Latest post Mon, Mar 20 2017 8:01 PM by mikedeluca. 1 replies.
Page 1 of 1 (2 items)
  • Thu, Mar 16 2017 11:39 PM
    • cda
    • Joined on Thu, Feb 26 2015
    • Posts 1
    • Points 15
    SetValues(const IACFString *xml) and IAAFClips::GetMetadata
    We are trying to develop AMA writeback plugin, but we are faced with some strange behavior in the host application. The first problem is setting values in method SetValues(const IACFString *xml) - the input string is empty, but in GetValues and GetParameterInfos methods I set two integer checkboxes. Our implementation of all IACFParametersXML methods is in attached .cpp file in link: https://www.dropbox.com/s/y5u4rpzdohnffvg/xmlparams.zip?dl=0 Also, if I change any parameter in UI and click "Save", host suggests me to save preset, but always fails with message "Failed to save profile: profile_name", if I press "Yes". The second problem is defining start timecode and duration of export. As I understand, it can be parsed from IAAFClips::GetMetadata, but I cannot find any examples or documentation how to do. thanks!
  • Mon, Mar 20 2017 8:01 PM In reply to
    • mikedeluca
    • Joined on Tue, Feb 28 2017
    • Posts 3
    • Points 25
    Re: SetValues(const IACFString *xml) and IAAFClips::GetMetadata
    Hi, I will take a look at the AMA plug-in data you provided.  If the problem seems to originate in the host, I will recruit assistance from the MC application team.
    -Mike
