Latest post Tue, May 29 2018 7:45 AM by BenoitM. 14 replies.
Page 1 of 1 (15 items)
  • Sun, Apr 30 2017 6:57 PM
    • Lukas Boeck
    • Joined on Fri, Jul 31 2015
    • Austria
    • Posts 467
    • Points 5,505
    Trim to fill on foreign framerate
    yo
    since v8 foreign framerates always have a Motion Adapter applied. is non-removable afaik.
    can't apply timewarp-> trim to fill to such clips.
    i'm guessing nobody has a workaround?
    MC 8.4.4 Cusom bulid Supermicro X9SRL-F, 32 Gig Ram, 3ware 9750 6x6TB Seagate EC Drives, LSI 9207 + LTO-6, Mojo DX, Artist Color, Flanders CM240, GTX 1070... [view my complete system specs]
  • Mon, May 1 2017 11:49 AM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,620
    • Points 60,370
    Re: Trim to fill on foreign framerate
    I understand that you can promote the temporal adaptor on the clip to a full Timewarp effect. Then you can configure it as a fit-to-fill, I believe.
    Camera(s) PXW-X70, HDR-FX1, Hero 6 Black | MC 18.12.1 | QT 7.7.9 | Continuum 2019 | Sapphire 2019 | Mocha Pro 2019 | Titler Pro 6 | Windows 10 Pro x64... [view my complete system specs]
    Steve
    ______________________
    www.nelliedogstudios.com
  • Mon, May 1 2017 7:25 PM In reply to
    • Lukas Boeck
    • Austria
    • Posts 467
    • Points 5,505
    i'm not convinced that's true.
    just tried promotion, started trimmer from inside Motion Effect editor.
    behaves like normal trimmer.
  • Tue, May 2 2017 3:20 AM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,620
    • Points 60,370
    Never tried it myself. Did you recreate the trim to fill settings in the promoted Timewarp effect?
    Steve
  • Tue, May 2 2017 7:47 PM In reply to
    • Lukas Boeck
    • Austria
    • Posts 467
    • Points 5,505
    It's true. it's true!
    If you promote, you can apply "trim to fill" from effects palette.
    works as expected.
  • Wed, May 3 2017 11:07 AM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,620
    • Points 60,370
    I finally gave it a shot and it worked for me, too. Good to know for future reference.
    Cheers
    Steve
  • Tue, Apr 10 2018 10:30 AM In reply to
    • BenoitM
    • Brussels, Belgium
    • Posts 1,173
    • Points 14,070
    Lukas Boeck:
    works as expected.
    Hmmm I can't seem to be able to do this easily: I have a 1080p50 (proxy/offline res) in a 1080i50 timeline.
    When I promote the clip, it's still ok with 200% speed, as expected (1080i50 is 25fps) but when I then add the Trim to Fill effect, the speed is reset to 100% and the clip plays half the expected speed; I can't find the proper/easy way to mod the TW parameters to double the speed after having trimmed to the desired duration. Apparently, manually editing the speed graph/value of the TtF breaks it.
    How should I proceed ?
    MC 2018.12 (Symphony option)/BCC 10.0.5/RED 5.6; BlackMagic Ultrastudio Mini Monitor (10.11.2.0); DELL Precision 5530 - Intel Core i7-8850H 2.6 GHz - 32... [view my complete system specs]
  • Thu, Apr 12 2018 7:27 AM In reply to
    • BenoitM
    • Brussels, Belgium
    • Posts 1,173
    • Points 14,070
    Help ??? Is everyone really out at NAB ? Wink
    -> How do I use a Trim to Fill effect on a clip that has a Motion Adapter ?
    I could not find a [simple] way to use it on a 1080p50 clip in a 1080i50 (25 fps) timeline.
  • Sun, May 27 2018 8:27 AM In reply to
    • BenoitM
    • Brussels, Belgium
    • Posts 1,173
    • Points 14,070
    Hi all,
    Support confirmed this is by design...I'm still open for your best recommendation to apply a Trim to Fill effect (and change the clip duration) on a 1080p50 clip in a 1080i50 (25 fps) timeline without complex math.
  • Sun, May 27 2018 4:56 PM In reply to
    • v-block
    • Posts 537
    • Points 6,800
    I would try, dropping in your 'trim to fil' effect on the clip in the timelime, changing the 'edit graph' to 'position', then do your trim as normal. When you are happy with the edit, note the frame number in the right hand frame indicator in the timewarp control. Half that and type the new figure into the box. This will double the speed of the segment you are working on. You will then need make a new cut, at the new keyframe position in the timewarp control and remove the extra frames up to the fill point, which are present because the speed has doubled in the segment.
    Asus X58 Sabertooth motherboard, Core i7 920 CPU, Win 7 Pro 64bit, NVIDIA GeForce GT610, 12GB Corsair 3x4GB CMX-12GX3M3A1333C9 ram in triple channel config... [view my complete system specs]
  • Mon, May 28 2018 9:10 AM In reply to
    • v-block
    • Posts 537
    • Points 6,800
    I didn't have MC in front of me when I posted that but after trying your example, the first thing that occured to me was why you would be concerned about the speed change when using Trim To Fill, A speed change is almost unavoidable when using that effect, as it locks the number of frames in the segment and lefts you stretch or compress them over time. In your example, after adding your trim to fill you could restore the speed to the original, simply by triming the segment to half it's length. With that in mind, I don't really understand what you expected when you added that effect.
  • Mon, May 28 2018 2:41 PM In reply to
    • BenoitM
    • Brussels, Belgium
    • Posts 1,173
    • Points 14,070
    v-block:
    I have one clip that I cut in three parts. I want to speed up the middle part and keep the first and last parts as is; obviously the cut edits must still keep matched frames (in particular the ending frame of the 2nd part must match the first frame of the 3rd part) after the 2nd part has been shortened (& accelerated)
    Before adding the TtF, the frames at the 2nd edit point do match; but when I add the TtF to the 2nd segment, they no longer do, b/c TtF resets the speed to 100% before I start trimming; I agree with your suggestion, but the math is (just a bit) more cumbersome when I trim the segment by non-trivial values (1/2, 1/4, etc.)
    Of course it's probably even better in this case to NOT cut the clip in 3 parts, and instead add a TW effect and keyframe the speed graph; it's just that a TtF would be faster IMHO.
  • Mon, May 28 2018 2:47 PM In reply to
    • Lukas Boeck
    • Austria
    • Posts 467
    • Points 5,505
    BenoitM:
    v-block:
    time adapt your middle part anywhichway.
    then do matchframe on the fist & last frames of effect. edit that from source window.
    trim to fill is sometimes slightly off sometimes i think.
  • Mon, May 28 2018 4:12 PM In reply to
    • v-block
    • Posts 537
    • Points 6,800
    You have found an example that isn't normal but in any case, I would simply use the normal timewarp in position mode, add 2 keyframes at the start and finish of your middle section, use the digital read out in the timwarp control, to make sure the 1st and 3rd sections are at normal speed (rate of change right and left should be the same between keyframes 1-2 and 3-4) and use linear keyframes if you need frame accuracy over where the effect starts and ends etc.
  • Tue, May 29 2018 7:45 AM In reply to
    • BenoitM
    • Brussels, Belgium
    • Posts 1,173
    • Points 14,070
    Thanks all for the suggested workarounds !
