Latest post Mon, Apr 24 2017 6:05 AM by Mondo. 1 replies.
Page 1 of 1 (2 items)
  • Thu, Apr 20 2017 1:58 AM
    • joyjoyfu
    • Joined on Mon, Jul 12 2010
    • Posts 1
    • Points 15
    SFPlayConsumer::Excecute TIMEOUT error messages
    Hi All
    Hopefully some Avid guru can help me with this.
    I have the latest version of Avid 8.8.2
    my OS is Window 10.
    After the update, I have trouble to open the old project.
    it kept giving me this error messages on both reord and source window: "SFPlayConsumer::Execute TIMEOUT".
    I googled for existing answers. someone suggest to turnoff the "Fast Scrub" in timeline setting.
    so I did turn this off, but I still got the same error msg.
    Some people suggest to install the AVCHD plug in. so I went on Avid.com to download the plugin.
    but apparently, 8.8.2 version doesn't have the AVCHD plugin available anymore.
    So, If someone has the same problem like I do.
    Could you direct me to the right path.
    Many thanks.
    Joy
  • Mon, Apr 24 2017 6:05 AM In reply to
    • Mondo
    • Sydney Australia
    • Posts 1,624
    • Points 18,615
    Re: SFPlayConsumer::Excecute TIMEOUT error messages
    joyjoyfu:
    More info needed. You don't say what kind of media you are using? At a glance I'd suspect a missing plugin or the wrong plug in doing the linking. In particular Sony XDCam material seems to link via Quicktime via default if the new Nablet plug ins aren't installed correctly.
    Also all the normal things on upgrade - new user, new settings, new site settings.
    joyjoyfu:
    It's there -it is simply built into the software rather than being a separate plug in. Has been since about V6.
    John
