Latest post Tue, Feb 21 2017 11:55 AM by yekoot_mada. 0 replies.
Page 1 of 1 (1 items)
  • Tue, Feb 21 2017 11:55 AM
    AS5000 API Basics
    Hi guys,
    First off, Im a newbie to all this API integration so apologies for any silly questions.
    So what type of API is the AS5000 running, is it REST?
    Basically I am on Windows and I need a program to send XML commands to our AS5000 and then see the response.  Whats the best tool to use for this as I have tried several without much luck.
    I found one tool and following the AS5000 API guide I sent this request:
    <?xml version="1.0" encoding="utf-8"?>
    but the response always returns with an error 3, which apparantly means bad XML formatting. I cant see where the bad formatting is the response:
    <Reply Status="ERROR" Msg="Error loadXML(API)" ErrNum="3"  />
    Basically, I need some pointers with regards to what tools to use so that I can test the API properly. I am using  REST tool but im not sure it is a REST API.
    Essentially I am looking to develop an app that can remotely start and stop recording on one/all of the channels.
    Also, some example working commands would be greatly appreciated.
    (Yes, I have the API Guide 2.5 PDF)
    Thanks a lot in advance.
