Latest post Wed, Feb 1 2017 4:42 PM by Vadym. 1 replies.
Page 1 of 1 (2 items)
  • Fri, Jan 27 2017 11:29 PM
    Web Services failing to authenticate
    Web Services test fails.
    We have Interplay WS running on the LUS/GPS server. We have Telestream Vantage attempting to connect to it but it is not authenticating. I have version 3.6 installed and the self test is not working. I have also tested with v3.5.
    The Telestream Vantage application can connect and pull the workgroup name and get the interplay server name, but it will not authenticate.
    I have checked the following:
    ·         Forward and Reverse DNS lookup to the Interplay Engine from the GPS server running the Web Services
    ·         Service Framework is installed, configured and running on the server that Web Services is installed on
    ·         The lookup server is configured for the Interplay Workgroup (The GPS server is the lookup server)
    ·         The Workgroup name and Interplay Engine host are entered in the Web Services configuration with correct case sensitivity.
    ·         Nexis client is installed and  logged in.
    ·         Interplay Access can log into the Interplay engine from the host the Web Services is running on.
    I’m having a hard time finding what else is wrong and why this will not work.
  • Wed, Feb 1 2017 4:42 PM In reply to
    • Vadym
    • Joined on Thu, Apr 17 2014
    • Posts 190
    • Points 2,365
    • Avid Developer Moderator
      Avid Employee
    Re: Web Services failing to authenticate
    Hi Rob,
    Is this a production environment? Do you have a support case number by any chance?
    Please note that combining IPWS with other other servers is not recommended for production environments.
