Latest post Mon, Mar 6 2017 9:48 AM by Harry Invision. 2 replies.
  • Mon, Mar 6 2017 2:21 AM
    • Harry Invision
    • Joined on Wed, Feb 3 2010
    • Brisbane, Australia
    • Posts 91
    • Points 1,105
    Multicam Idea?
    Hi All,
    Just wondering if anyone has a good workflow for Multicaming big shoots. We have Two Sony F5s running with 7 Go Pros and Drones running. So up to 10 streams at once with various TOD Codes. This happens over 60 Days with 12hour shoot times as its a travelling Road Trip. A section of day looks like below....
    Now the only Multicam method that works is Aux Timecode, add edits and sync. Which is hugely time consuming. Collasping camera vision layers, adding P in P to each layer match frame and editing a new track is far faster, in the long run. Example below...
    Now simply if we could multicam layers or sub masters, this would fix a huge workflow problem. Any reality tv program using multicam shoot must run into the same problems? Has anyone figuired a workflow?
    Regards
    Paul H
    Media Comoposer 2018.4 + Symphony DX Nitris HP Z840 E5-2659 Quadro P4000 32Gb of Ram Win 10 64bit 64TB Editshare 16TB Internal Raid [view my complete system specs]
  • Mon, Mar 6 2017 6:24 AM In reply to
    • TrevorA
    • Posts 1,017
    • Points 11,630
    Re: Multicam Idea?
    On an iphone, so can't see your screen grabs.
    If the recordings are free run TOD then I use auto sequence to get 1 video layer per camera which makes for easier sync.
    Once synced I'll use PIP then export a 'multiviewer' pass and bring that back in and add as the top video layer. (Means, once grouped, I can do editorial looking at all cameras without overhead of trying to play them all.
    Then use groupitforme to create groups from the sync map (I don't do a lot of reality so mostly I can group it myself).
  • Mon, Mar 6 2017 9:48 AM In reply to
    • Harry Invision
    • Posts 91
    • Points 1,105
    Re: Multicam Idea?
    Thanks Trevor,
    Sounds like a good idea, one low res mixdown. The second editor has a slower machine so would work well.
    It is a big set up but the time saving over three month of post would be great.
    Harry
