Latest post Wed, Mar 8 2017 12:04 AM by Mondo. 9 replies.
Page 1 of 1 (10 items)
  • Tue, Feb 28 2017 2:46 PM
    • PreteMedia
    • Joined on Thu, May 24 2012
    • Posts 3
    • Points 65
    Building Custom PC
    I am currently upgrading my hardware and am looking at building a PC from the ground up.  I will be working mostly HD but also will have several projects originating on 4K.  I also do a fair amount of Adobe After Effects work along with Premiere Pro and Adobe Encoder.  I'm looking to build the system with an internal raid for media.
    Below is a link to the build with parts picked out.  Looking for comments and suggestions.
    https://pcpartpicker.com/user/MoonFartFlam/saved/8XfkLk
    1. Should I wait to see what NVIDEA has to offer in a few weeks with the new P series graphic card?
    2. On the internal raid will I be better off using a pcie raid controller card or will the onboard raid conroller on the Supermicro MOBO suffice?
    3. According the the MOBO specs it will support Thunderbolt 2 technology.  Does anyone have any experience with pcie thunderbolt cards and performance.
    Any other info or comments are welcome.
    John
  • Tue, Feb 28 2017 8:57 PM In reply to
    • videoguy
    • Plainview, NY
    • Posts 481
    • Points 6,680
    Re: Building Custom PC
    that looks like a pretty solid system, but be warned. Building a dual xeon machine is a bot more complicated then snapping together a DIY gaming / video editing system. Stuff like physics - weight, leverage and heat become critical. Air flow is madatory.
    Have you looked into just getting an HP Z 840 workstation. Check out the specs on this Videoguyss Tech Select for $4,995
    VIDEOGUYS TECH SELECT HP Z840 DUAL OCTO-CORE WITH QUADRO M4000
    http://www.videoguys.com/shop/allbrands/brands-d-h/hp-workstations/hp-z840/hp-z840-under-5k.html
    • Dual Octo-Core Xeon E5-2620v4 2.1 2133
    • 32GB (4x8) DDR4-2400
    • 256GB Solid State Boot Drive
    • NVIDIA Quadro M4000 8GB 4xDP
    • Slim Blu-ray Writer
    • HP 15-In-1 Media Card Reader
    • Thunderbolt 2
    • Upgraded 1125w Power Supply
    • Now with Windows 10 Pro
    • 3/3/3 Year Onsite Warranty
    Add in a G-Tech thunderbolt RAID 12TB for $599.95
    Feel free to call me with any questions you may have 800-323-2325
    Gary
    Media Composer 3.5 ASUS P6X58D-E w/ Intel i7 980 Hex-core, 24GB RAM, PNY Quadro4000, Win7, SATA Boot drive, G-Speed eS for video [view my complete system specs]
    Videoguys.com 800 323-2325 http://www.videoguys.com We are the Digital Video Editing & DVD Production Experts
  • Wed, Mar 1 2017 3:47 PM In reply to
    • PreteMedia
    • Posts 3
    • Points 65
    So now I am thinking about the choice of video card.  I know the NVIDIA Quadro M4000 will work but seeing that I am also using this system for After Effects and Premiere Pro does anyone have any thoughts on the new GTX 1080 Ti?
    https://arstechnica.com/gadgets/2017/02/nvidia-geforce-1080ti-will-launch-for-699-next-week/
    Any comments and suggestions would be greatly appreciated.
    John
  • Wed, Mar 1 2017 4:15 PM In reply to
    • Atomike
    • Nebraska
    • Posts 719
    • Points 10,965
    The GTX 1080 Ti is cheaper, and looks like it will be a beast.
    In theory, it should work fine with a Media Composer machine.  My only worry would be the fact that it's not 100% supported, and so every time I have any little problem with my PC, I would wonder if it was because I wasn't using a Quadro card.
    But yes, you are right, it seems like a much better choice on paper.  I just realistically want to be the first guy to try it.
    Media Composer version: usually newest release, or 1 behind. Nvidia GTX 1070Ti Windows 10, Core i7 8700K processor, ASRock GA 1151 Z370 Motherboard... [view my complete system specs]
    I spend most of my time between New York and Los Angeles.  In Nebraska.
  • Wed, Mar 1 2017 4:19 PM In reply to
    • videoguy
    • Plainview, NY
    • Posts 481
    • Points 6,680
    GTX1080 is a beast and fantastic valeu. It kicks Adobe software into a whole nutha gear.
    Gary
  • Wed, Mar 1 2017 5:24 PM In reply to
    • scocklin
    • Maryland
    • Posts 651
    • Points 7,835
    Why not both?  The M4000 for GUI and the GTX1080 for GPU.  Not only improving performance for After Effects but also increasing render times in Resolve for those 4K outputs.
    I'm running the K4000 and GTX780, I need to get my render speeds up in Resolve, right now depending on nodes I'm rendering anywhere from 3 to 10FPS with the GTX780 running as my GPU, I just read that Nvidia starts selling this month the new GTX1080 Ti with a street price of around $700. Not a bad price for a card that specs out better than the Titan X.
    http://www.anandtech.com/show/11172/nvidia-unveils-geforce-gtx-1080-ti-next-week-699
    HP Z800 2x 3.46GHz Hex Core X5690, 48GB Ram, Windows 10, Samsung SSD 850 Pro 512GB, Avid Mojo DX, Nvidia Quadro K4000, GTX 1080 FTW, DeckLink SDI 4K,... [view my complete system specs]
  • Thu, Mar 2 2017 1:49 PM In reply to
    • Pheral
    • Sylva, NC USA
    • Posts 966
    • Points 12,235
    PreteMedia:
    I'm pretty sure that Supermicro motherboard won't fit in the Corsair case you've selected.  The X10DAX is an EATX form factor, and the case is ATX.  I've built a couple of DP systems based on the Supermicro boards, and I can tell you that I've always had better luck when I've matched them with Supermicro cases.
    Media Composer v8.9.2 | Windows 10 Professional 64-Bit | Supermicro X10DAi | Intel Xeon E5-2620 v4 Broadwell (x2) | Noctua NH-D9DX i4 (x2) | PNY GeForce... [view my complete system specs]
  • Tue, Mar 7 2017 1:58 PM In reply to
    • Mark
    • Joined on Sun, Dec 19 2010
    • Posts 431
    • Points 4,645
    Stumbled across this while looking for something else:
    http://www.logicalincrements.com/articles/videoediting
    Hope it's useful,
    /mp
  • Tue, Mar 7 2017 10:41 PM In reply to
    • Lukas Boeck
    • Joined on Fri, Jul 31 2015
    • Austria
    • Posts 466
    • Points 5,480
    one thing i can recomment are pseudo watercooled gpus
    no fuss, but allows you to keep the heat away from pricey raid cards.
    isn't available for 1080ti yet.
    MC 8.4.4 Cusom bulid Supermicro X9SRL-F, 32 Gig Ram, 3ware 9750 6x6TB Seagate EC Drives, LSI 9207 + LTO-6, Mojo DX, Artist Color, Flanders CM240, GTX 1070... [view my complete system specs]
  • Wed, Mar 8 2017 12:04 AM In reply to
    • Mondo
    • Sydney Australia
    • Posts 1,625
    • Points 18,630
    PreteMedia:
    Just looking at what you now have for a $1000 more you can get a dual XEON with an HP backed 3/3/3 warranty - I reckon I'd go for that. It has ECC memory (OK not as much as yours) an M4000 which may not be as quick as the 1080Ti but I can vouch for the Z840 - its very well engineered, especially when it comes to cooling and serviceability.
    The warranty is worth at least 500 on it's own..
    and for $600 more you can get a 12TB RAID which is a much better way to store your media than internally..
    Yes it's more but I've experienced the NBD onsite warranty and its fantastic - both for my current machine and an older laptop...
    John
