Latest post Mon, May 29 2017 2:04 PM by TVJohn. 11 replies.
Page 1 of 1 (12 items)
  • Thu, May 25 2017 8:12 PM
    • Todd H
    • Joined on Fri, Jun 9 2006
    • Mansfield, Texas
    • Posts 83
    • Points 1,040
    New build for Avid MC
    I have been having an issue with my current build where my computer just shuts off then reboots.  I always get that it is a power issue in the error log but I can not solve this.  This year I have changed out the memory, psu, motherboard and boot drive.    I am now getting the issue again after not having it for a few months.  Today when I turned on the pc to sit down and work it ran the check disk for the C drive.   The constant restarts has made me crazy and I have seen this error reported by a ton of people all over the net and not a single person has solved it.
    anyway, I think I will just rebuild from scratch.  I am running mc 8.7 right now but will update to the current mc for the rebuild.  So I am wondering if anyone out there has a list of components recently that has worked for them.  I am using the specs from this site https://pixelstrobist.com/best-pc-for-video-editing-for-all-budgets/  as a baseline the super computing pc for 2300.  I do not want amd however.  I have a blu ray and quadro 4000 gpu currently I am hoping to reuse.
    Is Avid safe to run in windows 10 pro yet?  Sorry for not knowing I just have been running windows 7 without a problem forever and had no interest in changing.  If avid is ok with windows 10 then I will upgrade.
    I have a kona 3g with the BOB that I use also.  I just want to find a a nice blend of working parts.
    Look forward to any thoughts.
    Windows 7 Pro 64bit asus p6t deluxe v2 pny nvidia quadro fx 1800 Corsair ddr3 12800 12 gb ram 1 seagate 1 TB 7200 rpm boot drive 2 Hitachi 1 TB 7200... [view my complete system specs]
  • Thu, May 25 2017 8:33 PM In reply to
    • EvanAA
    • Joined on Mon, Mar 7 2016
    • Posts 37
    • Points 480
    Re: New build for Avid MC
    Yes, Win10 Pro works great! Been on it for over a year.
    With Win10 make sure once you get it up and working to turn off the Win auto updates. They can kill your system.
    http://www.windowscentral.com/how-stop-updates-installing-automatically-windows-10
    -Evan
  • Thu, May 25 2017 8:36 PM In reply to
    • Todd H
    • Mansfield, Texas
    • Posts 83
    • Points 1,040
    thanks Evan.  Much appreciated
  • Thu, May 25 2017 9:21 PM In reply to
    • LDV20
    • Joined on Fri, Nov 18 2011
    • Posts 124
    • Points 1,500
    If you are going to build a single I7 CPU - check out the new Intel X299 chipset - it replaces X99 also new pascal
    quadro video cards - (althought not sure if avid qualified them yet)
    MC 8.9.2 - Win 10 pro, Asus PrimeZ270 with i7 7700 cpu, Quadro P2000,32gig memory, 500gig SSD system drive, WD 5TB,and 2TB media drive,matrox mini, external... [view my complete system specs]
  • Fri, May 26 2017 1:51 AM In reply to
    I've found that MC barely uses the GPU, so using an expensive/powerful video card had little impact on performance. Also found the Quadro cards to be underper spec'd when compared to their GeForce counterparts.
    Maybe this situation has changed with the latest versions of MC.
  • Fri, May 26 2017 10:29 AM In reply to
    • Lukas Boeck
    • Joined on Fri, Jul 31 2015
    • Austria
    • Posts 396
    • Points 4,615
    MC doesn't use gpu much.
    but plugins do!
    i do a lot of diy builds. pm me for blueprints.
    MC 8.4.4 Cusom bulid Supermicro X9SRL-F, 32 Gig Ram, 3ware 9750 6x6TB Seagate EC Drives, LSI 9207 + LTO-6, Mojo DX, Artist Color, Flanders CM240, GTX 1070... [view my complete system specs]
  • Fri, May 26 2017 3:44 PM In reply to
    • Bruno M
    • Joined on Thu, Feb 11 2010
    • London, UK
    • Posts 406
    • Points 5,060
    It's worth mentioning that by default, WIndows 10 is set up to send a lot of information about you and your computer back to Microsoft.
    There's a video that goes into this in a lot of detail, if you can get past the presenters rather annoying presentation style!
    https://www.youtube.com/watch?v=u1kGMCfb2xw
    He also runs through Spybot's Anti Beacon software, which is designed to disable all these data sharing 'options', which can even switch themselves back 'on' after an update!
    HP Z800,HP8600,HP8760WSonnetFusion RAID, Mediadock U320, Classic Nitris Mojo DXSymphony 5,6 & 8.5 JVC DTV1910 HD tube monitor, HP Dreamcolor, [view my complete system specs]
  • Fri, May 26 2017 7:57 PM In reply to
    • EvanAA
    • Posts 37
    • Points 480
    Also think about future proffing some. Yes MC uses very little of GPU, yes most 3rd party plug-in's do. Also Premiere uses GPU a lot. So will you be or maybe using Premiere also?
    -E
  • Sun, May 28 2017 2:30 AM In reply to
    • TVJohn
    • Bayonne NJ
    • Posts 4,277
    • Points 52,925
    Over the last 20 years I have learned to steer clear of 3rd party utilities and "helpers". Usually they start off somewhat beneficial, as time moves on they often cause more problems that they are supposed to "fix".
    Using MC 8.10. Avid FX6.4, Vegas Pro 15/ DVD Architect 6pro, DVDit6.4proHD, CCE Basic, TmpGe Express4, TmpGe Authoring Works 4, DVDLab-Studio. Sony EX-1R, Canon XH-A1, GL2, GL1, Canon EOS 60D
  • Sun, May 28 2017 8:33 PM In reply to
    EvanAA:
    -E
    I can certainly see if more GPU power is needed for plugins and other apps. But for the expectation that MC might be using the GPU more is not a great idea, IMHO.
    The reason being that unlike a mother board, a video card is rather easy to upgrade and the pace of GPU development seems to be way outpacing that for CPU's.
    The highest I'd recommend is a very good card, like a 1080. But going any higher than that just seems like a waste of money, JMHO.
  • Mon, May 29 2017 11:47 AM In reply to
    • cuervo
    • Joined on Fri, May 2 2008
    • Santa Fe, NM
    • Posts 1,171
    • Points 15,560
    Let me begin by saying, clearly, that I love MC. I've been using MC since v3. It's always been a dependable platform for my editing.
    Having said that, my last build was an Intel platform with Thunderbolt II and a dual GPU setup, one nVidia Quadro 4000 card, to satisfy my display needs, and one nVidia GTX1070 for GPU processing. This setup is fully supported by the paid version of Davinci Resolve 12.5. I completed my last job on Davinci Resolve, why?
    I've been processing a lot of high end drone footage, i.e. 5K/29.97P cDNG. This really takes a lot of processing power. Especially, getting the first RAW pass to play back in real time. I can get realtime playback, using Thunderbolt II with RAIDed SSDs, and 100% GPU from the GTX1070 card. Resolve can do it, MC is brought to its knees.
    Let me add that I'm not posting this to troll AVID. I've got an AVID wrokflow based on years of expereince. But, requirements have pushed me to faster turnaround. MC is a ponderous system, not really intended for independent users. My needs are going off in a different direction; and, AVID seems not to care about those needs.
    'nuff said.
    edit: P.S. I think it's worth a shoutout to Marianne, who has provided years of really valuable support and customer service. BMD is nowhere nearly as responsive as Marianne or this forum. It's painful to recognize what I've posted, above.
    SYS1:ASUS Z97, Haswell 4.0GHz CPU, 32GB RAM, Quadro 4200 + GTX1070, Thunderbolt II -DNxIO-FSI CM171 ///SYS2:ASUS Maximus Extreme V, Sandy Bridge 3.1GHz... [view my complete system specs]
  • Mon, May 29 2017 2:04 PM In reply to
    • TVJohn
    • Bayonne NJ
    • Posts 4,277
    • Points 52,925
    Interesting. Avid has taken the path of collaboration, cloud usage, extensive media management, distributed systems. As we move toward 4K, and higher, considering the interest in virtual reality, is the performance balance being drawn away from the pure function of editing and color grading?
