So it's not a killer but still a bit worrying.
    I've seen it happen with 7.3.2 client and 7.5. Weirdly never with 7.4. And because the 7.4 client accidentally did not include the fix  that could under circumstances cause the media indexer to BSOD, I wonder if that's related or just pure coincedence.
    I already have a case open because 7.5 client causes BSOD's on 2 SGL Flashnet servers, probably because RSS is enabled on the 10G cards and wonder if I should open a case for this one folder user rights issue too.
    Regards,
    Avid reseller ACSR at Telmaco
    http://www.telmaco.gr/en/
  • Sat, Jun 24 2017 7:41 AM In reply to
    Re: Nexis client, folders in workspaces occasionally locked on windows user level.
    I opened a case as recently this problem appeared on an editing system with the projects folder.
    The response from support however amazed me. Their advice is to use the same Nexis client version throughout the system. Using mixed versions could cause this.
    If so, why is this not mentioned in the readme?
  • Mon, Jun 26 2017 4:46 PM In reply to
    • BobRusso
    • New Jersey
    • Posts 2,243
    • Points 27,700
      Moderator: Avid ISIS
      Moderator: Avid NEXIS PRO
    Are the files Read-only and the application is trying to copy, move, rename, or delete? Files with the Read-only Attribute can't be modified by design. When clips are locked in a Media Composer bin, the Read-only Attribute is added. Other shared storage that claims compatibility with Media Composer doesn't honor this attribute.
    There was a change in Windows 7 with how Read-only files are handled. In Vista and earlier, it a file is Read-only it can't be deleted. In Windows 7 and later, read-only files can't be modified but can be copied, moved, renamed, or deleted.
  • Mon, Jun 26 2017 8:18 PM In reply to
    Hi Bob,
    The folders are not accessible at all when this occurs. While at the same folder level in the same workspace other folders can be accessed. I've also seen it happen when trying to access sub folders or a parent folder (which is even weirder).
    With Nexis client 7.3.2 a quit and start of nexis client would resolve the issue. With Nexis client 7.5 however this did not work. It would stay inaccessible. With Nexis client 7.4 however I have not seen the issue which is the reason I didn't open a case before.
  • Fri, Oct 26 2018 12:30 PM In reply to
    Hi Avid (and Bob if you still follow this thread).
    Today finally a hint on the reason why this happens but what I'm about to write could also be nonsense.
    At one customer a system was locked out of a folder after media composer crashed when a usb stick was plugged in into the pc.
    This left the <projectname>.log file open in the projects folder of the project that was open at the time of the crash. I was able to determine this as I was not able to delete this file from another system after copying the whole project subfolder to a <project-copy> folder.
    Nexis client is blocking access to parent folders of files that are left open or growing by the specific system that left that file open while other systems can still gain access to that folder but cannot delete the file which is left open. The Nexis client on the system on which the crash occured can correct the issue by performing a Nexis client restart or a whole system restart (it could be that newer 2018.6.x version of Nexis client corrects it without a restart, not 100% sure).
    So it seems the delayed write failures that occured on Airspeeds and Telestream vantage and media composer crashes were leaving files open that could only be deleted by other systems like the Interplay server (NXNuser) after a restart of the Nexis client (up to version 2018.6) on the specific systems that left the file open.
