Latest post Mon, Apr 3 2017 3:05 PM by Fernando Sancho. 4 replies.
  • Tue, Mar 21 2017 6:50 PM
    Dell PowerEdge R630 guideline
    Hi, does anybody know ram configuration set up for these servers? I have an old sr2500 and I was thinking of upgrading (hw & sw) but I can't find any information other than the minimum system requirements.
  • Thu, Mar 30 2017 5:42 PM In reply to
    • Baklap
    • Hilversum - The Netherlands
    • Posts 6,944
    • Points 82,400
    Re: Dell PowerEdge R630 guideline
    Fernando, if you wish i can check out some specs on one of ours? Would be good to know what role the system is going to play as a Lookup demands less then a STP or Indexer.
    35+ MC's - 224TB Isis - 2.2 PB Spectra T950 - Interplay - 2 Media Central's - 3 TM's - 2 STP's - 500 TB Isilon - 2 Vantage - MOG SPeedrail... [view my complete system specs]
    Twitter Account
    "If you do what you did you will get what you got!"
    My Keys
  • Thu, Mar 30 2017 6:13 PM In reply to
    Hi, thanks mate, that would be great! This is a small facility, very low budget, so the idea is to run interplay production services, media indexer and lookup all together in the same server (not certified I know).
    I've been using an SR2500 for these services, worked smoothly with version 2.x but the time has come to upgrade both HW & SW to 3.x.
  • Sat, Apr 1 2017 11:34 AM In reply to
    • Baklap
    • Posts 6,944
    • Points 82,400
    Did some quick digging and have this for you. We use this system for Media Director:
    Model: Server PER630
    Prc: Intel(R) Xeon(R) CPU E5-2620v3 @ 2.40GHz 2.40GHz (2 processors)
    Installed memory (RAM): 32GB
    Server 2012R2 64bit
    Broadcom Myri-10G Ethernet adaptor
    OS Disc 40 Gb
    Datadrive 1 TB (spinning disc)
    Hope this helps :-)
    Menno
    Twitter Account
    My Keys
  • Mon, Apr 3 2017 3:05 PM In reply to
    hey, thanks for the information! By any chance do you know RAM configuration ? I guess 2 x 8GB 2400Mhz dimms per CPU right?
    Regards,
    Fernando
