Latest post Thu, Apr 27 2017 5:28 PM by stefanocps. 8 replies.
Page 1 of 1 (9 items)
  • Thu, Apr 20 2017 9:48 PM
    windows problem when using a laptop
    hello when i use avi din my laptop, when i open certain windows, when they are long...i can t get too see the button at the end..generally ok and cancel
    It is like the windows goes out o the screen and i can t move it up
    It is not avid related..i have it in other similar sw...but may be you can help
    thanks a lot
    CPU I7 2600k 3.4ghz Ram 32gb Ssd 256gb GPU Nvidia GTX760 Win 10 Avid Media 8.4 [view my complete system specs]
  • Thu, Apr 27 2017 2:03 PM In reply to
    • RalphC
    • Joined on Wed, Sep 2 2015
    • Posts 1,633
    • Points 17,945
    • Avid Customer Advocate
      Avid Customer Service
      Avid Employee
    Re: windows problem when using a laptop
    stefanocps:
    thanks a lot
    It might help if you added screenshots. I will move your post to Off Topics section.
    Goodluck,
    RalphC
  • Thu, Apr 27 2017 3:13 PM In reply to
    here it is
    that is my laptopscreen (it has 1366x768 resolution)
    i don t use it for big work, often i do exercise onm it, and little job)
    as you see in some windows, ythis in particlura..the bottom button are missing
    are out of the screen
    it should be a resolution problem but how to solve?
    also avid don t warn me about resolution when i open it
    thanks
  • Thu, Apr 27 2017 4:42 PM In reply to
    • RalphC
    • Posts 1,633
    • Points 17,945
      Avid Employee
    stefanocps:
    1366x768 is the native/recommended resolution of your laptop? Can you try to set a lower dpi settings.
  • Thu, Apr 27 2017 4:51 PM In reply to
    yes
  • Thu, Apr 27 2017 4:58 PM In reply to
    • RalphC
    • Posts 1,633
    • Points 17,945
      Avid Employee
    Lowering the dpi settings did not help?
  • Thu, Apr 27 2017 5:06 PM In reply to
    no!
  • Thu, Apr 27 2017 5:14 PM In reply to
    • RalphC
    • Posts 1,633
    • Points 17,945
      Avid Employee
    Did you check the GPU driver? if it's affecting all SW, I've check if the GPU driver is correctly installed, 1366 is too low IMO, you should be shooting like 1920 something.
  • Thu, Apr 27 2017 5:28 PM In reply to
    i can t do nothing do the gpu driver
    they are the latest and the resolution is that
    seems thais os low but avid should tell me that i not the correct resolution
