Latest post Sat, Feb 24 2018 11:29 PM by RiddleDab. 7 replies.
  • Mon, Jun 12 2017 5:26 PM
    • conleec
    • Los Angeles
    • Posts 1,319
    • Points 17,060
    Command Snap-To-Edit Not working
    Hello everybody,
    So this is a new one for me: I did a clean install of Sierra yesterday and then installed Media Composer 8.8.4. Everything seems to be working fine, except that I can no longer hold down the Command key to force the playhead to snap to an edit. Command-Option no longer works either. Been doing this for close to 20 years, and it's driving me crazy. Can anybody point me to a setting that may have been changed, or something?
    It's NOT the "position bar snap" or the "segment drag snap" settings, btw. I never use those, and checked that they're not selected.
    Chris
    MacPro 3.33Ghz 12 Core (Westmere, MacPro 5,1), 48Gb RAM, nVidia GeForce GTX 680, Intensity Pro (Desktop Video 10.4.3), OS X 10.13.6, MC 2018.12 [view my complete system specs]
  • Mon, Jun 12 2017 6:13 PM In reply to
    Re: Command Snap-To-Edit Not working
    Works here on El Capitan...
    Have you tried a new Avid user?
  • Fri, Jun 16 2017 10:38 PM In reply to
    • conleec
    • Los Angeles
    • Posts 1,319
    • Points 17,060
    I'm at my wit's end here. I just uninstalled and re-installed Media Composer. I've repaired permissions. I've tried new users. And Command-drag is no longer snapping. Here's a link to a YouTube video showing what's going on. MC 8.8.4. OSX 10.12.4.
    https://youtu.be/0_fBvaDmUG4
    Chris Conlee
  • Fri, Jun 16 2017 11:57 PM In reply to
    • conleec
    • Los Angeles
    • Posts 1,319
    • Points 17,060
    Seriously. I've now rolled back to MC 8.8.0, and it's still not working. I've swapped keyboards. Still not working. I've upgraded to 10.12.5. Still not working. WTF!?! This is making Media Composer basically unusable. Anybody have a clue what the hell could be going on here?
  • Sat, Jun 17 2017 6:35 PM In reply to
    • conleec
    • Los Angeles
    • Posts 1,319
    • Points 17,060
    Mystery solved, for anybody who's the least bit interested: I finally did a wipe of my hard drive, and re-intallled the entire OS and all my apps from scratch. Media Composer snap worked as anticipated. Then I installed my virus scanner: Webroot, and suddenly snap didn't work anymore.
    To confirm, I disabled Webroot and voila -- snap worked as expected.
    Long story short: Webroot for Mac screws up Media Composer's Command-snap feature. I really like Webroot otherwise, so I guess I'll just disable when editing.
    Chris
  • Sat, Jun 17 2017 6:54 PM In reply to
    • Andrew
    • Joined on Wed, Apr 6 2011
    • Costa Mesa, Orange County, California
    • Posts 103
    • Points 1,240
    conleec:
    Chris
    Wow!  You were really lucky to discover that!  Usually it's always that one unknown thing that causes Media Composer to not behave as expected.  I guess I'll stay away from Webroot.  Anti-virus software always has a habit of complcating things.  Had you not discovered that, I was concerned that you would kiss Media Composer off forever.  Glad the problem had nothing to do with MC.
    Avid MC v2018.12.1, macOS Mojave 10.14.2, iMac 21.5-inch, late 2015 (purchased new on Jan. 2017), , Processor: 2.8 GHz Intel Core i5, Memory: 16 GB 1867... [view my complete system specs]
  • Sat, Jun 17 2017 7:41 PM In reply to
    • conleec
    • Los Angeles
    • Posts 1,319
    • Points 17,060
    Andrew:
    LOL, no, i wouldn't kiss MC off forever, because it's how I make my living day to day on episodic television. But when my home system goes haywire, it drives me bat-sh*t crazy. I've been with it for nearly two decades, and will be with it until the bitter end, I'm sure.
    BTW, Webroot is really good, and other than this unfortunate side effect, I haven't noticed it causing any other slowdowns or problems. It found two trojan horses attached to recent builds of FileZilla, by the way, so it's worth having something.
    Chris
  • Sat, Feb 24 2018 11:29 PM In reply to
    • RiddleDab
    • Posts 12
    • Points 120
    Same problem. Your fix worked for me as well. Thank you so much for posting this. I couldn't use Shift mouse drag either. It was driving me crazy. Turned off Webroot and everything is working as it should.
