Latest post Sun, Dec 3 2017 11:22 PM by Bruno M. 12 replies.
Page 1 of 1 (13 items)
  • Sun, Feb 19 2017 5:42 PM
    Reducing moire on 4k DJI footage in 1080p/25 project
    I'm in a 1080p/25 project with 4K footage shot with a DJI Inspire drone. The aerial footage is super sharp to the point where I get a very noticable "moire" effect on brick walls and corrigated iron roofs. Is there any way to fix this within MC 8.8? I can bounce all this over to After Effects to fix but it would be great to fix this right within Media Composer and save some time.
    MC 8.8
    Avid Media Composer 2018.10 HP ZBook 17 Gen3, i7-6700HQ CPU @ 2.60Ghz Win 10, 64GB RAM [view my complete system specs]
  • Sun, Feb 19 2017 6:04 PM In reply to
    • Vilem
    • Joined on Sat, Apr 10 2010
    • Prague
    • Posts 1,402
    • Points 15,445
    Re: Reducing moire on 4k DJI footage in 1080p/25 project
    In the attached image to see the resolution playback green / yellow (Draft quality). What will happen when you switch to green? (Bottom left icon on the timeline).
    V.
    AVID MC2018.9 - dongle, HP Z620 - 2 x Intel Xeon E5-2620, Quadro P2000 - driver 390.77, RAM 48GB - DDR3, BM Intensity Pro 4k - 10.11, W10 - 64bit Professional... [view my complete system specs]
  • Sun, Feb 19 2017 9:08 PM In reply to
    Er...yes that does indeed fix the issue! Sadly not the first time that has happened to me...
    Thanks!
  • Mon, Feb 20 2017 3:55 PM In reply to
    • Gretski
    • Posts 170
    • Points 2,275
    Having taken that on board,  I have still had occasions ( even in full green) where DJI 4K footage is too  sharp and moire has occured in a 1080 project.
    Has anyone found a way to fix this ( or other over sharp footage / stills)  within Avid?
    I have in the past had to resort to a 3rd party programs.
    Asus X299, i7 7820, Nvidia 2000M 32GB ram, NVME SSD 8.9.1 ( yes its very fast!) [view my complete system specs]
  • Mon, Feb 20 2017 5:25 PM In reply to
    • mjolnarn
    • Joined on Wed, Feb 8 2006
    • Sweden
    • Posts 13,346
    • Points 159,335
    Boris , Sapphire or Neat Video , not necessary in that order , a very light blur would be my first option however
    Tomas
  • Wed, Nov 29 2017 3:55 PM In reply to
    • jkakos
    • Joined on Wed, Nov 29 2017
    • Posts 1
    • Points 15
    Hi, what codec do you use in avid wokflow?
    I have same problem. I used transcode AMA linked clips method and I choose XDCAM 5O codec...
    And moire has occured.
    Than I tried several things but nothing works, so finaly I batch import all my footage into Avid DNxHD 120 and there is much less moire.
    I think this is codec problem...
  • Fri, Dec 1 2017 7:41 AM In reply to
    I use DNxHD 85 till 185X depending on the project.
    Moire isn't only on DJI but on other cameras as well.
    Desktop
    Corsair RM750X/Asus P8Z68 Deluxe(Gen3)/i7 2600K@4.4/Corsair 32G DDR3/PNY Quadro P2000D(390.77)/Samsung 850 Pro SSD(OS) 256 GB/ 2x2TB WD RE4@RAID 0/LG BH16NS40/W10 Pro 64bit/Media Composer Software 2018.11 with Symphony Option on Dongle/2xHP 22'' Monitors/M-Audio AV30 Speakers.
    3 Heads Digital Films
  • Fri, Dec 1 2017 12:18 PM In reply to
    Best thing to fix 4K drone footage. Get them to shoot HD footage instead!
  • Fri, Dec 1 2017 12:29 PM In reply to
    • Lukas Boeck
    • Joined on Fri, Jul 31 2015
    • Austria
    • Posts 464
    • Points 5,460
    i use after effects for transcoding DJI to dnx.
    levels computer to video + reduce interlace flicker @ 0,9
    not a fix but an improvement.
    MC 8.4.4 Cusom bulid Supermicro X9SRL-F, 32 Gig Ram, 3ware 9750 6x6TB Seagate EC Drives, LSI 9207 + LTO-6, Mojo DX, Artist Color, Flanders CM240, GTX 1070... [view my complete system specs]
  • Fri, Dec 1 2017 10:23 PM In reply to
    • rodpaul
    • Posts 95
    • Points 1,280
    Transcoding Dji 4K to DnXHR results in footage that’s not useable - lots of artifacts in high detail areas and with motion. The original footage looks fine - any ideas?
    Dell T3600T 12 Cores 3.5 ghz Intel 32GRAM K4200 Windows 10 [view my complete system specs]
  • Sat, Dec 2 2017 4:55 PM In reply to
    Moire is the MSG of Video. Gives me the jiggies. We all want fast fixes but where are they? Of all the correction-specific PlugIns and 3rd party tools, has there ever been one called “Moire Fixer”? That would be a real winner, imo.
    Meanwhile, We all have a different footage/plug-ins/monitors/Project frame rates & sizes, but I would be glad to participate in a Moire Bake Off, to search for a crowd sourced Moire solution using 1 downloadable, problematic shot, leading to a crowd sourced vote on which solution worked best. Someone smart could organize this, even Avid could use it to drum up a new kind of community interaction.
    Yesterday I was playing around with some AVX2 Ignite FX, which have controls to blur and/or offset (H or V or both) different color channels, luminance, etc. Seemed promising.
    All I can say is: “No More Moire”!.
  • Sun, Dec 3 2017 2:18 AM In reply to
    • jwrl
    • Melbourne, Australia
    • Posts 8,373
    • Points 96,875
    When I have to deal with it I use AE's noise reduction prior to any scaling, and turn temporal filtering on.  I then adjust the noise reduction until the image starts to develop that plastic look, back off a little from that and render.  It's not exactly fast because of the temporal filtering, but the end result is usually extremely good.
    I've rescued a project that way in this past week that a colleague had just had rejected by the broadcaster.  Only seven shots, but those seven nearly cost him the gig.
  • Sun, Dec 3 2017 11:22 PM In reply to
    • Bruno M
    • Joined on Thu, Feb 11 2010
    • London, UK
    • Posts 532
    • Points 6,770
    I've used Boris effect's temporal blur on stationary shots and it gives a better result than plain blur. You can also use something like the Animatte tool to limit the effect to just the problem areas.
    No good though if you have any kind of movement or camera move!
    HP Z800, HP8760, SonnetFusion RAID, Mojo DX, Symphony 8.10, JVC DTV1910 HD tube monitor, HP Dreamcolor, Avid Artist Color [view my complete system specs]
