Latest post Mon, May 22 2017 8:41 PM by RodneyinMunich. 20 replies.
Page 2 of 2 (21 items) < Previous 1 2
  • Sun, May 21 2017 10:24 AM In reply to
    • mjolnarn
    • Joined on Wed, Feb 8 2006
    • Sweden
    • Posts 13,346
    • Points 159,335
    Re: Capturing old dv tapes with 32 k audio
    Jay Fedigan:
     I needed to set the frame rate at 30i for the 32k option to show up on the dropdown menu.
    FW capturing is just a plain transmission of bytes from the tape to Avid/mxf , you need to have the Avid setup configured exacly as the properties of the tape media, no conversion at all is done when you are fw capturing.
    Tomas
  • Mon, May 22 2017 12:20 PM In reply to
    • DStone
    • Massachusetts
    • Posts 3,501
    • Points 45,075
    Jay, you should probably transcode the media to something with 48K audio before using it in a 1080i/p project.
    Dave S.
  • Mon, May 22 2017 12:58 PM In reply to
    • Jay Fedigan
    • Joined on Wed, Sep 15 2010
    • Belmont, MA
    • Posts 70
    • Points 1,025
     I am able to open the footage in an HD project but I'm not sure if there will be issues once I'm done editing. I have not tried to transcode any media before. Is there a tutorial or some help I could get and how to do it?
    HP z440 Xeon ES-1650 v3 3.4 GHz, 16 GB RAM, Nvidea Quadro M4000 , Media Composer 8.8.3 Windows 10 Pro [view my complete system specs]
  • Mon, May 22 2017 2:17 PM In reply to
    • DStone
    • Massachusetts
    • Posts 3,501
    • Points 45,075
    RIght-click on a clip and choose Conslidate/Transcode. In the dialog, click on Transcode. If you're doing this in a 1080 project, the video settings will be for DNxHD 145. You need to manually select the audio settings. Change the sample rate from 32K to 48K 16-bit. You can select multiple clips and transcode all at once. Note that this takes some time per clip.
    A better solution is capture into a DV project and transcode just the audio. That's a lot faster and you can drop the SD clips into your HD project, where they'll get a FrameFlex put on them to scale to HD. You can also just change the project format from 30i to 1080i and it'll do the same thing.
    Also, just to note, I can use native DV with 24-bit 32K audio in a 1080i project without issues. No playback or editing problems that I've noticed. So this may all be moot anyways.
    Dave S.
  • Mon, May 22 2017 4:51 PM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 159,335
    For best upscaling results, hopefully you have Boris or could use a trial license for this project only:
    1. Capture using firewire , you will get the same DV codec as on the tape
    2. Still in SD mode, add all that media to a single Sequense and do a transcode to 1:1 ( that is uncompressed SD ) and 48 khz audio
    3. Now export a QT ref out from this Sequense.
    4. Switch project to HD and Import that qt ref, do not link , to DNxHD with settings " do not resize "
    5. Use BCC Uprez to upscale it to HD and render it out, you might want to do a Video Mixdown after rendering to lock the media, easier this way to continue to work with it.
    add..   and if you don´t have Boris use about the same workflow but link the QT ref and use FrameFlex to upscale it, then render it out and lock it with a Mixdown  ... end add ..
    Tomas
  • Mon, May 22 2017 8:41 PM In reply to
    Just copy the bin into your 1080 project and act like it's a normal bin.
    Edit 1: MC 8.10 + Symphony + PhraseFind • MacPro 6x3.5GHz/64GB OS10.10.5 • Artist Mix & Color • Aja Io 4K • Edit 2: MC 8.10 • MacPro 2x2.66GHz/48GB... [view my complete system specs]
    Rodney Sewell BFS
