After having our Nitris DX in operation for almost 10 years, I thought it would be high time to open it up again and not only give it a good dusting but also to replace the rather old and noisy 80 mm Delta main system fans. I decided to pick up a pair of Austrian designed Noctua fans which are very nicely made and extremely quiet. However, these fans don't have the same specs as the original Delta's (RPM speed is lower in the replacement fans). More on this to follow.
In addition, there is a 40 mm PSU cooling fan which sounds like a turbine when powered up and given the hard mounting to the metal PSU chassis which in turn makes contact with the main fan metal support "leaf", the sound the NDX was emitting had some nice harmonics producing beats in the 90 dB range..., borderline unusable I/O box unless rectified. Actually, one could argue a health hazard. In short, I replaced this fan too and while the overall cooling might not be quite as effective as it was before, the unit is virtually dead quiet and I actually can hear my timelines now! I couldn't wipe the grin off my face after connecting everything and powering up.
I won't go further into the hardware and noise issues but I wanted to lay down the foundation for my questions. Why? Because Symphony is now complainig intermittently about a "fan malfunction" and stops timeline or clip playback. Clearly, there is no fan malfunction because all three are working perfectly well. But..., evidently NDX communicates in some fashion (over the PCIe bus) with SYM telling it that there is a problem. Of the three fans, only the main two PCB 80 mm fans are three pin and are therefore in principle speed controlled by the NDX hardware. The PSU fan is a two pin fan powered internally by the PSU so it is not controlled by the PCB nor has direct communication with it other than possibly through the 20 pin molex power connector to the NDX hardware. So, with that out of the way, I was hoping someone with NDX hardware knowledge could help answer the following:
1) How does the NDX box communicate with SYM at the fan "malfunction" level?
2) Does the communication only happen between system controlled 3-pin fans (i.e., the main fans) or is the system also monitoring the PSU fan through the 20 pin connector?
3) What does the NDX hardware expect in terms of fan performance/specs? Is it RPM based only or is there more to it?
4) If I know the now quiet NDX box is operating properly without excessive heat (I haven't noticed the passive chip heatsinks or the PSU overheating after having the system on for a day), is there a way to disable this notification in software (e.g., through the console) which prevents proper functionality of the software?
Any insight or advice is much appreciated.
Thanks, David
Hi David.
Whilst I know very little about the internal workings of the NDX, I have some experience of putting fans into computer cases.
As you're probably aware, fans can have anywhere between 2 and 4 connectors. These pins usually follow the same standard, in that pin 1 is ground, pin 2 is +ve, pin 3 is the sense output from the fan and pin 4 is the (PWM) control input.
If we assume that Avid follows this convention, the 3 pin fans inside the NDX are sending rotary information to the NDX boards via pin 3 on the fan. You mentioned that your replacement fans have a lower rotational speed to the originals, and this may be your problem. It may be that your fans are being speed-controlled , which can be simply done with DC motors by varying the voltage on pin 2. However, when the NDX hardware/firmware thinks it needs maximum cooling, it's going to send the max voltage (12 volts) to the fans and expect them to come to full speed. Given that your fans won't reach these speeds, the circuitry will detect this problem via pin 3 and do whatever the firmware is designed to do - in your case it stops Symphony with an error message.
Where this problem happens in DIY computer builds, it's sometimes possible to change fan settings in the BIOS, but since there seems no way of accessing anything like BIOS/setup menus in NDX, I suspect your options are limited. You mentioned console settings, but I've never seen any published settings that allow you to get into the inner workings of the NDX. Avid normally seem to do this via a firmware update, which you may have noticed when you've updated the software, but I wouldn't rate your chances of getting a modified firmware update from Avid engineering!
I suspect your only remaining options are to get hold of fans that run as fast as your original fans, or to service the original fans (bearing lubrication/replacement).
Bruno
Hi David
I had trouble concentrating in our online suite with a DX box right in front of me, our engineer replaced all three fans with the same make you mention and Avid Symphony after an hour came up with the same alert. The engineer then looked up the original fan specs and replaced them almost like for like in terms of speed and air flow it now runs whisper quiet.
ill see if we have the document and pop it on here. I think we had to go with two manafacturers.
and i live 2 streets from noctua HQs (no ***!)
i can go see if they have still have any 2-pin fans left.
Bruno M:Where this problem happens in DIY computer builds, it's sometimes possible to change fan settings in the BIOS, but since there seems no way of accessing anything like BIOS/setup menus in NDX, I suspect your options are limited. You mentioned console settings, but I've never seen any published settings that allow you to get into the inner workings of the NDX. Avid normally seem to do this via a firmware update, which you may have noticed when you've updated the software, but I wouldn't rate your chances of getting a modified firmware update from Avid engineering!
With a little electronics knowledge you could "trick" the Avid box into thinking the fan is running at full speed. First you would have to measure the sense voltage on the original fans at both normal and full speed (I'm assuming here that the NDX hardware probably only runs at two speeds - normal and full bore). Then you would have to measure the sense voltage of the new fan at what you consider normal and full. As it only seems to have problems with full you could just concentrate on stepping that voltage up so that it matches the original fans. We are talking mV here so I imagine it wouldn't need to be a big adjustment.
Of course if you can just buy much quieter fans that match the rotational speeds of the originals I think that would be a lot easier.
John
Mondo:With a little electronics knowledge you could "trick" the Avid box into thinking the fan is running at full speed. First you would have to measure the sense voltage on the original fans at both normal and full speed (I'm assuming here that the NDX hardware probably only runs at two speeds - normal and full bore). Then you would have to measure the sense voltage of the new fan at what you consider normal and full. As it only seems to have problems with full you could just concentrate on stepping that voltage up so that it matches the original fans. We are talking mV here so I imagine it wouldn't need to be a big adjustment.
I'm pretty sure this wouldn't work. As far as I'm aware, pin 3 sends pulses based on it's rotational speed (2 pulses per revolution) and this is what computer motherboards read, not the value of the voltage on that pin.
Fellas,
thanks for all the replies. It's good to hear that I'm not the only one who found the NDX alarmingly loud. Of course, when it's in a server room, one probably doesn't know or care but when it's in the suite...
Sharney, info on your final replacement units would be helpful. The Noctua's are really nice fans so it's going to be a shame to have to pull them. I looked up the specs of the original Delta's but couldn't find the specific model in my NDX on their site. Generally, similar model numbers had higher RPM and airflow.
Question: did your engineer know or measure whether RPM info is being passed to/from the PSU 2-pin fan (i.e., in principle no RPM or other info being communicated) to the circuit boards through the 20-pin power connector? This is actually my main concern as it was the loudest (and fastest) fan of all.
I've already serviced the old Delta fans so they should be quieter than they were. I guess the next step would be to put them back in and see if the firmware problem goes away. If it does, the next thing would be to actually know or measure what RPM the NDX expects out of these 3-pin fans (I doubt there is any way for it to detect airflow).
I actually tried a couple of strobe tachometer phone apps to see what RPM the Delta's (and PSU fan) were turning but they are rather crude and don't give particularly accurate results. With that in hand, perhaps I can source a pair of similar spec better quality fans. I think my 80 mm Delta's turn 1800 RPM while the Noctua's that I picked up are 1200 RPM (intentionally chosen as I knew they would be quiet) but I guess this is proably too low for the NDX to be happy.
David
Hey David,
Can you tell me the models of the fans you used for replacment? I'd love to do this, myself. For the 80mm, I know that Noctua has the PWM, FLX (multiple speeds), and ULN (ultra low noise / slow fan). The PWM has a 4pin connector but would still work, but don't know if the FLX would...
As for the 40mm, that's the loudest part by far! I'd love to know what you used there.
Ben
