Latest post Wed, Jun 28 2017 8:20 AM by MattB. 10 replies.
Page 1 of 1 (11 items)
  • Fri, Mar 31 2017 9:52 PM
    • ryguy
    • Joined on Thu, Apr 30 2009
    • Posts 141
    • Points 1,995
    Avid crashing when playing thumbnails
    Hi All, I was working away in 8.8.1 and i clicked on a clip in the bin while using script view and pressed the space bar in order to play the thumbnail so that I could then stop it on a frame I liked better, as I have done a million times. When suddenly I got this error:
    "An application has requested more GPU memory than is available in the system. That application will now be closed."
    then avid shut down.
    I found an Nvidia webpage that talks about this error but isn't very helpful.
    http://nvidia.custhelp.com/app/answers/detail/a_id/3553/~/opengl-request-for-more-gpu-memory-than-is-available-meaning
    I have ensured that I am running the lates recommended drivers for my Nvidia Quadro 4000 to work with Avid, which is  375.86.
    Any Ideas?
    Main Workstation: Dell Precision T7600, Windows 10 Pro, Intel Xeon E5-2687W @ 3.10GHz 2x, 64GB RAM, Nvidia Quadro 4000, Running Avid Media Composer... [view my complete system specs]
  • Tue, May 9 2017 4:47 PM In reply to
    • ryguy
    • Posts 141
    • Points 1,995
    Re: Avid crashing when playing thumbnails
    Hey haven't had a response to this! anyone have any ideas?
    Thanks in advance!
  • Tue, May 9 2017 5:01 PM In reply to
    • Posts 10,228
    • Points 218,335
    ryguy
    what happens if you turn off GPU rendering?  My bet is you shoud jump to 8.8.2 at least or wait  few days for 8.8.3.  there are tweaks in both that affect GPU.
    Also what card do you have?
    marianna
  • Tue, May 9 2017 5:15 PM In reply to
    • ryguy
    • Posts 141
    • Points 1,995
    Hi Marianna, the GPU rendering is already switched off because of the colour correction glitch many users including myself have been experiencing. I am currently running 8.8.2. Also my second Avid set up is not experiencing the same problems.
  • Wed, May 10 2017 1:55 PM In reply to
    • mjolnarn
    • Joined on Wed, Feb 8 2006
    • Sweden
    • Posts 13,346
    • Points 159,335
    You seem to have a system similar to mine, what about the media cache settings, they are very low by default, I have changed mine to 2000 - 1200    2000 - 1000 and also have the cache folder located on a fast media drive , allowed ram usage is 16 gb
    Tomas
  • Wed, May 31 2017 3:13 PM In reply to
    • ryguy
    • Posts 141
    • Points 1,995
    Thanks for replying, I went into media cache and in the thumbnail tab I set the disk cache size to 2000 and the memory cache size to 1200 and then I went in to the video memory tab and changed the memory to 16 GB from 2GB. I then tried to play a thumbnail and it still crashed. I also noticed that the video memory setting reverted back to 2GB after I reopened Avid. Is the video memory the GPU memory or the system ram?
  • Mon, Jun 12 2017 4:28 PM In reply to
    • Posts 10,228
    • Points 218,335
    Ryan
    I have a case going on this for you..... something is definately odd if you have one system working fine and one not.  Case # 03223971
    stand by
  • Tue, Jun 13 2017 7:42 AM In reply to
    • MattB
    • Joined on Tue, May 9 2006
    • Shepperton, UK
    • Posts 473
    • Points 6,435
    Im getting the same issue on my 'Edit 1' system (see specs) - I have reported in another post.
    MattB
    Edit 1:- Intel Core i9 7900X msi x299-SLI-plus mobo 32GB DDR4 3000Mhx memory NVIDIA Quadro P4000 (Nvidia driver 411.95) Samsung 860PRO SSD 512GB system... [view my complete system specs]
    Matt B
  • Tue, Jun 13 2017 9:47 AM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 159,335
    MattB:
    MattB
    Hi Matt / Ryguy , and I saw that other post Matt.
    What happens if you do a fresh install of the Win 10 drivers provided by the Avid installer ( apps / avid / utilities / nvidia )
    You might need to select the advanced installing options to get that option ( to remove all the old ) and also reboot one or two times.
    Tomas
  • Tue, Jun 27 2017 7:53 AM In reply to
    • MattB
    • Shepperton, UK
    • Posts 473
    • Points 6,435
    Tomas - Sorry - I took a while to get to this (paying jobs!). I have done a clean install of the Nvidia drivers on edit 1 and it has made no difference. Do you think I should roll back to an earlier driver?
    MattB
    Matt B
  • Wed, Jun 28 2017 8:20 AM In reply to
    • MattB
    • Shepperton, UK
    • Posts 473
    • Points 6,435
    So, the solution is to revert to Nvidia driver 353.82 and all is well again.
    It seems that it is a known issue because I found this KB article:-
    http://avid.force.com/pkb/articles/en_US/compatibility/Quadro-4000-and-Windows-10
    MattB
    Matt B
