Latest post Wed, Apr 19 2017 12:19 AM by Mondo. 4 replies.
  • Wed, Apr 12 2017 9:02 AM
    • mkj
    • Sweden
    • Posts 344
    • Points 4,535
    share 1 gigabit connection with 2 workstations? (to connect to ISIS/Nexis)
    Have anyone tried this?
    And what (small) switch do you use?
    It cant be often you use 100% of the bandwith....and have a room where its a bit problematic to drag new cables to.
  • Wed, Apr 12 2017 9:23 AM In reply to
    Re: share 1 gigabit connection with 2 workstations?
    Most CAT5/6 network points are wired with 4 twisted pairs and you normally only use 2. So you can get splitters fro each end to double the capacity. better than a switch.
  • Wed, Apr 12 2017 11:51 AM In reply to
    • mkj
    • Sweden
    • Posts 344
    • Points 4,535
    brilliant!
    Thanks!
    EDIT: are you sure here? Everywhere I read they say that gigabit is not possible to split? (uses all 4 pairs)
  • Fri, Apr 14 2017 9:12 AM In reply to
    • Bruno M
    • Joined on Thu, Feb 11 2010
    • London, UK
    • Posts 475
    • Points 6,025
    mkj:
    This is indeed the case. Gigabit networks are designed to use all four twisted pairs. This allows users to happily send Gigabit down Cat 5 cabling, creating four 250 Mbps channels (before encoding). Gigabit networks will work in situations where only two of the pairs are connected, but will fall-back to 100 Base-T.
    In theory, it should be possible to send the same signal down two pairs of Cat 6 cabling, as the bandwidth capability doubles per pair over Cat 5, but I don't know if there's any hubs/switches that will do this.
    EDIT: Just discovered there's something called 1000Base=TX which was designed to send Gigabit down just 2 pairs. From a quick Google search it seems that it hasn't really caught on in a big way, but you might find some hardware that uses this standard - probably be quite expensive!
    HP Z800,HP8600,HP8760WSonnetFusion RAID, Mediadock U320, Classic Nitris Mojo DXSymphony 5,6 & 8.5 JVC DTV1910 HD tube monitor, HP Dreamcolor, [view my complete system specs]
  • Wed, Apr 19 2017 12:19 AM In reply to
    • Mondo
    • Sydney Australia
    • Posts 1,625
    • Points 18,620
    mkj:
    brilliant!
    Thanks!
    Are you planning on using both workstations at the same time? I think it will lead to lots of issues with traffic congestion but you best bet is a small gigabit switch. Hopefully you've got one lying around you can test.
    John
