Latest post Wed, Feb 15 2017 4:11 AM by avopp. 0 replies.
Page 1 of 1 (1 items)
  • Wed, Feb 15 2017 4:11 AM
    • avopp
    • Joined on Tue, Apr 12 2011
    • Posts 1
    • Points 5
    Media Composer 8.5.3 and Blackmagic Intensity shuttle for thunderbolt
    I have been trying to get our blackmagic intensity shuttle to capture footage straight into avid. Prior to the upgrade from 7.06 to 8.5.3 we were able to record using this setup. I am able to get a video and audio feed but when i press capture the software returns an error of video present but not able to record. I have updated the blackmagic software and still the same error. I am stumped and I am asking for any help if at all possible. I have copied the error notes from the console of media composer.
    We are using a HP zbook G2 and its for a mobile editors. As mentioned before we were able to do this in version 7.04 of media composer using the intensity shuttle. Since i upgraded to 8.5.3 this is not possible.
    Memory stats:  physical = 32683 MB, virtual = 8388607 MB, restriction = 0 MB
    WARNING: Requested LocateBuffer size 2048MB is the same as current size 2048MB.
    Set persistent image cache limit: 200.0 MB in C:/Users/Public/Documents/Avid Media Composer/AvidImageCache
    AWin32Mixer::Open inputMixerID = 4
    Created ADM Device : 1394 Audio
    DirectSound ADM running on Windows OS Version Major=6 Minor=1 Build=7601
    Created ADM Device : DirectSound Audio
    AlertableTimer Win32 constructor, default system clock resolution min = 1, max = 1000000
    MCBootstrap::gwhoami = 30
    AVX Library V1.5
    OpenGL implementation found:
        vendor   = Brian Paul
        renderer = Mesa OffScreen16
        version  = 1.5 Mesa 6.4
        This OpenGL implementation does not support hardware texture render
        maximum render dimensions: = 1920 x 1080 at 8 bits per pixel channel
        vendor   = NVIDIA Corporation
        renderer = Quadro K4100M/PCIe/SSE2
        version  = 4.4.0
        This OpenGL implementation supports hardware texture render
    MonCon Painters: GPU, CPU
    ACPL transfer type: OGL
    ACPL transfer mode: NonOverlapped
    Older CPU<->GPU bus speeds detected (8.5669)
    AAF DLL loaded from : C:\Program Files\Avid\Avid Media Composer\AAFCOAPI.dll
    AAF DLL version     : 1.1.6 (8895) [0]
    Avid Media Access: Device monitor successfully initialized
    MSM directories:1
    LocalMDB::LoadMobsFromMDB() inCallback=0000000000000000 sourceOnle=FALSE
        mediaDirPath phyMobs logMobs
        "C:\Users\Public\Documents\Avid Media Composer\Avid_MediaFiles\" 0.01 sec
        total time=0.01 mobs=0
    Media Drives:
    DATADRIVE (B:), OSVolID = 66, 976759804 totalKB, 975091040 freeKB, 973186566 realFreeKB
    WINDOWS OS (C:), OSVolID = 67, 230811644 totalKB, 164395632 freeKB, 164074547 realFreeKB
    COM2: error (2) The system cannot find the file specified.
    Connecting to workgroup "" TM server ""
    The TransferManager server name is not set! Set the TMClient.ini parameters in the Transfer settings!
    Couldn't get workgroup destination list - result=24
    Couldn't get local workgroup list - result=24
    Couldn't get playback devices list - result=24
    MAX_INDEXES_TO_READ set to 10240
    In Init ARO Cmds
    MTSC state = 0The single frame player will be built for a length of 3600 frames
    MSMRescan() took:     0.006000s
    LocateBuffer Resize from 2048MB to 8192MB
    WARNING: Requested LocateBuffer size 8192MB is the same as current size 8192MB.
    EmbedDNXCC turned OFF.
    EmbedDNXCCOptions Slot 1 turned ON and set to DID(0x61) SDID(0x1).
    EmbedDNXCCOptions Slot 2 turned ON and set to DID(0x61) SDID(0x2).
    EmbedDNXCCOptions Slot 3 turned ON and set to DID(0x41) SDID(0x5).
    EmbedDNXCCOptions Slot 4 turned ON and set to DID(0x60) SDID(0x60).
    SignalSelector::SetSignal failed, continuing.
    The default render wait time is 50
    EWC Play is supported...
    Connecting to workgroup "workgroup" TM server "TM-Srever"
    Workgroup Transfer mode couldn't be determined! The Transfer Manager Server "TM-Srever" may not be available.
        GetTMParameters returned 4 - tmParmValue="NULL" tmParmType="NULL" serverName="TM-Srever"
    StreamingPlayConsumer::DoSDKHWEncodeForCapture - SDK HW encode disabled
    DIDWriter::DoSDKHWEncodeForCapture - SDK HW encode disabled
    Exception:
    @ Wed Feb 15 13:53:37 2017
    * Exception: The deck is either off or not connected. Check
    your deck connections, or try disabling the TC
    track to capture on the fly.
      Capturing master clip :: test
    Exception caught in APlayer::Play - Exception: FATAL_ERROR
    Exception:
    @ Wed Feb 15 13:53:53 2017
    ***** Capture Failed *****  Clip Discarded
    Exception:
    * Exception: Video signal present but not captured.
      Capturing master clip :: raw.01
    Exception:
    @ Wed Feb 15 13:54:01 2017
    Exception:
      Capturing master clip :: raw.02
    Exception:
    @ Wed Feb 15 13:54:05 2017
    Exception:
      Capturing master clip :: ggg
    Exception:
    @ Wed Feb 15 13:54:26 2017
    Exception:
      Capturing master clip :: raw.03
    Exception:
    @ Wed Feb 15 13:54:59 2017
    * Exception: Audio/video is unexpectedly no longer coming into the system.
      Capturing master clip :: raw.04
    Exception:
    @ Wed Feb 15 13:55:09 2017
    Exception:
      Capturing master clip :: raw.05
    Exception:
    @ Wed Feb 15 13:56:30 2017
    Exception:
      Capturing master clip :: raw.06
    Exception:
    @ Wed Feb 15 13:57:25 2017
    Exception:
      Capturing master clip :: raw.07
    Exception:
    @ Wed Feb 15 13:57:44 2017
    Exception:
      Capturing master clip :: raw.08
    Exception:
    @ Wed Feb 15 13:57:58 2017
    Exception:
    @ Wed Feb 15 13:57:59 2017
    Regards
    Spiro
