Latest post Mon, Mar 27 2017 1:58 AM by usatraveler. 17 replies.
  • Sat, Mar 18 2017 3:10 PM
    • keithkowal
    • Swampscott, MA
    • Posts 120
    • Points 1,770
    4k video file format , why doesn't <file.mp4> from sony import
    Just got a comsumer ax100 from Sony - recorded 4k files and it stored the video files in mp4 format.
    The issue i have is that is set up a 4k project in AVID MC8.8 and got this !    Did i set up the 4k project incorrectly or did i record using the wrong format for the file..... ?
    seriously - what the heck !
    2.4 ghz P7 / 3-1T HD / 20gbyte RAM / MC8.8 [view my complete system specs]
  • Sat, Mar 18 2017 4:09 PM In reply to
    • Vilem
    • Joined on Sat, Apr 10 2010
    • Prague
    • Posts 1,382
    • Points 15,210
    Re: 4k video file format , why doesn't <file.mp4> from sony import
    Most likely it XAVC-S codec, for which Sony (Nablet), not published AMA plugin. You can try to use the Convert V4 (trial version limited to two files at once), for repackaging into mov container (very fast). Perch attempt AMA connections in MC. Alternatively recoded in other programs to DNxHR codec (Sorenson, DaVinci Resolved ....)
    V.
    AVID MC8.9.2 - dongle, INTEL Core i7-950,Gigabyte-GA-EX58-UD5, Quadro P2000 - driver 385.08, RAM 24GB - 6 x DDR3, BM Intensity Pro 4k - 10.9.5, W10 -... [view my complete system specs]
  • Sat, Mar 18 2017 4:51 PM In reply to
    • keithkowal
    • Swampscott, MA
    • Posts 120
    • Points 1,770
    I have Sorenson.....
    what file format in sorenson, would work best to convert , so that the resolution is preserved?   "trying -> convert to MOV in sorenson...  didn't work...
    i'm getting frustrated with Avid's lack of codec support ..... i just spent over $1600 for a 4k camera,
    so, what camera would output directly to avid ?   in 4k
    and / or :
    what file format should i look for before buying a camera ?
    i had a canon before  HD , (not 4k) , that Avid supported, no problem / what do i do ?
    Per your response:   Convert V4 , ask to update .net ... win 10 complains, un-secured, etc..
  • Sat, Mar 18 2017 5:07 PM In reply to
    • Vilem
    • Prague
    • Posts 1,382
    • Points 15,210
    keithkowal:
    I do not know what version you Sorenson, if he allows DNxHR codec. DNxHR codecs are new codecs from AVID, successor DNxHD codec, enabling higher resolution.
    You can try TMPGEnc encoder, DaVinci Resolve (light version free) - allows export to MXF ATOM DNxHR, there are tutorials on YouTube ...
    keithkowal:
    This is a business decision by Sony ....No
    keithkowal:
    http://resources.avid.com/SupportFiles/attach/Avid_Supported_Video_File_Formats.pdf
    V.
  • Sat, Mar 18 2017 8:42 PM In reply to
    There's also a plugin spefically for linking XAVC-S by Drastic Technologies, for I think $99.
    (SYSTEM 1) iMac Late 2012 27" (13,2), Mac OS X 10.12.6, Avid Media Composer 8.9.2 w/Symphony, Intel Core i7 3.4 GHz, 32 GB RAM, NVIDIA GeForce GTX... [view my complete system specs]
  • Mon, Mar 20 2017 12:45 AM In reply to
    • keithkowal
    • Swampscott, MA
    • Posts 120
    • Points 1,770
    The simple solution is for me - is to use Sorenson and convert the *.mp4 (4k) file to <file.mov>  , it then imports
    after that, into a 4k project (29.97) , NO Problem
    Thanks for all comments..
    k
  • Mon, Mar 20 2017 1:59 PM In reply to
    • ramz434
    • Long Island
    • Posts 150
    • Points 1,895
    On Friday, I just had this same problem. I have Squeeze, but the Convert V4, for $20, knocked out about 2 hours of XAVC-S footage real quick, as it just rewraps the files to MOV, instead of converting them all.
    - HP Z400/24gb ram/Windows 10/MC8.9/256gb Samsung SSD/ NVidia GTX 1080/Dual HP ZR22 Monitors/ - Macbook Pro/16gb ram/OS 10.11/MC8.6/NVIDIA GeForce... [view my complete system specs]
  • Mon, Mar 20 2017 3:55 PM In reply to
    • dmfreeman
    • Michigan
    • Posts 1,829
    • Points 23,925
    I have used Convert V4 to wrap to MOV files.  Also the Drastic plug in for $99 allows you to link from directly within MC.
    Denny
    Media Composer 8.5.4, BCC 10.0.0074, AvidDVD 6.4.4, Boris Red 5.5.2.1382, Asus P9X79 Pro Motherboard with Intel 3930K Processor. 32 gigs DDR3 ram, Windows... [view my complete system specs]
  • Mon, Mar 20 2017 11:26 PM In reply to
    • keithkowal
    • Swampscott, MA
    • Posts 120
    • Points 1,770
  • Wed, Mar 22 2017 8:46 PM In reply to
    • ttv
    • Joined on Sat, Jul 28 2012
    • Germany
    • Posts 27
    • Points 270
    hi,
    you just need to rewrap the files to *.mov container with ffmpeg. after that avid will link to the files and you can transcode them. its pretty easy:
    ffmpeg -i "input_xavcs_file.mp4" -vcodec copy -acodec copy -timecode $tc "output.mov"
    only problem is, that reading the timecode isnt that easy. you can read it from the "input_xavcs_file.xml", stored next to the "input_xavcs_file.mp4" or find it in the last bit of the inputfile. just note that the tc is stored like this:
    LtcChange value="09290518"
    you need to read the parameters from behind. the tc here is 18:05:29:09
    you also can use ffmpeg to bring the files directly to avids mxf-op-atom norm btw.
    hope that helps!
    2x z400, 24GB RAM, 1xQuadro2000(310.90), 1xQuadro4000(310.90) QuickTime7.7.3, Win7Pro64bit, Symphony6.0.5, NitrisDX 1x z400, 24GB RAM, Quadro2000(310... [view my complete system specs]
  • Thu, Mar 23 2017 7:59 PM In reply to
    • cls105
    • KTOWN LOS ANGELES
    • Posts 236
    • Points 3,240
    Lately ive been using FFMPEG with "another gui"
    I use the prores presets. It will make prores versions of your files at the source framerate and resolution.
    Then I'll ama the prores files, and consolidate them into Media Composer.
    Media Composer works quite well with prores if you consolidate it.
    And yes, I'm doing all of this in Windows 10.
    DIY intel 7820x, asus x299-e mainboard, Quadchan 64gb ram, win10 home 64bit creators, 1080ti, Blackmagic Intensity 4k. The latest Media Composer. [view my complete system specs]
  • Thu, Mar 23 2017 9:40 PM In reply to
    • ttv
    • Germany
    • Posts 27
    • Points 270
    cls105:
    the problem here ist that ffmpeg will need to transcode the files an if you are not that experienced with ffmpeg you can make lots of mistakes in that step. if you just rewrap the clips, ffmpeg wont touch the codec, just change the container and you can use avids dnxhr codecs for getting the clips with untouched framerate and aspect into the system.
  • Fri, Mar 24 2017 1:12 AM In reply to
    • gumbaedit
    • Richmond, VA
    • Posts 514
    • Points 6,760
    I have found that davinci resolve has become my go to for a lot of file conversions.  Not only will it handsle some cosnsumer formats, but you can transcode it to almoist anything you want as well as enter metadata to track it later.  On my last project I ran all of my XAVC-S footage thru it to transcode to DNxHD 36.  After locking poicture in avid, it relinked perfectly when I conformed and colored in Resolve
    6 core Late 2013 MacPro 3.0 gHz, 16 gigs RAM, MC 8.8.5 on OSX 10.12.4, DNxIO, Flanders CM250, BMD Desktop Video version 10.9.1 [view my complete system specs]
  • Sat, Mar 25 2017 5:04 PM In reply to
    • keithkowal
    • Swampscott, MA
    • Posts 120
    • Points 1,770
    Here is the next hurdle i have to overcome with this  AMA stuff...
    what i'm use to is exporting a ref quicktime to allow sorenson to do it's thing.   so now what ?  come on, this 4k stuff is messing me up !
    Export to what ? obvioiusly not quicktime....
  • Sat, Mar 25 2017 7:18 PM In reply to
    • ramz434
    • Long Island
    • Posts 150
    • Points 1,895
    You can do Same As Source and bc its AMA footage - Avid will choose the DNX flavor you have set in your Media Creations settings (I think thats where it pulls if from) - other wise you can choose a particular DNX setting and output that way. If its just for ciient review - I usually just do Same As Source and put it into Squeeze from there.
