Latest post Mon, Apr 10 2017 8:42 AM by olenad. 3 replies.
  • Thu, Apr 6 2017 10:39 PM
    inews 3.6 to 3.7 server upgrade and soap response minor change
    We have performed the 3.6 to 3.7  upgrade of a test system at a customer site. There is an in-house application developed by the company that uses web services.
    The developer reports that the SOAP response, after the upgrade, changed a little bit. The tags shown below come from the system after the iNEWS server upgrade from 3.6 to 3.7. They have “<ns2:”, while before the upgrade, the response used to come with “<ns3:”, instead.
     Is it normal ?
    <ns2:QueueLocator>129959042.6820247.3</ns2:QueueLocator>
    <ns2:StoryAsNSML>&lt;?xml version="1.0" encoding="UTF-8"?>&lt;nsml:nsml xmlns:nsml="http://avid.com/nsml" version="3.1">&lt;head>&lt;meta break="1" float="false" hold="false" mcserror="false" rate="140" wordlength="6"/>&lt;rgroup number="10"/>&lt;wgroup number="182"/>&lt;formname>JORNAIS/BDRJ/INDICAD&lt;/formname>&lt;storyid>07bf0482:0070c7d2:582c19a7&lt;/storyid>&lt;/head>&lt;fields>&lt;string aready="false" bg="0" id="page-number" ro="false" uec="false" urgency="1">   &lt;/string>&lt;string aready="false" bg="0" id="var-1" ro="false" uec="false" urgency="1"> *   BDRJ&lt;/string>&lt;string aready="false" bg="0" id="var-2" ro="false" uec="false" urgency="1"/>&lt;string aready="false" bg="0" id="title" ro="false" uec="false" urgency="1">xxªFEIRA, xx / xx / 2016&lt;/string>&lt;string aready="false" bg="0" id="var-4" ro="false" uec="false" urgency="1"/>&lt;string aready="false" bg="0" id="presenter" ro="false" uec="false" urgency="1"/>&lt;duration aready="false" bg="0" id="audio-time" ro="false" uec="false" urgency="1">0&lt;/duration>&lt;duration aready="false" bg="0" id="tape-time" ro="false" uec="false" urgency="1">0&lt;/duration>&lt;duration aready="false" bg="0" id="total-time" ro="false" uec="false" urgency="1">0&lt;/duration>&lt;string aready="false" bg="0" id="video-id" ro="false" uec="false" urgency="1"> &lt;/string>&lt;string aready="false" bg="0" id="modify-by" ro="false" uec="false" urgency="1">maia&lt;/string>&lt;string aready="false" bg="0" id="endorse-by" ro="false" uec="false" urgency="1"/>&lt;string aready="false" bg="0" id="cume-time" ro="false" uec="1" urgency="1">@21603&lt;/string>&lt;string aready="false" bg="0" id="ready" ro="false" uec="false" urgency="1">OK&lt;/string>&lt;string aready="false" bg="0" id="writer" ro="false" uec="false" urgency="1"> &lt;/string>&lt;date aready="false" bg="0" id="modify-date" ro="false" uec="false" urgency="1">1479283148&lt;/date>&lt;string aready="false" bg="0" id="var-21" ro="false" uec="false" urgency="1"/>&lt;string aready="false" bg="0" id="var-5" ro="false" uec="false" urgency="1"/>&lt;string aready="false" bg="0" id="var-6" ro="false" uec="false" urgency="1"/>&lt;string aready="false" bg="0" id="var-7" ro="false" uec="false" urgency="1"/>&lt;string aready="false" bg="0" id="var-3" ro="false" uec="false" urgency="1"/>&lt;/fields>&lt;body family="0" findent="0" font="" pindent="0" pitch="0" rindent="0" tabs="24">&lt;p family="0" font="" pitch="0">&lt;a idref="0"/>&lt;/p>&lt;p family="0" font="" pitch="0"/>&lt;p family="0" font="" pitch="0">&lt;a idref="1"/>&lt;pi>{{//// SOBE SOM ////&lt;/pi>&lt;/p>&lt;p family="0" font="" pitch="0"/>&lt;p family="0" font="" pitch="0"/>&lt;p family="0" font="" pitch="0">&lt;pi>DEIXA :             &lt;/pi>&lt;/p>&lt;p family="0" font="" pitch="0">&lt;pi>}}&lt;/pi>&lt;/p>&lt;/body>&lt;aeset family="0" font="" pitch="0">&lt;ae family="0" font="" id="0" pitch="0" runs="0" type="G" version="S2.1">&lt;ap family="0" font="" pitch="0">&lt;i family="0" font="" pitch="0">LOCUTOR VIVO&lt;/i>&lt;/ap>&lt;/ae>&lt;ae family="0" font="" id="1" pitch="0" runs="0" type="G" version="S2.1">&lt;ap family="0" font="" pitch="0">&lt;i family="0" font="" pitch="0">//// RODA VT ////&lt;/i>&lt;/ap>&lt;/ae>&lt;/aeset>&lt;/nsml:nsml></ns2:StoryAsNSML>
    </Stories
  • Fri, Apr 7 2017 9:19 AM In reply to
    • olenad
    • Joined on Thu, Nov 6 2014
    • Posts 29
    • Points 310
    Re: inews 3.6 to 3.7 server upgrade and soap response minor change
    yep, that's correct
    Olena
  • Fri, Apr 7 2017 2:13 PM In reply to
    The developer said that in this case he would need to change the system´s source code in order to support the different response.
    Is there any way of making iNEWS 3.7 respond exactly the same way as 3.6 ?
    Thanks in advance!
  • Mon, Apr 10 2017 8:42 AM In reply to
    • olenad
    • Posts 29
    • Points 310
    <ns2: ...> or <ns3:..> are auto-generated namespace names
    we cannot garantee some specific name in response because it's genereted by framework
    You may look into this line in "GetStories" response, for example, to check what name space you should use
    Here is example from my LAB
    <GetStoriesResponse xmlns="http://avid.com/inewsqueue/types" xmlns:ns2="http://avid.com/inewssystem/types" xmlns:ns3="http://avid.com/inewsstory/types">
    Olena
