Latest post Sat, Jun 3 2017 12:17 AM by George Angeludis. 7 replies.
  • Mon, Mar 6 2017 10:01 AM
    Avid MC 8.8 Installation and PACE license problem
    Due to iLok problems with MC 8.6.4 I upgraded to MC 8.8. using the Applicaton Manager. However, the iLok problem remains. PACE License Support Win 64 Version 3.1.3. (included in MC 8.8 installer) was not installed.
    So I deactivated MC 8.8, deinstalled MC 8.8, "License Support" and "Interlok driver setup x64" as advised here: http://community.avid.com/forums/p/122828/706750.aspx#706750
    (deinstalling "License Support" was only possible using Revo Uninstaller). Then I installed and activated the download version of MC 8.8.
    Result: When starting MC 8.8, error message says the necessary software for validation of the product is not running, I should first install iLok license manager.
    I downloaded and tried to install PACE License Support Win64_v3.1.4_r36376 from www.ilok.com (the only available version, however v3.1.3 would be needed). An error message says "Your Windows System needs updates to run this software. 1603 fatal error during installation". I updated Windows 7, not all of 24 updates could be installed.
    Then I began the whole process from the beginning. Nothing helps.
    MB: ASUS P6TD Deluxe, ATX, Intel X58, QPI 6.4GT/s, Intel LGA1366, 6xDDR3 1600MHz, PCI-E V2.0, On-board Soundkarte. CP: Intel Core i7 920 (2.66 GHz) Quad... [view my complete system specs]
  • Mon, Mar 6 2017 10:58 AM In reply to
    Re: Avid MC 8.8 Installation and PACE license problem
    http://community.avid.com/forums/t/180175.aspx?PageIndex=4
    MC/SN 2018.5 x 15 Z400/420/440 PC's 2 x Mac, 4 x PT 12.8.1 HDX all on PCs. [view my complete system specs]
  • Mon, Mar 6 2017 3:42 PM In reply to
    Problem solved:
    The problem is in PACE 3.1.3, which is integrated in MC 8.8 installer. However, when I started MC 8.8 an error message "reinstall or download and run iLok License Manager" appeared.
    So I tried to download PACE 3.1.3 from the iLok website directly, but only v3.1.4 was available. When I tried to install it, a Windows system update was requested, which I did, with no success.
    So I downloaded and installed a previous version, License Support Installer Win64 v2.4.7, before I installed MC 8.8. However, the integrated PACE 3.1.3 did not install, but v2.4.7 disappeared from system/programs&features. Of course, when opening MC 8.8, "reinstall or download and run iLok License Manager" appeared again.
    So I installed again PACE 2.4.7. Now MC 8.8 runs with no problems.
  • Mon, Mar 6 2017 4:12 PM In reply to
    I found with an older iLok version on some PCs, when MC 8.8 launched it would give error messages about disabling soundacards!
  • Thu, Mar 16 2017 4:10 PM In reply to
    After installing 8.8.1 I find I am returning to more license issues.  I was getting an error message when starting SN/MC that there was software not enabled, namely PACE iLok protection.  I traced this to the delayed service start.  If you get this message, RMC My Computer>manage>services and applications>services.  Double click Pace License Services and change from  Automatic(delayed start) to Automatic start.  This sorted it for me and I am unaware yet of any other issues this may cause.   I have an SSD drive on this system and it boots fast, may be too fast?
  • Fri, Mar 31 2017 9:52 AM In reply to
    Just for your information.
    PACE license services 3.1.3 may require Windows security patch,
    same as NXIS client and recent DNxIO driver.
    So, do windows update or install two security patches KB3035131 and KB3033929,
    then install PACE license services from MC 8.8 installer.
    I tihnk this should be written in ReadMe of MC 8.8.
    Thanks.
  • Thu, Jun 1 2017 10:44 PM In reply to
    • cheknews
    • Joined on Sat, Jan 1 2011
    • Posts 66
    • Points 870
    We googled KB3125574 and found a mirror that had it.  Downloaded that and iLok 3.1.3 installed and we're up and running.
    MC 8.3, i7, 12Gb ram, quadro 4000, matrox mx02 mini, windows 7 pro, [view my complete system specs]
  • Sat, Jun 3 2017 12:17 AM In reply to
    New MC installations doesn't like new iLok drivers on Win7x64.
    It needs older iLok driver as others have pointed out.
    Desktop
    Corsair RM750X/Asus P8Z68 Deluxe(Gen3)/i7 2600K@4.4/Corsair 32G DDR3/PNY Quadro P2000D(390.77)/Samsung 850 Pro SSD(OS) 256 GB/ 2x2TB WD RE4@RAID 0/LG BH16NS40/W10 Pro 64bit/Media Composer Software 2018.5 with Symphony Option/2xHP 22'' Monitors/M-Audio AV30 Speakers.
    3 Heads Digital Films
