Hello Everyone,
I am having some issues with importing Alpha RGB titles in Avid Media Composer. I am importing these Alpha RGB transparent text and lower thirds into Avid than I am cutting them into the timeline and they are glitching the footage when I lay the text over the footage. I must be doing something wrong that is causing this issue. I know it's not a hardware issue. I am editing in avid 1920X 1080 29.97. When I remove the Alpha text I don't get glitchy jumps in my video. Thanks for your patience and help!
These are my settings for Alpha RGB from After Effects
RGB+Alpha Quicktime
Color: Straight Matted
Format Options Animation
Importing into Avid
Alpha Channel-Invert on import White=Opaque
Image Size Adjustment-Image Sized for Current Format
Color levels
Scale from Full Range to legal range
Autodetect sequentially numbered files
I brought these in with an MFX 45 what other numbers do you suggest? Here are my options for MXF 45, 100, 145, 220 MFX?
When I render I get the glitchy jumps in video.
This is most likely the GPU render bug. See this thread for more information:
http://community.avid.com/forums/t/179757.aspx
Dave S.
Thankyou!
