Latest post Sun, Mar 19 2017 7:03 PM by sealke. 8 replies.
Page 1 of 1 (9 items)
  • Sat, Mar 4 2017 10:53 AM
    • struijs
    • Posts 54
    • Points 760
    Media Composer 8.8.0 import/select files and cmd-a
    Hi Avid,
    What is wrong with cmd-a to select all my (XDCAM) files in the import/media link screen?
    Since 8.7 this is not working anymore and i have to use Shift or cmd to select more files.
    Also a pain in the a** for a long time is that i always get the warning that i have to fill in my disc label. I 100% agree. But please give me the option to do that before selecting my files.
    And the last one, opening avid, my last project is automatic selected, but i cant just press enter anymore to continue. Now i have to grab my mouse and press ok. Why.....?
    Why do you implement these changes? It makes our workflow slower than the last 10 year. And in my option, it makes no sence.
    Kind regards to all, Peter
    MC 8.8.0, PDW-U2, Mac [view my complete system specs]
    Filed under: , , ,
  • Sun, Mar 5 2017 12:26 AM In reply to
    Re: Media Composer 8.8.0 import/select files and cmd-a
    I've also noticed this in 8.7.2 when importing audio files.
    +1
    MC 8.8.2 OSX 10.12.3 Quicktime 7.6.6 Nitris DX [view my complete system specs]
  • Wed, Mar 8 2017 12:52 AM In reply to
    • Mondo
    • Sydney Australia
    • Posts 1,607
    • Points 18,400
    struijs:
    I'm not sure but that is not the correct workflow. Click on the folder above the BPAV directory or the BPAV directory and Avid (via the correct AMA plugin) will link to all the XDCAM clips in that folder.
    John
  • Thu, Mar 9 2017 9:31 PM In reply to
    • struijs
    • Posts 54
    • Points 760
    I am talking abut XDCAM Disc files.
  • Thu, Mar 9 2017 9:51 PM In reply to
    I have confirmed that it's not working, as you report, but am looking for follow up if that changed for some purposeful reason or if it's a bug.
  • Thu, Mar 9 2017 10:01 PM In reply to
    • struijs
    • Posts 54
    • Points 760
    Cmd-a works everywhere. But not in this window.
    Thanks for testing. Do you report it as a bug?
    Did you test also the XDCAM label bug? This is for a long time a bug in my idea.
    Try to import some files from disc with entering the label. you can not. You only can fill in the label after the "error" from MC that you have to fill in the label.
    But thats we i wanted, but could not...:-)
    Peter
  • Thu, Mar 9 2017 10:20 PM In reply to
    Avid knows CMD+A doesn't work, and they think it should, since all input/output windows are driven by the OS. But they are checking to see if that was a change or a bug, so I'll report back when I know more.
    Sorry we don't use XDCAM here so I have no way of testing that workflow.
  • Thu, Mar 9 2017 10:32 PM In reply to
    • struijs
    • Posts 54
    • Points 760
    Thank you Kevin.
  • Sun, Mar 19 2017 7:03 PM In reply to
    • sealke
    • Joined on Fri, May 25 2007
    • Posts 38
    • Points 450
    Hi all,
    cmd+a is also not working for me when importing media like wav files.
    I'm working on OSX 10.9.5 with MC Version 8.6.5.
    sealke
    Mac Book Pro Retina, 2,3GHz, 16GB, OSX 10.9.5, MC 8.6.5 [view my complete system specs]
