I need to upgrade my isis 5000 from version 4.0.3 to 4.7.9, is this possible or should I go through another lower version?
thank you very much
Copy pasted from:
http://resources.avid.com/SupportFiles/attach/AvidISIS/AvidISIS_ReadMe_4_7_11.pdf
The installer, AvidISISSetup.exe, determines the version of software currently on your System Director and prevents you from performing an unsupported upgrade.
If applicable, a dialog box instructs you to upgrade to an intermediate version before upgrading to the current version. Make sure you correctly identify your ISIS hardware model in the table, where noted.
Inyour case: v4.0.3 (ISIS 5000) / v4.0.4 (ISIS 7000) To 4.7.11 which is direct, without intermediate steps.
I've done the upgrade and it worked fine.
Note:
ALWAYS make a backup of your metadata prior to the upgrade!
• Partition0 • Partition1 • PartitionDump.bin
metadata location: D:\Program Files\Avid\ISIS System Director
Jeroen van Eekeres
www.mediaoffline.com
Thank you so much, I'll try it.
