Latest post Wed, Jun 28 2017 8:18 AM by MattB. 14 replies.
Page 1 of 1 (15 items)
  • Thu, Jun 8 2017 4:08 PM
    • MattB
    • Joined on Tue, May 9 2006
    • Shepperton, UK
    • Posts 472
    • Points 6,410
    Avid or Nvidia issues?
    Im getting a few issues that I cant get to the bottom of and I can't work out where the issue lies.
    First - I used to be able to get thumbnail images for title mattes etc by highlighting and then presing the 'home' key - cant do it now, has that facility been removed?
    Second (and more annoying) Avid freezes if I try to play a thumbnail image (to play through to a more informative image for the clip). I get an error message from Nvidia OpenGL which says the application has requested more memory than the systen has available, and Avid closes and I have to restart.
    I have learned to constantly Ctrl-S to keep saving my work. (I cant find the autosave frequency setting now either).
    Anybody got any ideas? Thanks in advance.
    MattB
    Edit 1:- Intel Core i9 7900X msi x299-SLI-plus mobo 32GB DDR4 3000Mhx memory NVIDIA Quadro P4000 (Nvidia driver 411.95) Samsung 860PRO SSD 512GB system... [view my complete system specs]
    Matt B
  • Thu, Jun 8 2017 4:50 PM In reply to
    • RalphC
    • Joined on Wed, Sep 2 2015
    • Posts 1,833
    • Points 20,230
    • Avid Customer Advocate
      Avid Customer Service
      Avid Employee
    Re: Avid or Nvidia issues?
    Hi MattB,
      You are working with MC 8.8.4v?
    RalphC
  • Thu, Jun 8 2017 4:55 PM In reply to
    • MattB
    • Shepperton, UK
    • Posts 472
    • Points 6,410
    Ralph
    8.8.3 at the moment (Edit 1 in my system specs), Havent got round to updating yet, dont like to when I'm mid project.
    MattB
    Matt B
  • Thu, Jun 8 2017 5:40 PM In reply to
    • RalphC
    • Posts 1,833
    • Points 20,230
      Avid Employee
    MattB:
    Ralph
    MattB
    Good idea not updating while in the middle of project. I open a support case for you 03222204, noted that you're in a middle of a project.
    RalphC
  • Mon, Jun 12 2017 4:11 PM In reply to
    • ryguy
    • Joined on Thu, Apr 30 2009
    • Posts 141
    • Points 1,995
    Hi there, I have also been having the issue with playing thumbnails. I am currently useing 8.8.2. I have lost hours of work over it becase playing a thumbnail causes avid to shut down. I have posted about it before here
    http://community.avid.com/forums/p/180481/842926.aspx#842926
    But have got nowhere, any help would be appreciated.
    Main Workstation: Dell Precision T7600, Windows 10 Pro, Intel Xeon E5-2687W @ 3.10GHz 2x, 64GB RAM, Nvidia Quadro 4000, Running Avid Media Composer... [view my complete system specs]
  • Mon, Jun 12 2017 4:20 PM In reply to
    • Posts 10,204
    • Points 218,090
    ryguy...
    Im going to get a case started....  are you able to send or post me myour settings?
    I trust your specifications are up to date right?
    marianna
  • Mon, Jun 12 2017 4:23 PM In reply to
    • ryguy
    • Posts 141
    • Points 1,995
    Marianna, Thank you. Yes my specs on my profile are current and it is the Main Workstation I am talking about. My other Alternate workstation plays thumbnails just fine.
  • Tue, Jun 27 2017 9:47 AM In reply to
    • MattB
    • Shepperton, UK
    • Posts 472
    • Points 6,410
    Hi. I've been tied up on other projects, so haven't been paying attention to this as I should. My problem still persists, so far I have:
    updated to MC8.8.4
    created new user profiles in new test projects
    performed a 'clean install' of the nvidia drivers
    Nothing so far has made a difference, MC still freezes if I try and play a thumbnail.
    The second issue is to do with seeing a thumbnail preview of a title caption. I used to be able to hit 'home' on a selected thumbnail and the image would change from a 'T' in a purple frame, to a meaningful image. Feature seems to have disappeared from MC8 onwards (or moved to where I can't find it)
    MattB
    Matt B
  • Tue, Jun 27 2017 12:51 PM In reply to
    • Vilem
    • Joined on Sat, Apr 10 2010
    • Prague
    • Posts 1,405
    • Points 15,470
    Hello everyone,
    I have the same error "error message from Nvidia OpenGL ...." when using Multicam.
    We all have the Quadro 4000 card in specifications.
    It helped me return to the 353.82 driver.
    With the new drivers provided with the MC8.x.x installation (362.13, 375.86, 377.11), there are problems with the graphics card memory.
    V.
    AVID MC2018.12.1 - dongle, HP Z620 - 2 x Intel Xeon E5-2620, Quadro P2000 - driver 390.77, RAM 48GB - DDR3, BM Intensity Pro 4k - 10.11, W10 - 64bit Professional... [view my complete system specs]
  • Tue, Jun 27 2017 2:08 PM In reply to
    • Posts 10,204
    • Points 218,090
    You can also try this in the future....
    1. Open your NVIDIA Control Panel and select “Manage 3D settings”
    2. Then, select the “Power Management mode” and change the option from “Adaptive” to “Prefer maximum performance”
    3. Save your changes, and your are done!
    See if that helps...
    marianna
  • Tue, Jun 27 2017 3:23 PM In reply to
    • Vilem
    • Prague
    • Posts 1,405
    • Points 15,470
    Marianna:
    Hi Marianna,
    Setting helped with Multicam.
    However, thumbnail playback, which I do not normally use, but tested, generates an error and closes the application.
    V.
  • Tue, Jun 27 2017 3:30 PM In reply to
    • Posts 10,204
    • Points 218,090
    Vilem
    what exact error?
    marianna
  • Tue, Jun 27 2017 3:36 PM In reply to
    • Vilem
    • Prague
    • Posts 1,405
    • Points 15,470
  • Tue, Jun 27 2017 3:41 PM In reply to
    • MattB
    • Shepperton, UK
    • Posts 472
    • Points 6,410
    Same error for me too.
    I have a case open with support already.
    I believe my Nvidia 3D settings are set to maximum performance already, but I'll check later today. And Im going to try Vilem's suggestion to roll back the driver.. All later today when I can get back to the machine.
    MattB
    Matt B
  • Wed, Jun 28 2017 8:18 AM In reply to
    • MattB
    • Shepperton, UK
    • Posts 472
    • Points 6,410
    So, rolling back to Nvidia Driver 853.82 did the trick, thanks for the pointer, Vilem.
    It seems that it is a known issue because I found this KB article:-
    http://avid.force.com/pkb/articles/en_US/compatibility/Quadro-4000-and-Windows-10
    All I need to sort out now is how to get thumbnail previews for title mattes again!
    MattB
    Matt B
