Latest post Wed, Mar 15 2017 5:19 PM by Job ter Burg. 3 replies.
  • Wed, Mar 15 2017 5:37 AM
    • Dynamic7
    • Joined on Sat, Oct 10 2009
    • Posts 205
    • Points 2,950
    Sequence clips
    I have approx: 50 clips in the MC bin , is there a way to combine all 50 clips into one (1) continuos sequence clip ? I know that in some of the other NLE's this can be done so I'd like to know if it can be achieved in MC also.
  • Wed, Mar 15 2017 6:08 AM In reply to
    • Mondo
    • Sydney Australia
    • Posts 1,625
    • Points 18,630
    Re: Sequence clips
    Dynamic7:
    Depends - you can arrange the clips in pic view in the order you want then lasso them all and drop them on to the timeline. You can even sub-edit them with ins and outs before doing that. Its Avid 101 and in their very first tutorial. Youc an also use the Autosequence function to highlight a bunch of clips and create a sequence.
    You can't combine them into a single clip but you can use that sequence as a source for another sequence.
    It only falls over when trying to seamlessly create a new clip that you could then use in say a multicam. You can do this in Premiere but not Avid. You would have to export the sequence and re-import the master clip or do a video mixdown.
    John
  • Wed, Mar 15 2017 4:38 PM In reply to
    Re: Sequence clips
    In your bin, order the clips as you want them, clear all ins and outs, and make sure you're at the beginning of each clip.
    Clear your edit window, select all your cllips, then Alt-Drag them into your edit viewer. The sequence will appear in your bin.
    Bob's your Uncle.
  • Wed, Mar 15 2017 5:19 PM In reply to
    Re: Sequence clips
    Or select all clips you want, hold ALT and choose Bin->AutoSequence. This will automatically clear ins and outs.
    However, the result is a sequence, and you cannot matchframe back to it.
