Latest post Tue, Apr 11 2017 7:29 PM by ryguy. 3 replies.
  • Tue, Apr 11 2017 5:41 PM
    • ryguy
    • Joined on Thu, Apr 30 2009
    • Posts 141
    • Points 1,995
    4K Project
    Hey All, I am working in an HD project, but I have a couple of shots fillmed in 4k. I really don't like using an ama link to bring in and work with 4k. So I thought I would open a 4k project, bring in the media as DNxHR, and then open the 4k bin up in the HD project. I should then be able to work with it, scale it, and so on.
    When I clicked on the new project button and clicked the drop down menu for 4k it gives me some options.
    My question is, what is the difference between 4k DCI Flat and 4k DCI Full? what does DCI even stand for?
    Main Workstation: Dell Precision T7600, Windows 10 Pro, Intel Xeon E5-2687W @ 3.10GHz 2x, 64GB RAM, Nvidia Quadro 4000, Running Avid Media Composer... [view my complete system specs]
  • Tue, Apr 11 2017 6:45 PM In reply to
    • Posts 9,264
    • Points 206,140
    Re: 4K Project
    Ryguy...
    Digital Cinema Initiatives (DCI) is the dominant 4K standard. Digital Cinema Initiatives  is a joint venture of major motion picture studios, formed to establish a standard architecture for digital cinema systems.
    Read up on it here...  https://en.wikipedia.org/wiki/4K_resolution
    it will provide the scoop on DCI ( flat cropped ) etc....
    AOL IM:  avidmarianna
    Skype: mariannamontague
  • Tue, Apr 11 2017 7:16 PM In reply to
    Re: 4K Project
    DCI Flat means 1.85:1 (1998×1080 in 2K, 3996×2160 in 4K). DCI Full (full aperture) is 16:9 (2048x1080 in 2K, 4096x2160 in 4K). DCI Flat and DCI Scope are common aspect ratio's for digital cinema delivery. DCI Full exists, but is uncommon (most theaters do not have a preset for it). For TV, use UHD.
    Also: you can now AMA link to the file in your current project. When transcoding, you can choose to keep it at original frame rate and resolution. It eliminates all the years of workarounds in having to create a project with matching resoltion and/or frame rate and moving bins and clips around.
  • Tue, Apr 11 2017 7:29 PM In reply to
    • ryguy
    • Posts 141
    • Points 1,995
    Re: 4K Project
    Ahh! Thanks for all the info. Very helpful.
