Latest post Thu, Nov 1 2018 1:51 PM by chiara1981. 10 replies.
Page 1 of 1 (11 items)
  • Fri, Jun 9 2017 6:43 PM
    • johanV2
    • Joined on Fri, Jan 7 2011
    • Posts 14
    • Points 170
    Avid Media Composer 7.0.2. is crashing when editing effect LCONCEAL - CONCEAL
    Hello,
    When I place the effect Conceal / Lconceal in the timeline and then I edit this effect with the effect editor I get the following message:
    Assertion failed !("WHo\'s calling this?!?!?") File:..\..\src\Consumers\EffectMan\ARealTimeEffect.c, line: 102
    I have allready tested the same effect in another project and also in a testproject and I 've got the same error ! Same error with the effects "flip" "flop".... Other effects don't give this error message when editing.
    I have found the same item in the forum A.M.C. for PC without a solution mentionned ....
    I am working with Avid 7.0.2 under Win 7 Prof SP 1 64 bit - IntelCore I7 CPU 920 @2.67 GHZ - Ram 24 GB
    Is there anyone who can help me ?
    Thanks for your response !
    Johan
    Windows 7 Prof 64 bit SP 1 CPU IntelCore I7 920 @ 2,67 GHZ Ram 24 GB [view my complete system specs]
  • Wed, Jun 14 2017 8:12 AM In reply to
    Re: Avid Media Composer 7.0.2. is crashing when editing effect LCONCEAL - CONCEAL
    Have you tested it with a fresh new user setting in a fresh new project to eleminate those as possible issues?
  • Wed, Jun 14 2017 12:48 PM In reply to
    If you're desperate and need a workaround, you could use the 3d Warp effect to do an LConceal, Flip, or Flop. It's a little more work than just dropping on a premade effect, but it might get the job done while you're waiting for a solution to the crashes.
  • Wed, Jun 14 2017 6:45 PM In reply to
    • johanV2
    • Posts 14
    • Points 170
    Hello Pat,
    Sorry, I have not mentionned that I have made indeed a fresh new user profile but I work still in the old project (where the crashing began).
    Till today I don't have no more troubles with effect editing....
    Regards
    Johan
  • Wed, Jun 14 2017 6:56 PM In reply to
    • johanV2
    • Posts 14
    • Points 170
    Hello Camoscato,
    Thanks for the tip but I have found that my Avid MC program was reinstalled in a wrong way after my PC was repaired !  The program must be installed with an ADMINISTRATOR account and not with an "account with administrator privileges"   (cfr AMC Guide) !!!!! I have reinstalled AMC with a real ADMINISTRATOR account and now editing effects works fine again ! I have also made a new user profile.
    I wrote this solution in another post about the same error but with the VERT effect....
    Regards
    Johan
  • Wed, Jun 14 2017 7:25 PM In reply to
    I'm glad to hear you were able to find the solution!
  • Thu, Oct 25 2018 2:18 PM In reply to
    Hi JOhan,
    I know this is a quite old post but I got the same problem of the Assertion Failed with a FLIP/FLOP effect and I got exactly the same thread as you.
    Now, I recently re-installed Avid mC with a monthly subscription and I read about the administration account. How can I check if I have an administration account or not?
    Thank you so much.
    Best,
    Chiara
  • Thu, Oct 25 2018 3:52 PM In reply to
    • johanV2
    • Posts 14
    • Points 170
    Hello Chiara,
    I think that this link will help you https://www.tenforums.com/tutorials/21680-determine-account-type-windows-10-a.html
    (if you are working with window 10).
    Grreetings,
    Johan
  • Thu, Oct 25 2018 3:59 PM In reply to
    Thank you so much Johan, but I am working on a MAC!
  • Fri, Oct 26 2018 12:40 PM In reply to
    • johanV2
    • Posts 14
    • Points 170
    O.K., then you can thry this I think:
    Administrator Rights (Mac)
        From the Apple menu, select System Preferences.
        In the System Preferences window, under System, select Accounts.
        Select your user account, and then view the right panel. If Allow user to administer this computer isn't checked, you don't have admin rights.
    Greetings,
    Johan
  • Thu, Nov 1 2018 1:51 PM In reply to
    Thank you so much Johan, i got it.
    Very useful tips.
    Best,
    CHIARA
