Latest post Tue, Mar 21 2017 7:36 PM by Vadym. 3 replies.
  • Mon, Mar 20 2017 9:33 PM
    CreateMasterClip seemingly not working.
    Normal 0 false false false EN-US X-NONE X-NONE MicrosoftInternetExplorer4
    /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman","serif";}
    I setup my avid system and think it works correctly since I am able to make folders get children and the like. But I seem to be unable to make a master clip. It seems to say something about not being able to checkin to a folder even though I am certain that folder exists since I made it with the createFolder ws call with the same URI. I am using SOAPUI to send the soap message to my interplay service, and am just getting started with AVID.
    <soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" xmlns:typ="http://avid.com/interplay/ws/assets/types">
       <soapenv:Header>
          <typ:UserCredentials>
             <typ:Username>*****</typ:Username>
             <typ:Password>*****</typ:Password>
          </typ:UserCredentials>
       </soapenv:Header>
       <soapenv:Body>
            <typ:CreateMasterClip>
            <typ:DestinationFolderURI>interplay://EvertzWorkgroup/Projects/JEFFK</typ:DestinationFolderURI>
            <typ:ClipName>EXAMPLE_Clip</typ:ClipName>
            <typ:Timebase>30i_df</typ:Timebase>
            <typ:TapeName>TapeA</typ:TapeName>
            <typ:StartTimecode>01:03:12:20</typ:StartTimecode>
            <typ:Duration>99999</typ:Duration>
            <typ:Video>true</typ:Video>
            <typ:AudioTracks>2</typ:AudioTracks>
            <typ:SourceMobType>Import</typ:SourceMobType>
         </typ:CreateMasterClip>
       </soapenv:Body>
    </soapenv:Envelope>
    returns this result even though that folder definitly exists and is the same URI I used to make it using the createFolder command.
    <soap:Envelope xmlns:soap="http://schemas.xmlsoap.org/soap/envelope/">
       <soap:Body>
          <soap:Fault>
             <faultcode>soap:Server</faultcode>
             <faultstring>An unexpected error occurred checking in asset to interplay://EvertzWorkgroup/Projects/JEFFK  null.</faultstring>
             <detail>
                <AssetsFaultType Code="OTHER_ERROR" xmlns="http://avid.com/interplay/ws/assets/types">
                   <Message>An unexpected error occurred checking in asset to interplay://EvertzWorkgroup/Projects/JEFFK  null.</Message>
                   <Details>An unexpected error occurred checking in asset to interplay://EvertzWorkgroup/Projects/JEFFK  null.</Details>
                </AssetsFaultType>
             </detail>
          </soap:Fault>
       </soap:Body>
    </soap:Envelope>
    It seems like from reading the help I want to specify SourceMobType as import and not include a tape name since what I want to do is make a master clip that I can use to cal CheckInAAF into, But whenever I try to remove the TapeName I get these errors showing in SOAPUI
    • line 13: Expected element 'TapeName@http://avid.com/interplay/ws/assets/types' instead of 'StartTimecode@http://avid.com/interplay/ws/assets/types' here
    • line 14: Expected element 'TapeName@http://avid.com/interplay/ws/assets/types' instead of 'Duration@http://avid.com/interplay/ws/assets/types' here
    • line 15: Expected element 'TapeName@http://avid.com/interplay/ws/assets/types' instead of 'Video@http://avid.com/interplay/ws/assets/types' here
    • line 16: Expected element 'TapeName@http://avid.com/interplay/ws/assets/types' instead of 'AudioTracks@http://avid.com/interplay/ws/assets/types' here
    • line 17: Expected element 'TapeName@http://avid.com/interplay/ws/assets/types' instead of 'SourceMobType@http://avid.com/interplay/ws/assets/types' here
    • line 17: Expected element 'TapeName@http://avid.com/interplay/ws/assets/types' before the end of the content
  • Mon, Mar 20 2017 9:56 PM In reply to
    • Vadym
    • Joined on Thu, Apr 17 2014
    • Posts 190
    • Points 2,365
    • Avid Developer Moderator
      Avid Employee
    Re: CreateMasterClip seemingly not working.
    Hi Jeff,
    The command will create a master clip that you'll need a MediaComposer to attach media to later. Please let me know what you're trying to achieve here.
    If you have existing media that you want to put into Inteprlay please look into Avid Media Toolkit (AMT SDK) or import features of the existing Avid products.
    Please see a working example of the create master clip command below
       <soapenv:Header>
             <typ:Username>*</typ:Username>
             <typ:Password>*</typ:Password>
       </soapenv:Header>
       <soapenv:Body>
             <typ:DestinationFolderURI>interplay://APIWG/Projects/test</typ:DestinationFolderURI>
             <typ:ClipName>clip1</typ:ClipName>
             <typ:TapeName>tape1</typ:TapeName>
             <typ:StartTimecode>00:00:00:00</typ:StartTimecode>
             <typ:EndTimecode>01:00:00:00</typ:EndTimecode>
             <typ:AudioTracks>0</typ:AudioTracks>
       </soapenv:Body>
    </soapenv:Envelope>
    a response will look like the following if you have a correctly configured working environment:
       <soap:Body>
          <CreateMasterClipResponse xmlns="http://avid.com/interplay/ws/assets/types">
             <Result>
                <InterplayURI>interplay://APIWG?mobid=060a2b340101010501010f1013-000000-a526b707e8e10085-74a30060dd43-9d08</InterplayURI>            <SourceID>interplay://APIWG?sourceid=060a2b340101010501010f1013-000000-9e26b707e8e10085-84ba0060dd43-9d08</SourceID>
             </Result>
          </CreateMasterClipResponse>
       </soap:Body>
    </soap:Envelope>
  • Tue, Mar 21 2017 12:45 PM In reply to
    I was trying to make a master clip in a project that I could check an AAF file into that has been pulled from another AVID production system. It seems like I really want to get familiar with CheckInAAF and Avid Media Toolkit which I now need conatact avid about downloading.
  • Tue, Mar 21 2017 7:36 PM In reply to
    • Vadym
    • Posts 190
    • Points 2,365
      Avid Employee
    Jeff,
    You can apply for AMT using the following page http://www.avid.com/alliance-partner-program/connectivity-program
    If you have AAF from another PAM system then you can use CheckInAAF request to put it into an existing folder.
    The AAF you have contains metadata only and points to media files (MXF essence) on the original PAM system. As the systems do not typically share the same media storage you'll get an offline asset upon checkin into different PAM system.
    It is recommended to use PAM Production services or Transfer Manager to transfer both metadata and media between PAM systems. You could use IPWS to start the transfer jobs only then.
