Latest post Sat, Apr 15 2017 9:42 PM by TrevorA. 2 replies.
  • Wed, Apr 12 2017 4:55 PM
    • Melissa
    • Joined on Wed, Apr 12 2017
    • New York
    • Posts 6
    • Points 130
    Render In/Out Issues
    We recently updated our 6 edit stations from Avid 8.4.5 to 8.6.5 and have found that whenever we select "render in/out," Avid will render every effect in that range regardless of whether or not it has already been rendered. In the past, if we had a 3-minute long sequence with 40 effects on it, but only 10 were unrendered, we would select the full sequence and render in/out and Avid would know to only render the 10 underendered effects and skip over the 30 already rendered effects. Now, since the upgrade, it will render everything including re-rendering the 30 effects that are already rendered.
    Is this a known bug? Or is there a way to force Avid to only render what is underendered? I've considered using expert render in/out, but I'm lead to believe that only affects effects that need to be rendered for a smooth playback, and we want to make sure every effect is rendered regardless if it will playback fine without.
    Thanks!
    Z820, 32GB RAM, Windows 7 ISIS 5500 and Interplay Environment [view my complete system specs]
  • Sat, Apr 15 2017 6:58 PM In reply to
    • knejmann
    • Århus, Denmark
    • Posts 174
    • Points 1,875
    Re: Render In/Out Issues
    melissalastweek:
    That is one of the uses of Expert Render. If you choose Render entire selection you sould get the result you want :-)
    Media Composer 8.2.11 (some with Symphony option) - Windows 7 - HP Z420/Z820 (Nitris DX), Lenovo W540 etc. - Interplay and ISIS7000+NEXIS storage - Avid... [view my complete system specs]
    Kåre Nejmann
    Danish Broadcasting Corporation - DR
    Aarhus, Denmark
  • Sat, Apr 15 2017 9:42 PM In reply to
    • TrevorA
    • Posts 1,081
    • Points 12,305
    Bug has been there for a number of versions. Only occurs if you use a keyboard shortcut to render into out. I have it assigned to the timeline button bar instead.
