Latest post Fri, Mar 17 2017 8:17 AM by Francesco. 2 replies.
  • Thu, Mar 16 2017 4:24 PM
    • Francesco
    • Joined on Wed, May 16 2012
    • Pisa - Italy
    • Posts 68
    • Points 675
    AMA Validator win 0.13.0.10000 : Fail
    Hi
    I'm writing because the validation of my plugin fails despite that Media Composer (version 8.7.2) works well.
    The command I issued is:
    AMAValidator.exe -v PRIMO_Cam_C_0001.blt
    Results is:
    File: c:\Downloads\AMAValidator-win-0.13.0.10000\bin\release\PRIMO_Cam_C_0001.blt
    [ERROR  ] [IMEHost] IACFClassFactory::CreateComponent failed (80000004), CompID={550CE07A-B37A-4CE6-8A3A-D66B9C6FBE55}, IID={41400962-A89C-4BBD-8EFC-F0CC0744AFF4}
    [INFO   ] [AAFSchemaValidator] Header Identification #1:
    [INFO   ] [AAFSchemaValidator]      CompanyName : BLT Italia SRL
    [INFO   ] [AAFSchemaValidator]      ProductName : BLTAPlugin
    [INFO   ] [AAFSchemaValidator]      ProductVersion : 2.2.0.0
    [INFO   ] [AAFSchemaValidator]      ProductVersionString : 2.2.0.8
    [INFO   ] [AAFSchemaValidator]      ProductID : 1905E9A3-A91A-4A2F-9133A2EE16999B7D
    [INFO   ] [AAFSchemaValidator]      Platform : AAFSDK (Win64)
    [INFO   ] [AAFSchemaValidator]      Date : 03.15.2017, 09:09:29
    [ERROR  ] [AAFSchemaValidator] Source reference in file mob slot 3 associated with 4-channel audio contains non-zero SourceMobSlotID
    [INFO   ] [AAFSchemaValidator] Slot found: Type: Picture, ID: 2, PhysicalNum: 3628680896, Origin: 0, Name: V1, Length: 125 with edit rate of 25/1
    [WARNING] [AAFSchemaValidator] Sequence element not found in Master Mob TimelineMobSlot=2.
    [INFO   ] [AAFSchemaValidator] Slot found: Type: Sound, ID: 3, PhysicalNum: 3623043280, Origin: 0, Name: A1, Length: 250 with edit rate of 50/1
    [WARNING] [AAFSchemaValidator] Sequence element not found in Master Mob TimelineMobSlot=3.
    [INFO   ] [AAFSchemaValidator] Slot found: Type: Sound, ID: 4, PhysicalNum: 3623043280, Origin: 0, Name: A2, Length: 250 with edit rate of 50/1
    [WARNING] [AAFSchemaValidator] Sequence element not found in Master Mob TimelineMobSlot=4.
    [INFO   ] [AAFSchemaValidator] Slot found: Type: Sound, ID: 5, PhysicalNum: 3623043280, Origin: 0, Name: A3, Length: 250 with edit rate of 50/1
    [WARNING] [AAFSchemaValidator] Sequence element not found in Master Mob TimelineMobSlot=5.
    [INFO   ] [AAFSchemaValidator] Slot found: Type: Sound, ID: 6, PhysicalNum: 3623043280, Origin: 0, Name: A4, Length: 250 with edit rate of 50/1
    [WARNING] [AAFSchemaValidator] Sequence element not found in Master Mob TimelineMobSlot=6.
    [INFO   ] [AAFSchemaValidator] The Network Locator after percent decoded is: 'file:///c:/Downloads/AMAValidator-win-0.13.0.10000/bin/release/PRIMO_Cam_C_0001.blt'
    [INFO   ] [AAFSchemaValidator] Slot found: Type: Timecode, ID: 1, PhysicalNum: 3628680752, Origin: 0, Name: Timecode, Length: 12960000 with edit rate of 25/1
    [WARNING] [AAFSchemaValidator] Can't retrieve Physical Track Number from Physical Source Mob, slot=1
    [INFO   ] [AAFSchemaValidator] Slot found: Type: Picture, ID: 2, PhysicalNum: 3623043280, Origin: 0, Name: V1, Length: 12960000 with edit rate of 25/1
    [WARNING] [AAFSchemaValidator] Sequence element not found in Physical Source Mob TimelineMobSlot=2.
    [WARNING] [AAFSchemaValidator] Can't retrieve Physical Track Number from Physical Source Mob, slot=2
    [INFO   ] [AAFSchemaValidator] Slot found: Type: Sound, ID: 3, PhysicalNum: 3623043280, Origin: 0, Name: A1, Length: 12960000 with edit rate of 50/1
    [WARNING] [AAFSchemaValidator] Sequence element not found in Physical Source Mob TimelineMobSlot=3.
    [WARNING] [AAFSchemaValidator] Can't retrieve Physical Track Number from Physical Source Mob, slot=3
    [INFO   ] [AAFSchemaValidator] Slot found: Type: Sound, ID: 4, PhysicalNum: 3623043280, Origin: 0, Name: A2, Length: 12960000 with edit rate of 50/1
    [WARNING] [AAFSchemaValidator] Sequence element not found in Physical Source Mob TimelineMobSlot=4.
    [WARNING] [AAFSchemaValidator] Can't retrieve Physical Track Number from Physical Source Mob, slot=4
    [INFO   ] [AAFSchemaValidator] Slot found: Type: Sound, ID: 5, PhysicalNum: 3623043280, Origin: 0, Name: A3, Length: 12960000 with edit rate of 50/1
    [WARNING] [AAFSchemaValidator] Sequence element not found in Physical Source Mob TimelineMobSlot=5.
    [WARNING] [AAFSchemaValidator] Can't retrieve Physical Track Number from Physical Source Mob, slot=5
    [INFO   ] [AAFSchemaValidator] Slot found: Type: Sound, ID: 6, PhysicalNum: 3623043280, Origin: 0, Name: A4, Length: 12960000 with edit rate of 50/1
    [WARNING] [AAFSchemaValidator] Sequence element not found in Physical Source Mob TimelineMobSlot=6.
    [WARNING] [AAFSchemaValidator] Can't retrieve Physical Track Number from Physical Source Mob, slot=6
    [WARNING] [AAFSchemaValidator] Required MediaContainerGUID property not found in File Source Mob essence descriptor.
    [INFO   ] [AAFSchemaValidator] Slot found: Type: Picture, ID: 2, PhysicalNum: 3628678544, Origin: 0, Name: V1, Length: 125 with edit rate of 25/1
    [WARNING] [AAFSchemaValidator] Sequence element not found in File Source Mob TimelineMobSlot=2.
    [WARNING] [AAFSchemaValidator] Sequence element not found in File Source Mob TimelineMobSlot=3.
    [WARNING] [AAFSchemaValidator] Sequence element not found in File Source Mob TimelineMobSlot=4.
    [WARNING] [AAFSchemaValidator] Sequence element not found in File Source Mob TimelineMobSlot=5.
    [WARNING] [AAFSchemaValidator] Sequence element not found in File Source Mob TimelineMobSlot=6.
    [INFO   ] [AMAMappingProviderValidator] IMediaContainer::IsContainerSupported() took 0.000000 seconds
    [ERROR  ] [AMAMappingProviderValidator] IMediaContainer::GetSampleMapping() failed to return sample mapping interface.
    VALIDATION FAILED. ERRORS: 2. WARNINGS: 22.
    Plug-in: "MVP_MSP_BLT Avid Plug-In 2.2.0.8 BLTAPluginMediaContainer"  File: c:\Downloads\AMAValidator-win-0.13.0.10000\bin\release\PRIMO_Cam_C_0001.blt
    I can't figure out why validation fails while all seems to work under Media Composer.  Moreover: Did you have an example in order to remove warnings ?  I started writing my plugin from the MVP_MSP_SampleCam example in the AMA SDK documentation (release used is 3.3.0.3185) .
    Best regards
    Francesco
  • Thu, Mar 16 2017 10:05 PM In reply to
    • mikedeluca
    • Joined on Tue, Feb 28 2017
    • Posts 5
    • Points 55
    Re: AMA Validator win 0.13.0.10000 : Fail
    Francesco,
    I am glad to see you are using the latest AMAValidator.  From the report, it seems you have 2 errors: failure to signal interleaved audio and a failure to return a sample mapping interface.  Try again without the '-v' option because that is showing some internal erorr processing that may not be relevant.  Repost the results and then we can work through each issue.  The reason why Media Composer will still function even with AMAValidator errors is that the AMAValidator is checking deeper within the AMA AAF schema and may uncover issues that would show up later in an end-to-end work flow.
    -Mike
  • Fri, Mar 17 2017 8:17 AM In reply to
    • Francesco
    • Pisa - Italy
    • Posts 68
    • Points 675
    Hi Mike
    here is the response to the  same command without -v :
    Validating c:\Downloads\AMAValidator-win-0.13.0.10000\bin\release\PRIMO_Cam_C_0001.blt using all available local plug-ins
    In the meanwhile I inserted some OutputDebugString inside the SampleMapping interface (in the Class instantiation, in the class destructor and in the InitializeInstance function) in order to display if something goes wrong, but seems all ok.  Result in the last methods is ACF_OK .
    Francesco
