Latest post Sat, Aug 11 2018 6:44 PM by marysuzie. 5 replies.
Page 1 of 1 (6 items)
  • Thu, Apr 20 2017 5:19 PM
    Media Composer v.8.8.2 Errorcode: -43
    Please help,
    I've just updated my software to versaion 8.8.2 from 8.5.3 and I can't export anything at all.
    I keep on getting errorcode: Exception:Movie export from procedures FAILED! errcode: -43
    I'm trying to export footage that I put together on the previous version.
    If anyone can help please let me know how to respond to you.
    Phil.
    HP Z440 Workstation
    Intel(R) Xeon(R) CPU E5-1620 v3 @ 3.5 GHz
    3.5GHZ 1TB HHD Internal Memory 16GB RAM
    Nvidia Quadro K2200 graphics card
  • Thu, Apr 20 2017 5:44 PM In reply to
    • Posts 9,520
    • Points 209,320
    Re: Media Composer v.8.8.2 Errorcode: -43
    what format are you exporting?
    what OS?
    try to exporte in QT Animation and see if that works
    AOL IM:  avidmarianna
    Skype: mariannamontague
  • Thu, Apr 20 2017 6:15 PM In reply to
    Hi Marianna,
    My OS is Windows 8 (I believe)
    The Format is H.264 @25fps
    Audio is: 48KHz and 24bit
    Hope this helps.
    Phil.
    HP Z440 Workstation
  • Thu, Apr 20 2017 8:43 PM In reply to
    • Posts 9,520
    • Points 209,320
    Definately h.264 related...
    are you able to export with QT animation and see if that works.  How about makeing sure you are exceeding the 2GB limit of the export clip size.
    M
  • Thu, Apr 20 2017 8:52 PM In reply to
    Thank you for this.
    After 2 hours of searching what the error code relates to I finally discovered that its a quick time file problem that AVID knows what the fault is and will be releasing a proper solution to the problem later this year :( :( :( (I really did not want to see or hear this but anyway)  I've decided to uninstall version 8.8.2 and reinstall 8.5.3 instead as I dont like some of the changes AVID has made to 8.8.2
    I will let you know how I get on (Huge sigh)
    #PISSEDOFF
    Thank you for your help Marianna :)
    HP Z440 Workstation
  • Sat, Aug 11 2018 6:44 PM In reply to
    • marysuzie
    • Joined on Thu, Sep 23 2010
    • Posts 14
    • Points 180
    Glad to find this thread as I am having the same issue. Which is weird as I have been exporting for months now without a hitch. Not sure what changed, but with each drive I am now getting that error code. Did avid provide a solution? I tried the DNXHD codec, but no dice....
