Latest post Mon, May 15 2017 1:25 AM by v-block. 2 replies.
  • Sun, May 14 2017 8:46 PM
    • v-block
    • Posts 504
    • Points 6,375
    Stabilise effect's premature start.
    When I add the stabilise effect to a clip, it immediately charges off analysing the clip, before I get a chance to set the thing up to suit my requirements. Is that just the way it must be or is there a way to add the effect, that avoids this wilful behaviour?
    Does it make any difference whether the adjustments are made before or after the analysis of the clip happens?
    Asus X58 Sabertooth motherboard, Core i7 920 CPU, Win 7 Pro 64bit, NVIDIA GeForce GT610, 12GB Corsair 3x4GB CMX-12GX3M3A1333C9 ram in triple channel config... [view my complete system specs]
  • Sun, May 14 2017 9:55 PM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,401
    • Points 57,635
    Re: Stabilise effect's premature start.
    I believe the analysis must happen before you select adjustments (and when you change adjustments, you'll notice that it does not re-analyze - or am I mis-remembering how it works?).
    Camera(s) PXW-X70, HDR-FX1, Hero 3+ | MC 8.8.0 | QT 7.7.9 | BCC 10.0.2 | Boris RED 5.5 | Windows 10 Pro x64 | System: P6X58D-E, Core i7 960, Quadro K4200... [view my complete system specs]
    Steve
    ______________________
    www.nelliedogstudios.com
  • Mon, May 15 2017 1:25 AM In reply to
    • v-block
    • Posts 504
    • Points 6,375
    I know many of the selections such as auto zoom, reference point etc. can be made after the analysis but there is also a box, as with the trackers,  that can be positioned on a feature or group of pixels. Is that even part of the stabiliser or is it unused in stabilisation?
    If the analysis starts before that box can be positioned and it has no function in the stabilisation process, then it can only be there to wind up fools like me.
