Latest post Thu, Mar 16 2017 3:18 PM by Jason Sedmak. 3 replies.
  • Wed, Mar 15 2017 2:38 PM
    • Brian Berdan, ACE
    • Joined on Mon, Nov 4 2013
    • Usually Seattle or Los Angeles
    • Posts 43
    • Points 440
    MotionEffect/Position- add keyframe button missing
    I usually use the "Speed" graph with motion effects, only occasionally using the "Position" one.  But today I notice there is no pink Add Keyframe button on the Position panel.  It's there on the Speed one.  I'm sure it used to be there- otherwise how would you use it?
    Using MC 8.6.5
    MacPro 2.66, MC 8.6.5, Nitris Apple MacBookPro 17" 2.4 GHz i7, 10.11.4, MC 8.5.1, Aja IoXT [view my complete system specs]
  • Wed, Mar 15 2017 2:48 PM In reply to
    • Brian Berdan, ACE
    • Posts 43
    • Points 440
    Re: MotionEffect/Position- add keyframe button missing
    And it's definitely been there recently as I did do an effect using position... just copied the effect onto a new shot and the button is there. But not when adding a new timewarp effect.  The bar under the graph is all light grey with just the two timecode windows... no 'fast menu', no 'go to next/previous', and no pink triangle.
  • Thu, Mar 16 2017 3:17 PM In reply to
    • Brian Berdan, ACE
    • Posts 43
    • Points 440
    Oops- operator error- need to toggle "Edit Graph" to 'Position'.  20+ years and you still learn things... cool
  • Thu, Mar 16 2017 3:18 PM In reply to
    • Jason Sedmak
    • Joined on Fri, Jul 16 2010
    • Denver
    • Posts 91
    • Points 1,090
    Brian, on my Mac 8.8 system, it is a little wonky, but if you toggle the "Edit Graph" pulldown it 'wakes' it up and those items appear.
    Good luck,
    J
    2010 Mac Pro 2.66 GHz 12-core 64GB GTX 980Ti Solid State Boot 8x Fibre to Terrablock Currently running 10.11.6 El Capitan Symphony 8.9.3 [view my complete system specs]
