Latest post Fri, Apr 21 2017 3:07 PM by Kevin Klimek. 2 replies.
  • Wed, Apr 12 2017 10:43 PM
    • curiosity
    • Boulder, CO
    • Posts 831
    • Points 10,500
    DV Tape Death Throes
    I know this is an ancient format, and at its best Firewire was a hot mess. But for the love of Pete, I still have jobs and work that are in this format! Avid has completely destroyed my ability to work with DV projects.
    • Sometime around 8.3 or 8.4 Avid lost the ability to create DV projects. Only SD is now available. (Even "Custom Settings" wont support 720x480)
    • 8.4.5 was the last version that would output to DV/DVCAM via 1394/OHCP. And even then, the only way to output was a crash record from the timeline. (Which means the framerate is not constant)
    • PAL DV can't hold the frame boundaries, images are offset every few scanlines.
    • You can still create an HDV project (1440x1080) but output to tape is a problem.
    The only working solution I have at the moment is to output a 720x486 file into a Premiere DV timeline (to chop off the extra 6 pixels) and then output. (and I cannot tell you how much it pains me to have to use Premiere)
    Anyone have a workaround or am I doomed to eternally maintin a Snow Leopard system running MC 6.5.5 (the peak of Firewire's power)?
    i7-5820(x99), 64GB, Win 8.1, GTX 1080ti [view my complete system specs]
  • Fri, Apr 21 2017 4:43 AM In reply to
    • Mondo
    • Sydney Australia
    • Posts 1,624
    • Points 18,615
    Re: DV Tape Death Throes
    Honestly? I'd keep running the Snow Leopard system. PS  Want to buy an Adrenaline or a Mojo? Big Smile
  • Fri, Apr 21 2017 3:07 PM In reply to
    With Mondo's suggestion, how about dual boot?
